Goodman CAPF4860C6AA Heater worked this morning. Now not working at all. Trying to find out where the pilot light is so that I can see if it has gone out.
5 Suggested Answers
SOURCE: Vulcan freeloader hot water heater
Could be moisture in the gas supply line - get your gas fitter to purge the line at the meter.
Posted on Aug 03, 2008
Therinnaiguy
  • 1420 Answers
SOURCE: Blower works but no heat
If in fact you have the above listed furnace, you do not have a pilot but electronic ignition. You will need to remove the front cover on the furnace, tape down the door safety switch and then have someone help you by turning up your thermostat to a very high setting. Watch and listen inside the furnace. There should be some blinking going on at the control board followed by a small blower fan starting up. Then after 10-15 seconds there should be a click followed by an orange glow viewed thru the viewing window to the burner section. In a few seconds the gas valve should click and the burners will ignite. There is a safety switch that will sense flame and then keep the gas going to the burners. If it does not sense it, it will shut it off within 10 seconds. If all is well so far, your blower will turn on in about 90 seconds after flame. There is a diagnostic code chart on the back side of the access door if you get an error code (blinking) on the control board.
Always check little things like air filter, condensate drain and broken or loose wires.
Posted on Nov 11, 2008
  • 189 Answers
SOURCE: Goodman ez 1425 blower works but no heat
It has electronic ignition. no pilot light.. it uses a hot surface ignitor to light the burners. this device gets red hot (just like looking down into your electric toaster). this hot cherry red device lights your burners
Posted on Mar 28, 2009
co7196
  • 3433 Answers
SOURCE: pilot light not working in gas heater
That probe that sits in the pilot flame is at fault. Remove and replace. Inexpensive fix. Make sure probe is in the tip of the pilot flame. If it does not stay hot enough, it will shut off the gas.
Posted on Jun 01, 2009
Goodman CApf4860c6aa heat cuts off
There is a small silver rod situated in the flame at the last burner. This rod tells the board the flames are lit. Clean it in place with a piece of sandpaper or emory cloth and see if that doesnt solve your problem
Nov 21, 2017 | Heating & Cooling
Goodman gmt070-4a wont heat, like the pilot light is out or something
turn gas supply on....turn gas valve to pilot....press down and hold to allow gas to come through pilot tubing.....light the pilot right by the thermal couple, once lit hold valve down for about 60-90 secs...then release ur hand on the gas valve and turn the valve to on position............make sure the bloody tstat is turned off before doin anything other wise burners will fire up soon as you turn valve to on position
Dec 05, 2013 | Goodman GMS90703BXA Heater
How do you light the furnace of a goodman ez 1625
We have not lit pilot lights ourselves since 1978 when they outlawed standing pilots in Ca for furnaces. We have electronic ignitions of spark oror hot surface ignition, neither of which can be manually lit.
Do you get any fan action if you flip the fan on from auto?if so, you have power and 24v control power too, I would start there.
Oct 31, 2012 | Goodman Heating & Cooling
NO GAS FLAME
First, is the PILOT burning? If so, is the heater Control Knob turned from PILOT to the ON position? If you have any other gas appliances in the home are they working? If they're not, your gas has been turned off. Contact your gas provider.
If the other gas appliances are working and you answered No to the first two questions, you will need to relight the pilot. After the pilot lights and holds for 1 minute, turn the Control Knob to the ON Position. Turn the thermostat up and the burner(s) should light.
Mar 09, 2011 | Goodman GMS80905CNA Ceramic / Coil...
How do I access pilot to turn on heater?
A GMS Goodman furnace does not have a pilot light. It is electronic ignition.
Nov 29, 2010 | Goodman GMS90703BXA Heater
I have a 1987 Goodman, (GU150-5 REV S) model gas furnace. The problem I have is keeping the pilot light on. I replace the thermal coupling twice, work for a few days and goes out again. Please tell me what...
If you have a weak pilot flame it could cause this. There is an adjustment screw for the pilot flame under another philips head screw that takes a small flat head screwdriver to adjust. Turning the pilot flame up may help.
Dec 21, 2009 | Goodman GMS90703BXA Heater
Finding Pilot light on Goodman Model caf024a2a. Cannot seem to find the pilot light...The blower works but no heat.
i think the ca # is for the cooling coil unit - the heater should start with gmXXXXX - if your unit is fairly new - the pilot light electronically when thermostat calls for heat the unit will not light if the burner door is open
Oct 24, 2009 | Goodman Heating & Cooling
Goodman CAPF4860C6AA not cooling properly
It sounds like it needs to be charged. What you need to do is shut the system down for 24 hours in order to let the unit thaw. Then if you are not EPA certified, you need to have a repair tech come out and charge your system. That should be it unless you have a leak in the lines.
Jun 21, 2009 | Goodman GMS90703BXA Heater
My goodman cental heat & air unit quit working last night
check to i see if there power to condenser. check to see if there 24 volts to condenser.checkt the disconnect box for power located out side by the condeser you should have 220volts at that box. check to see if your stat is set on cool.
Jun 20, 2009 | Goodman Heating & Cooling
Feb 21, 2009 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
108 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
