Question about Toro Snow Blower Scraper For S200 s620 New 233170 ()
Toro S-200 not throwing very far or high. What parts do I need to repair this problem?
Toro ccr3600
it sounds like it is not running high enough has to run pretty high on the rpm so it can throw it out the chute unless your rubber or steel blades are worn
Jan 05, 2014 | Toro Garden
Toro ccr powerliteE 3hp runs but only half speed
need to take the bowl off carb and take water out of it nine did the same thing
Dec 31, 2013 | Garden
Toro 200-43 name sr-21s serial # 200012530 pulls hard to start but won't start pulled spark plug still pulls hard and no spark
Sounds like the engine stop cable has stretched or broken and is not releasing the engine brake. This cable also disengages the kill switch to the ignition module. Follow the cable from the upper handle down to the side of the engine and watch how far it will move the brake lever. If it is less than 3/4 of an inch, the cable will need to be replaced.
Sep 06, 2010 | Toro Lawn Mower With Toro Power Tools
Auto focus button was pushed a few times and now our Apex TV won't focus at all.
likely a convergence failure. if you push the button over and over, sometimes it will throw the set out so far that it cannot align anymore.. the sensors need to see the lines to do the auto alignment. you probably need new convergence ICs, repair is tricky and requires soldering. estimate = 200-350 $
May 26, 2010 | Apex Digital GB4308 43" Rear Projection...
Toro S200 doesn't blow to the side as far as it did
It's possible your auger may be worn, and it is not moving / propelling enough snow to make up the difference to blow the snow at the angled setting. It may throw the snow forward better due to less resistance, rather than the snow having to propel around an angle / curve. Just a thought for now.
Jan 20, 2010 | Agri-Fab Agri - Fab Snow Blower - 42"
After a couple of hours of use last week, the motor started slowing down. Turned it off and it would not restart. tried again after an hour and it started but sounded really rough. stopped it and took it...
sounds like the motor is worn out. Toro does not sell the motor separate. It is considered a throw away unit.
You will have to purchase a new one.
Sorry.
Good Day.
Nov 05, 2009 | Toro Electric Ultra Blower/Vac 12 Amp
NEED MANUAL FOR TORO WHEEL HORSE GARDEN TRACTOR 416-8
As far as I understand, fixya.com does not stock or sell this mataerial. The purpose of this site is to get direction on a course of action to follow ...
Here is my suggestion ... if you have looked in the manuals section of fixya.com and not found what you are looking for, visit the manufacturers web site which is probably www.toro.com/wheelhorse or something very similar ... Google it to find it ... or you could search www.archive.org
Thanks for using fixya.com
If this helps you, positive comments are appreciated
a
Oct 26, 2009 | Garden
Very little grass is shooting into the bag to fill it
Hello monica_skinn:
If the Underside of the Deck is Clean and the Blades are Tightened Properly, then the Problem is Caused by the Blade Lifts being Worn or the Blades are Not a High Lift (Bagger Blade) Blades.
A Bagger Blade has a Very High Lift Ear on the Backside of the Blade Across from the Cutting Edge. This Extra Lift is What Gives the Extra Lift and Throw (by increasing air Flow under the Mower) the Grass gets to be Bagged.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 11, 2009 | Toro Lawn Mower With Toro Power Tools
Will not throw snow
I have a toro 421 snowblower won't start after had it fixed from shop and how to operator to starter?
Jan 15, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Snow Blower Scraper For S200 s620 New 233170 () Logo
146 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
