Question about Ovens
Our belling double elec oven has just stopped working, no power at all and the fuse has not tripped? any help out there?
    Problem Solver:
  • 16 Answers
Are you sure there is power on the outlet? If yes then probably the power cord is at fault. You should have a handy tester at hand to go further. You could buy a cheap one at any hardware or electronic shop. Now for the power cord. First remove the back cover of your unit. Then set your multimeter to voltmeter range... at the highest range. Plug your oven to the power outlet. Trace the line of the power cord inside the oven. Look for the connections and markings for Line1 and Line2. Now point your test prod to these connections. You should read a voltage similar to your power outlet. If not then replace the power cord. If its OK then remove the power cord to the power outlet. Set the multimeter to the Ohmmeter range. Check the coil if it is OK. You should read a reading of less than a hundred ohms or more. Be sure to remove any connections to the coil before doing this test. If everything goes well according to the test procedure then the culprit must be the power switch or the connection going to it or to the coil.
Posted on Jan 03, 2011
Testimonial: "Thank you for your quick responce. All working now!!! it was fused spur behind the cooker, WHAT A DONUT. but thanks again for the help. Simon"
Kitchenaid superba double oven, stopped working everything dead, breakers not tripped. does not respond to any control.
Open the lower oven door and remove the 2 screws on the left and right trim pieces. Be careful not to drop the trim pieces and bend them. Locate and remove the screws on each side of the control panel and push up on the panel gently to get it off the hangers. Behind the control panel is an over heat fuse that has popped. It plugs into a harness on the back side of the panel. This trips/breaks it's connection from either the oven over heating the cleaning cycle or just from age.? Once fuse is replaced you're good to go. Hope this helps.
Aug 23, 2012 | Ovens
Belling oven xou592 bottom fan oven not heating up fully. Fan works and orange thermostat light on but does not heat up. Before this happened it tripped mcb in consumer unit.
You need to fit a new oven element.
This is located at the rear of the oven behind a removeable cover, where the fan is
It is a fairly straightforward job to replace.
Hope trhis helps with your problem.
Dec 15, 2009 | Belling XOU592 / XOU593 Electric Double...
No fan or heat
Hello..... have you (a) checked that you have power going to the oven...(b)...With the power to the oven switched off open the terminal block (where the cable from your socket enters the oven) check that all connections are secure....(c) remove the rear panel of the oven and check that the safety stat is ok.......(usually small square white or gray unit wit two wires running to it found on rear of main oven...it is usually fixed to a bracket or directly fixed to the cabinet...test for continuity with a multimeter if open circuit ..that is no meter reading relpace it
regards Sir Galahad
Jun 28, 2009 | Belling XOU492 Electric Double Oven
Oven wont work but clock still works
First make sure you didn't trip a breaker. You could have power for the electronics on one side of the 220V and that is why the clock still works. Turn off the breaker and then back on even if it looks on. If it does this again you have a sever problem that will require a service call. If the breaker is tripping it could be other than the oven and if so a new one will work ok unless itsin your wiring.
If this helps you please ratre me accordingly Good luck.
Mar 12, 2009 | Belling XOU252 Electric Single Oven
Belling XOU252 Single Oven Trips Fuses Repeatedly
Hi.
Probably a faulty element, if you feel competent enough, disconnect the feed to the elements in turn, this should eliminate the problem.
Good luck.
Nov 20, 2008 | Belling XOU252 Electric Single Oven
Hotpoint BU62 bouble oven
sounds like the bott oven element has gone, or faulty thermostat.
Dec 09, 2007 | Hotpoint UY46 Style Line Stainless Steel...
Ovens Logo
180 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
