Question about Frigidaire FCGM201RFB (1953 cu ft) Commercial Refrigerator
For awhile it was so cold everything froze, even with the thermostat at 1. Now the interior temp is 52, even after I've edged the thermostat to 5 overnight. It's only 2 yrs old.
    Brigadier General:
  • 3,917 Answers
Hi
If the temperature is too low and you can
Posted on Jan 03, 2011
  • poundstar May 11, 2011
    I have this same problem... but can not see your response. all I see is
    "Hi
    If the temperature is too low and you can"
    Can you finish your evaluation.
Fridge too cold!
don't forget that just turning down your fridge temp dose not mean your problem might be over yet. the freezer setting may also be too high & that will affect your fridge temp as well. i set both my control settings to around 50% of what is on the scale & that works perfect for my 7 yr old fridge. also, very important, is make sure the freezer portion is going through it's full defrost cycles, or it will freeze the upper portion inside the fridge. you should not have any frost build up in your fridge, nor should you have any in your freezer. that's why they call them FROST FREE. try the slow temp decrease over a period of a few days & hopefully that will work for you. good luck.
Dec 01, 2011 | Refrigerators
I don't know what happened to my refrigerator but it is starting to freeze everything. I couldn't change filter because it was stuck, frozen in place. So i had to turn the fridge off so it could thaw out...
1 setting on a fridge is as cold as it can get so it will be close to freezing
should be set on 4 or 5
next if it still is freezing then the thermostat is failed and you will need to replace it
May 09, 2017 | Frigidaire FRS23H5ASB Gallery 22.6 Cubic...
Kenmore Coldspot EM5119829. The Freezer works
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp
or..
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Sep 03, 2009 | Refrigerators
Frigidaire is freezing everything!
Possible defrost timer or thermostat failure.
Jul 11, 2017 | Frigidaire FRS26H5AS Side by Side...
Refridgerator acting erratic
The refrigerator/freezer defrost system can be checked by manually initiating a defrost cycle. There
are two methods of initiating the ADC Test Mode.
First Test Method:
1. Turn the thermostat off for 15 seconds.
2. Turn the thermostat on for 5 seconds.
3. Turn the thermostat off for 15 seconds.
4. Turn the thermostat on for 5 seconds.
5. Turn the thermostat off for 15 seconds.
6. Turn the thermostat on for 5 seconds.
7. Turn the thermostat off.
In 3 to 8 seconds the ADC should turn on the defrost heater (with the bimetal closed). NOTE: The test mode will terminate when the bimetal opens. If the refrigerator/freezer is already in defrost, Test Mode can be terminated by unplugging the refrigerator/freezer from the wall outlet and waiting 30 seconds before plugging it back in. The refrigerator/freezer should immediately go into cooling mode if the thermostat is closed.
If this first test procedure fails to make the ADC initiate a defrost cycle, try the following procedure to make the ADC begin the Test Mode.
May 07, 2009 | Kenmore 57029 Side by Side Refrigerator
2002 KIA Sedona Overheating
most likely, replace thermostat .
Apr 14, 2009 | 2002 Kia Sedona
Heater blows cold air unless accelerating
1.maybe your thermostat is no opening or closing.
2. not enough Ant-Freeze
3. Low on water
With more details on the engine i may be able to help you more. for example what is the temp reading after it idles awhile or does it blow warmewr when driving ?
Dec 30, 2008 | 2000 Oldsmobile Intrigue
Kitchenaid freezer will not stay frozen 5 years old
it might be your thermostat stucking up...the one your adjusting one notch higher...
Mar 28, 2008 | Refrigerators
Frigidaire FCGM201RFB (1953 cu ft) Commercial Refrigerator Logo
81 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
