Question about Toshiba Satellite L455D-S5976 Notebook
2green power lights on front but laptop will not start up
    Brigadier General:
  • 8,909 Answers
Toshiba boot problems
L45* series laptops are very good normally but don't boot up if there is a device in the USB slot or a CD/DVD in the drive.
If it still refuses to POST, remove the AC Adapter, remove the battery and remove the hard drive.
Power the unit up without the hard drive and it should complete POST and complain that there is no hard drive. If that doesn't work remove AC adapter, ensure battery is disconnected and remove hard drive and RAM. Try again. If it still doesn't work, you have a mother board fault and it needs a service centre. www.Toshiba.com will help you out.
If it does work at one of the options, when you have closed the laptop down, replace the RAM first and test, then the Hard Drive.
Hope this fixes your problem.
Posted on Jan 03, 2011
IA THIS RVICE FREE I HAVE BEEN UNEMPLOYD FOR 2 YEARS AND IHAVE RIEND THAT I THNK AN D TEWORK IF I CAN DETERMINE THE PROBLEM
Sounds like the power supply capacitors have failed. If you can't replace capacitors on a circuit board on your own, it's time to take in to a repair shop.
Dec 08, 2014 | Samsung HL56A650 56 in. TV
Burner lites then drops out
Clean the remote sensor with light sandpaper or a dollar bill.
Dec 16, 2013 | Ruud UBHC Air Conditioner
Hi, I am installing a newer stereo into my 87 volvo 240dl wagon... Having trouble with a couple wires as to where they attach.
Red is for constant power, yellow is for ignition power, blue is for an electric antenna, black is ground. The others are for the speakers. - 2blue, 2green, 2purples, 2whites. If you don't have an electric antenna , don't use the wire. Also if you extra wires for the vehicle this is common. don't use them. Hope this helps. Randy
Aug 26, 2011 | 1987 Volvo 240
Hi my zanussi zwf1432s stopped halfway through washing green light on start/pause button flashs wont do nothing else all lights will change when cyle chosen but will not start justs beeps then back to...
Hello Paula,
Do not know how many flashes but 1green/1red = 11 water pressure low.
2green/1red = 21 blocked filter or pump fault.
You would be best firstly checking the filter and make sure it is clean and pump turns.with water drained and filter out shine torch into filter put on spin/drain and see if pump blade spins if not then try and turn with long screwdriver to free out any debris then refit filter and check for leaks and try donnt fill fully until you are happy it can drain water.
Hope I was of some help.
Good Luck
Apr 22, 2010 | Zanussi ZWF1430W Front Load Washer
I have no picture or sound when i hit the power button it clicks off
Please do the self check this set has:
When the power light comes on and goes out press and hold both the MENU and Input (also called Device) buttons at the same time for at least 5 seconds and then release both buttons.
The power light will blink a two digit error code--for example--2 blinks, a pause and 2 blinks.
Let me know what error code you find and I will tell you what it means and what may actually be the problem.
I am here to help people.
If this information has helped you rate this solution as I do this here for free.
SD TECH
Dec 18, 2009 | Mitsubishi WS-55807 TV
C500 Laptop won't come on power button just flashes
Have you tried attaching an external monitor when the LCD screen is disconnected from the motherboard? this connector is located under the keyboard strip – a piece of plastic just above the keyboard.
If it works, this way, then the video cable isn’t seated properly in the connector on the back of the screen. Plugging the video cable back in should fix the problem.
I don’t know how comfortable you are with taking apart laptops but I think that this information could be useful for you.
Source: http://www.asklaptopfreak.com/laptop-notebook-help/2006/08/08/laptop-powers-on-and-shuts-off-immediately/
Sep 28, 2009 | Compaq Computers & Internet
Have Clarion DB148R cd car stereo but no wiring diagram
matching colors are the speakers, red it the accesory, needs to be hooked up to an alternating current, something that works with the ignitions, this will turn the sterio on and off, yellow is 12 volt or memory, constant power, blue is a remote wire for an amp. black is a ground wire and orange is normally an illumination wire, so when you dim your dash lights your stereo also dims.
Sep 04, 2009 | Clarion DB148R CD Player
No picture no sound. All three lights blinking.
Very common for new electronics to have power supply failures. The resistors are built cheaper and tend to fail quickly
Aug 25, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Toshiba Satellite L455D-S5976 Notebook Logo
219 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
