Question about Marantz SR-585 Receiver
My Marantz SR-585 Receiver is not processing digital sound - neither through optical nor through coaxial cables. analogue sound is ok.
Duncan
  • 218 Answers
SOURCE: Marantz SR 7200
Sounds like it is zapped (fried outputs). Time for a trip to the repair shop. Good luck.
Posted on Jan 29, 2007
SOURCE: marantz sr 66u receiver
KAKO SI MIMI
Posted on Dec 19, 2008
killer_clown
  • 86 Answers
SOURCE: NO POWER - MARANTZ SR-5000
you mite not have to reset it, try checking ur fuses, it could of triped the cicrut when the power went out, normaly thats what happens unless it was a direct contact then, u mite wanna go get a nother receiver, and what i mean by direct contact, i mean like directly pluged into the wall
hope that helps
Posted on Feb 13, 2009
It is likely that the PA stage has developed an offset voltage in the output stage. The faulty amplifier channel can be found by progressively disconnecting the collectors of the of the power transistors until the protection fault disappears. Once the faulty channel is found the the cause of the offset has to be traced to the faulty transistor or resistor. Don't forget that if you can smell smoke or burning then there are likely to be components(esp transistors) that have been damaged by the fault.
I had a Luxman unit that destroyed 5 transistors in the output stage that was due to an open .5W resistor in the driver stage.
Good luck.
Posted on Mar 29, 2009
  • 6 Answers
SOURCE: Kenwood vr-405 receiver
I have the 405 as well. My TV has an optical out and I run that straight to the 405 optical input. I set the input selector to DVD/CD (not DVD)and presto! TV audio out my speakers. It all comes down to the audio connections on your TV.
Posted on Jan 10, 2010
How to output sound to a 2nd device
If you need an analogue output, you can tap stereo analogue audio by using one of the two sets of "pre-out" RCA jacks on the back of your receiver. These provide "headphone like" output power, and will not overload any analogue input connected to it EXCEPT MIC and PHONO inputs on the 2nd device. If it's digital audio output you need, there's an HDMI monitor out, that will provide digital audio to another HDMI input equipped device. You'll have to get a relatively cheap adaptor if you need this digital audio output in another digital format/connection (like the popular S/PDIF optical or coaxial).
Jun 11, 2014 | Marantz NR-1604 7.1 channel HT receiver...
How do we connect our system using a Shaw PVR
Do you have a optical/coaxial input on your system? Eg: cable, TV.I use a optical input on my Yamaha ( cable, satellite ). Look to see if there is a optical/coaxial output on your pvr, there should be. Use ether the optical or coaxial output from your pvr and connect it to the cable (satellite ) optical/coaxial input on your receiver. The manual that came with your Shaw PVR should explain how. You will get 5.1 surround if available on certain channels.I prefer optical over coaxial myself, but they both work well.If you don't have optical/coaxial inputs on your receiver, you will have to use RCA cables, analogue out on cable box, to tape input or aux on your receiver. You will not get surround sound, just stereo. But it's better than nothing.
Jan 18, 2013 | Onkyo Ht-rc330 5.1-channel Home Theater...
I bought a second hand marantz receiver. my problem is when i push the cd button the display read like this: CD/DIG2/STEREO/NO DATA and the it will go back by it self to CD/DIG. what should i do? please...
the receiver is ok. it is telling you that CD is assigned to digital #2 input, surround mode is stereo and there is no input signal. You need to connect a source to digital2 input (coaxial or optical) and you'll get sound from it.
Jun 01, 2012 | Marantz SR-7000 Receiver
Pcm is flashing and no sound out of our receiver
If you have the PCM display flashing ,it means it has lost the PCM link with what ever equipment you have connected to this receiver. The light should be steady if all is OK. Try replacing the optical / coaxial cable.
Mar 11, 2011 | Marantz SR-19 Receiver
No audio produce in optical connection
Typically when you use the optical connector from a DVD player there are several steps to getting everything ready to hear sound.
First: The Marantz Receiver will have a setup menu option for changing the DVD player to "optical" or it will say "digital" input. Once this is done, you should immediately get Sound.
Secondly, the DVD player (may) have an option to be switched to a digital output through the optical port. You would be able to find this out with it's user manual.
I really hope this helps,
Best Regards,
Mark
Jan 24, 2011 | Marantz SR-4400 Receiver
Input signals Marantz SR4003
There are four digital connectors on the back of the unit: 2 optical and 2 coaxial. They are marked a s 1 2 3 4. 1 and 2 are optical, 3 and 4 - coaxial. Also you have front optical connector marked as F.
You can connect 5 digital sources to your receiver. For example, connect your DVD to input 2 (optical) by optical cable and connect your DSS to input 3 by coaxial cable. Assign DVD to digital 2 and DSS to digital 3 in input setup menu.
Aug 14, 2009 | Marantz SR5001
I like the look and price of the Marantz SR 6003 receiver, my only question being whether it suppports DSD data output from a SACD player like the ONKYO like the OPPO DV-980h. In other words can it receive...
Downloaded the user manual for the Marantz SR 6003 A/V Receiver. In this it stated that if a SACD player was connected to the SR 6003 with an HDMI interface earlier than 1.2 then the digital data from the SACD could not be transferred over the HDMI cable to the SR 6003. This implies, but does not confirm, that if a SACD player does provide a digital output on an HDMI 1.3 interface, then SACD audio data can be transmitted to the SR 6003 and, presumably, decoded and converted to 6 analogue streams which are then amplified and deleivered to the (6) analogue output terminals.
I'm fairly sure that the native DSD data from the SACD has to be converted to PCM before transmission over the HDMI interface which is better than nothing. What I was hoping for though was for the data to be transferred in DSD and converted in the SR 6003 directly to analogue, avoiding two intermediate conversions. This ideal solution can be done by only a few SACD/ A/V Receiver combinations, which is silly considering that it is also the simplest. One example, which has made a big impression amongst high fi enthusiasts, is the OPPO DV-980H Universal DVD player (plays any audio or video disc and costs almost nothing) and the Integra DTC 9.8 home theatre processor.
Jan 14, 2009 | Televison & Video
Marantz SR7500 Home receiver, Digital CD will not play
Verify that the digital output is enabled. This is a switchable output. A brown-out or other power isseu may have shut it down.
Get back to us if that is not the case.
Dan
Mar 20, 2008 | Marantz SR-7200 Receiver
Playstation 3
I assume that the Marantz has an Optical lead input. If so you should connect an digital optical lead directly between the PS3 and the Marantz receiver for the sound while keeping the HDMI lead to the projector for the picture. You will need to configure the PS3 to be outputting the sound to the optical output (done through the settings menu).
Jan 08, 2008 | Marantz SR-5200 Receiver
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
