Question about Samsung Kitchen Ranges
Samsung refrigerator rb215lash shows and error code #1, what is it?
5 Suggested Answers
Sea Breeze
  • 4655 Answers
SOURCE: there is water pooling inside the vegetable
Your refrigerator has a defrost drain blockage behind the evaporator in your your fresh food compartment. Some models like yours have 2 evaporators. I recommend that you unplug and remove the cover to the evaporator and check the defrost condensate tray below the evaporator. A wet vacuum cleaner and poring a solution in the drain will help you locate the leak and where. I do have the manual on yours and can help you solve this. Let me know, Sea Breeze
Posted on Jun 30, 2009
  • 132 Answers
SOURCE: Samsung Refrigerator Model RB215LASH Fan motor in
Your problem here is a build up of ice in the freezer.
If you manually defrost the fridge and the problem disappears then you have found the solution.
The defrost cycle is faulty and you will need a technician to sort it out for you
Posted on Apr 01, 2011
  • 706 Answers
SOURCE: I have a samsung refrigerator rb215lash and the
Green board malfunction.
Posted on Oct 31, 2014
goodwinpeg
  • 744 Answers
SOURCE: How do I check a thermal fuse and heater with a digital multimeter on my Samsung rb215lash refrigerator?
Hello Sylvia;
My name is Peter. I am a retired field service technician.
You need to unplug the sensor. Place the bulb in a glass of ice water. After 10 minutes, Set you multi-meter to the lowest Ohms (Omega Symbol), touch the meter leads together you should get a reading of '1.0' or 'OL' the connector has two plugin ports, with one meter probe on the one port and the other probe in the other port, you should get a reading of 16 Ohms.
You have three sensors, one for the freezer, one for the evaporator coil and one for the freezer:
You have two defrost heaters they are part of the drain assemblies: Once again, set your meter on the lowest Ohms. Put one contact in one connector port and the other lead in the other connector port, If you get a reading of '0' or infinity the heater is bad. If it is good you should get some reading 25 to 150 Ohms.
All of these components are behind the back fresh food section and freezer wall.
I am sorry you bought a Samsung. 65% of all of my service calls were either Samsung or LG.
Posted on Dec 11, 2014
Samsung RB215LASH freezer stopped cooling. Temp staying same as fridge
ensure that the vents in the back are not blocked with dust/hair
Sep 07, 2012 | Samsung RB215LASH
WATER LEAK SAMSUNG RB215LASH
When water is leaking inside of your refrigerator, the problem could be as simple as condensation from humidity or a worn gasket, especially since you purchased your refrigerator used. The problem could also be a clogged drain or frozen evaporator.
To help you determine the problem, along with solutions that you can use, check out Refrigerator leaking water inside for some simple troubleshooting steps. I hope that helps!
Aug 02, 2012 | Samsung RB215LASH
Samsung Refrigerator Model RB215LASH Fan motor in freezer becoming increasingly loud
Mar 30, 2011 | Samsung RB215LASH
Samsung fridge, Model#RB215LASW/XAC has defrost problem. Is there any way to gain Fault Codes for this model?
Here's a link for the service manual....This is a complex device....
Kinda like a Prius....
There are tests modes and you can pull the error codes and force modes...
http://www.ajmadison.com/ajmadison/itemdocs/DA68-01778A-EN.pdf
Jan 28, 2010 | Samsung RB215LASH
There is water pooling inside the vegetable crisper of my samsung refrigerator #rb215lash.
Jun 30, 2009 | Samsung RB215LASH
Can not go in yahoo website
unplug your refrigerator.
May 30, 2009 | Samsung RB215LASH
Ice maker not working.........
Reset button on the bottem front right of ice maker
Jul 22, 2008 | Samsung RB215LASH
Kitchen Ranges Logo
75 people viewed this question
Top Samsung Kitchen Ranges Experts
Oloyede Monsuru
Are you a Samsung Kitchen Range Expert? Answer questions, earn points and help others
