Question about Plantronics Discovery 925 Bluetooth Headset
My 925 is stuck in mute mode i think. I am not able to hear anyone unless i touch the main button and then when i touch it, it hangs up on every call. Is there any way to get this out of this mode?? Help??
I need a bluetooth headset with 30' range and a simple mute button... no "hold for 3 seconds" or "combo" keystrokes.
Posted on Jan 08, 2011
Volume on G E model 21028GE3-4
To adjust the speaker volume, press up/down on the base unit.
To change the ringer volume:
Make sure your phone is OFF (not in talk mode).
Press the MUTE/PROG button to go to the main menu.
Press CID/VOL (up or down) button to scroll to "HANDSET SETUP".
Press MUTE/PROG button to confirm.
Press CID/VOL (up or down) button to scroll to "RINGER VOLUME".
Press MUTE/PROG button to enter the menu. "SET RINGER 1HI 2LOW 3OFF" shows in the display.
Use the touch tone pad on the handset to select 1, 2 or 3, or use the CID/VOL (up or down) button to scroll to your selection. HI is the default setting.
Press the MUTE/PROG button to save your selection. You will hear a confirmation tone and the new volume setting shows in the display.
To change the receiver volume: When the handset is ON (in talk mode) you may adjust the receiver volume by pressing the CID/VOL (up or down) button.
If you need a manual, you can download one here.
Oct 06, 2011 | GE 21028GE3 Cordless Phone
I want to change the nombers of the rings to get start the answering machin
These are the instructions from the manual, which I found here:
http://safemanuals.com/user-guide-instructions-owner-manual/GE/21028GE3-A-_E
RING SELECT (FOR ANSWERING MACHINE)
This feature lets you select the number of times you want to phone to ring
before the answering system answers a call.
1. Make sure your phone is OFF (not in talk mode).
2. Press the MUTE/PROG button to go to the main menu.
3. Press CID/VOL (up or down) button to scroll to HANDSET SETUP.
4. Press MUTE/PROG button to confirm.
5. Press the CID/VOL (up or down) button to scroll to the RING SELECT menu.
6. Press MUTE/PROG button to enter the menu. RING SELECT 3 4 5 6 TS shows in the display.
7. Use the CID/VOL (up or down) button to scroll to the your selection. The default setting is 5.
8. Press the MUTE/PROG button to confirm. You will hear a confirmation tone and the new setting shows in the display.
NOTE: If you select Toll Saver (TS) the unit answers after the 3rd ring if there
are NEW messages, OR the unit answers after the 5th ring if there are NO new
messages. This allows user to access their answerer from another location and
then hang up after 4 rings to save long distance charges.
Oct 13, 2010 | GE 21028GE3 Cordless Phone
My radio is stuck on mute. How do I turn the mute
Where is the mute button on an RFX9500?
May 04, 2010 | Phase Linear UCD200
I can`t hear anyone, mute is stuck on my razor phone
i dont think is the mute its probably the earpiece
you could find most of the parts in ebay.com
Mar 26, 2010 | Motorola Mobility FOR MOTOROLA RAZR RAZOR...
How do i get mute off my phone
Well that would be hard to believe you can't get mute off since you have to personally initiate mute while during a call and the mute would be disable after you hang up. The mute button is located on the left side below the screen. Now here is what you might want to look at. Make sure TTY mode is off, this option would put your phone in permanent mute. Go to settings then to call settings, TTY mode should be off. If this still doesn't work and your phone displays "car kit" on the main screen then your phone is probably water damage or needs repair.
Jul 13, 2009 | LG VX8350 Cellular Phone
Cannot program, menu stuck on Spanish, cannot access main menu from mute/ok button
I know this should be a MUCH more techie answer, but have you tried just asking a nearby Mexican to help you? Just a thought.....
You say you cannot get to the menu from the mute/ok button?
What happens instead?
FROM DA BOOOK looks pretty clear to me.
Handset Setup
1. Make sure your phone is OFF (not in TALK mode).
2. Press the mute/menu OK button to go to the main menu.
3. Press CALLER ID-VOLUME ( 6 or 5) button to scroll to HANDSET SETUP.
4. Press mute/menu OK button to confirm and you may program the following items: Language, Handset Name, Ringer Tone, Ringer Volume, VIP Melody, Key Tone, Set Day/Time, Equalizer, Area Code, Tone/Pulse, Registration, Deregistration and Default Setting.
NOTE: During programming, you may press the END/cancel button at any time to exit the sub-menu and return to the menu.
Language
From the Handset Setup Menu:
1. Press the CALLER ID-VOLUME ( 6 or 5) button to scroll to the SET LANGUAGE sub-menu.
2. Press mute/menu OK button to enter the menu. SET LANGUAGE 1ENG 2FRA 3ESP shows in the display.
3. Use the touch tone pad on the handset to select 1ENG, 2FRA, 3ESP, or use the CALLER ID-VOLUME ( 6 or 5) button to scroll to the desired language. English is the default setting.
4. Press the mute/menu OK button to save your selection. You will hear a confirmation tone and the selected language shows in the display.
Apr 29, 2009 | Uniden Cordless Phone
Cannot get my 925 to work on my computer as an audio unit for use with Skype. Cannot find a driver that will work on VISTA 32bit
Have you placed the 925 into discovery mode?  It will be flashing red and blue rapidly if you did.  Here's how to do it: Turn the headset off by holding the main button down until a red light comes on Turn it back on by holding that same button and keep holding it after you see the blue light come on.  Eventually it will start flashing red and blue.  This is now in pairing mode.  Set your computer (if it is bluetooth enabled) to find all bluetooth devices.  It should be listed as Plantronics 9xx.  If you need a passcode it's 0000.
Apr 20, 2009 | Plantronics Discovery 925 Bluetooth...
When I get calls, I cant hear anything out of my phone unless it is on speakerphone, but the person on the other end can hear me perfectly. This has happened in three different Venus' that I have had...
did you change your earpiece setting on the my settings menu, it's under Sound settings. you can change it to low to high. And when you answer the phone, you traditionally answer it the portrait way?
Mar 06, 2009 | Verizon Communications Samsung Alias Cell...
925 Plantronics will not pair with cell phone.
You are holding down the main button too long.  When it flashes blue and red it is now in pairing mode.  To turn on the headset hold down the main button until you see the blue light come on, then let go.  If you hold it any longer this is when it goes into pairing mode.
Feb 24, 2009 | Plantronics Discovery 925 Bluetooth...
Plantronics Discovery 925 Bluetooth Headset Logo
218 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
skiffy99
skiffy99
Level 1 Expert
shaun taylor
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
