Question about Epson Stylus Photo R200 InkJet Printer
Hi, When printing photos, my photos have horizontal light coloured lines across them. When I print the nozzle check pattern all colours match the guide with the exception of the light magenta. There are no gaps in the light magenta pattern, but the diagonal lines are not straight. When I print the colour alignment pattern, there are blank horizontal lines across the pattern. Head cleaning seems to have no effect. Please advise. Thanks, Mark
  • 2,509 Answers
Epsons are notorious for this sort of problem, especially in used infrequently as ink residue dries on the print head; try using a cleaning cartridge, or swab around relevant print head with cotton bud and ethanol/isopropyl alcohol. Here are examples of cleaning carts, there are others http://www.internet-ink.co.uk/epson-cleaning-cartridges/ http://www.icompinkcartridges.co.uk/epson-r200-r300-r220-r320-r340-cleaning-kit.html
Posted on Jan 03, 2011
  • Epson Master
  • 511 Answers
Based on my experience, there are two possible causes.One, dried waste ink at the bottom plate of the head,especially around the output of light magenta, so that the inkspray distorted. Two, the film coating on the output of light magenta is damaged. If what happens is that the second possibility, can not be repaired. it is usually due to headscratch paper during printing. If you have experience apart pairs of heads, please loose head and checked whether there are scratches on the head output.
Why is my dell 926 printer is blacking everything out
The print head nozzles may be clogged. From the Utility section found in the printer driver, clean the print heads by performing a head cleaning followed by printing a nozzle check pattern. A head cleaning and nozzle check must be performed as a cycle. After printing a nozzle check, examine the printed dot pattern. Each staggered horizontal and straight vertical line should be complete, with no gaps in the dot pattern. If there are gaps in the dot pattern, continue with another cycle. Performing up to 6 cleaning cycles is not uncommon if the print heads are severly clogged.
Now you will be able to print in colour.
Hope this helps.
Shane
Dec 21, 2011 | Dell 962 Photo All-In-One InkJet Printer
Printer is blacking everything out
Hope this helps.
Shane
Dec 21, 2011 | Dell 926 All-In-One InkJet Printer
My printer is blacking everything out
Hope this helps.
Shane
Dec 21, 2011 | Office Equipment & Supplies
I have a Canon Pixma MP270 and I can only print in colour both the black and colour lights are lit up on the printer
f print quality does not improve by the standard cleaning of the Print Head, clean the Print Head deeply. Cleaning the Print Head deeply consumes more ink than the standard cleaning of the Print Head, so clean the Print Head deeply only when necessary.
1. Make sure that the power is turned on.
2. Clean the Print Head deeply. (1) Press the g0022565.png (Maintenance) button repeatedly until y appears. g0054776.png
(2) Press the Black or Color button.
The machine starts cleaning the Print Head deeply. Do not perform any other operations until the machine completes the deep cleaning of the Print Head. This takes about 2 minutes.
3. Check the print head condition.
When the deep cleaning is completed, the LED returns to the copy standby mode. To check the print head condition, print the nozzle check pattern.
See " Printing the Nozzle Check Pattern".
If the problem is not resolved, turn off the power and clean the Print Head deeply again after 24 hours.
If the problem is still not resolved, replace the FINE Cartridge with a new one.
See " Replacing FINE Cartridges".
If the problem is still not resolved after replacing the FINE Cartridge, contact the service center.
Print the nozzle check pattern to determine whether the ink ejects properly from the print head nozzles.
NOTE If the remaining ink level is low, the nozzle check pattern will not be printed correctly. Replace the FINE Cartridge whose ink is low.
You need to prepare: a sheet of A4 or Letter-sized plain paper
2. Load a sheet of A4 or Letter-sized plain paper in the Rear Tray.
3. Open the Paper Output Tray gently, and open the Output Tray Extension.
4. Print the nozzle check pattern.
(1) Press the g0020617.png (Maintenance) button repeatedly until A appears. g0054754.png
The nozzle check pattern will be printed.
5. Examine the nozzle check pattern.
See Examining the Nozzle Check Pattern.
Examine the nozzle check pattern, and clean the Print Head if necessary.
1. Check if there are missing lines in the pattern (1) or horizontal white streaks in the pattern (2). g0054755.png (1) Check if lines are missing in this pattern. If yes, the cleaning is required.
See " Cleaning the Print Head".
(A) Good
(B) Bad (lines are missing)
(2) Check if horizontal white streaks are present in this pattern. If yes, the cleaning is required.
(A) Good
(B) Bad (horizontal white streaks are present)
Post back!
Oct 26, 2010 | Canon Office Equipment & Supplies
Canon i550 not printing any color, Prints in black OK but no color.
Please check nozzle head pattern first. Is your print head pattern printed perfectly?. Be sure that the print head pattern is ok. No missing line or column. If your nozzle colour is not printed at all even just one point,check the print head or try to clean the print head.
e-manualshop
PrinterClinic
Jan 03, 2010 | Canon i850 InkJet Photo Printer
Epson stylus photo R2400
I had this trouble, went through cleaning & realignment, then various print options. What i found was that dark colours had faint dark horizontal lines 5mm apart when printing on Photo in the epson driver. Changing it to Best Photo solved it.
Jul 31, 2008 | Epson Stylus Photo R2400 InkJet Printer
R220 colour errors
chech the ink pan below maximum waste overflow, take the injection pump it or enject until ink finish.check ink cartidge or not fully engage the lock.
Nov 15, 2007 | Epson Stylus Photo R220 InkJet Printer
CX6600 horizontally cuts text
Change the colour of the text to print each colour The same text once in each colour- then you will know what the faulty colour is. Download this utility www.ssclg.com install it and learn to use it. Also go to www.fixyourownprinter.com and take a look At #Epson printers there
Jun 16, 2007 | Epson Stylus CX6600 All-In-One InkJet...
Colour printing
If the test patterns are not matching what your printer tells you is normal and your photos are banded horizontally, you may have clogged nozzles and printhead. Do a maintenace clean under your printers direction, and see if it now prints ok. Also, you may be low or out of one particular colour, but still have enough of the others and the printer will try to compensate by using available colours, hence colour banding and distortion. A manual clean with cotton buds and cleansing solution is recommended if the first clean does not help.
Dec 12, 2006 | Canon BubbleJet i560 InkJet Printer
Epson Stylus Photo R200 InkJet Printer Logo
750 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
