Question about NorStar Lands Phones
Inactive feature message displayed when we try to access any features on our M7310 phones. This occurred after a power outage.
  • 1 more comment
  • smhowland Jul 09, 2008
    all phones work on all three lines for both incoming and outgoing calls. We have just lost all features, so have no ability to program or record greetings etc.
    when we press features key and code (e.g. 983) nothing happens but the display of feature 983 or 981 then after a couple of seconds the message feature inactive. phone then returns to normal display.
    Any help on this "feature inactive" problem?
    Scholar:
  • 135 Answers
Dear customer..here is the solution
Sometimes when you put a new (or alternate) voicemail system on a Norstar switch, The feature codes that accessed the old system stay in the KSU memory. If this is the case all of your feature codes will appear inactive even if the voicemail system is operating correctly.
To fix this issue you need to run an External Feature test (XFtest) to identify and remove the leftover codes from your KSU memory. You must have a programming set to access this menu (M7310, M7324, T7316).
Power down the Voicemail unit. Remove connection to voicemail ports from KSU.
1. Press [Feature] **938378 (XFtest). The password will be 266344 (Config).
2. Your display will read Feat code: and you will have options First and Exit.
3. Press First. The first stored feature code will appear, and you will have options Test, Back, and Next.
4. Press Test. Your options will read Remove and OK. Press Remove.
5. Once the feature code is removed, press Next to go to the next code.
6. Do this with all codes until your display reads None Registered
7. Release
Restore connections to the voicemail ports from the KSU. Power the system back up.
The feature codes will be restored to the correct defaults with the completion of the voicemail power-up cycle.
thank u
Posted on Jul 09, 2008
  • jessica schuster Aug 28, 2012
    The feature codes did not restore to the defaults still reads none registered. They still come up inactive feature.
    The feature codes did not restore to the correct defaults when the voice mail completed the power up cycle. They still show none registered and they still read inactive feature. please advise
  • 4,472 Answers
Have you tested the phone, and tested the power supply through the phones menu?this is what the book says about inactive feature code.
Inactive Feature-
You have entered a feature code that is used
by an application program that your system
does not have.
Keep me updated.
Thanks,
Lee
  • 2 more comments
  • Lee A.
    Lee A. Jul 09, 2008
    Do you have the manual for the phones? In the manual there are several tests you can run on the phone to make sure they are working properly.
    Let me know.
    Thanks,
    Lee
  • Lee A.
    Lee A. Jul 09, 2008
    are these features that are programmed onto the CAP module buttons?
    Thanks,
    Lee
  • Lee A.
    Lee A. Jul 09, 2008
    Sounds like the power outage might have wiped them out do you know how to reprogram the features?
    Thanks,
    Lee
  • Lee A.
    Lee A. Jul 10, 2008
    Have you ran the external features test?
    Thanks,
    Lee
    Guru:
  • 1,894 Answers
Do you mean that the options are grayed out with out any access??
  • 19,396 Answers
Check that there is line in phone cable
  • Ginko
    Ginko Jul 09, 2008
    If the feature codes show as inactive, this means that the phone system is not getting the voice mail. Check that connections are ok, check that voicemail is working. Contact service provider if you have problem with voicemail.
    Champion:
  • 217 Answers
If you go into your phone options, you'll want to do a "master reset". This will restore your phone to its original state. All of your features will be restored as well.
I have a Nortel Norstar M73110 and I can't access the main greeting/main system control (Feature 983 stuff). Is there a way I can reset this password, or even hard reset the system?
Norstar M7310 features inactive
All features are inactive. I have done the following: 1. Press [Feature] **938378 (XFtest). The password will be 266344 (Config). 2. Your display will read Feat code: and you will have options First and Exit. 3. Press First. The first stored feature code will appear, and you will have options Test, Back, and Next. 4. Press Test. Your options will read Remove and OK. Press Remove. 5. Once the feature code is removed, press Next to go to the next code. 6. Do this with all codes until your display reads None Registered 7. Release Next I am told to Restore connections to the voicemail ports from the KSU. Power the system back up. But I do not know how to do this. Please advise. Thank you!
Oct 04, 2017 | NorStar Lands Phones
Locked out of Nortel t7316 every time you press feature and #983 or 985 it displays inactive feature.
F983 and F985 are voice mail access feature codes. Try rebooting your voice mail system to see if the unit recovers. There is no switch so you will need to unplug the power to the VMS to reboot.
Jun 29, 2015 | Nortel Lands Phones
Our voicemail system is inactive but my phone says I have a MSG, how do I clear that?
You can have a (sort of text) message from one set to another without voicemail. Voicemail uses that mechanism to tell you you have a message. Feature 1 is Send message, Feature 65 is View Message, or press the soft key under the MSG display. After viewing it, another soft key should say ERASE.
Mar 04, 2014 | NorStar M7310 Corded Phone
Norstar M7310 all features inactive
I have been asked to advise, but sadly I am totally ignorant of the product,or its likely method of operation.
I wish you well, and I'm sorry that I cannot help or assist.
robert
Mar 29, 2017 | Nortel Norstar Meridian Phone System With...
How to reactive feature 983 on M7310
reset the password read your owner manual, and proceed with the steps they recommend., Use the section troubleshooting and fix it.
God bless you
Sep 20, 2012 | NorStar M7310 Corded Phone
I have M7310 phones with the complete system I can not seem to be able to activate our mail box system, we tried entering f:981 and F:983 however it says feature inactive
If none of the voice mail feature codes work (feature 980-989) then the voice mail system is either not working or isn't recognized by the telephone system.Go to your communications closet and check to see if theres a power light on in the voicemail.If not then you might want to call in your tele system service provider.
Jan 15, 2010 | NorStar Meridian M7310 Phone
Inactive features
Is the phone system working but the voicemail did not come back up ? Can you tell me what kind of voicemail you have, ist should be marked on the voicemail system ?
Aug 01, 2008 | Lands Phones
Inactive Feature
The system lost programming. Call a vendor in...
May 07, 2008 | NorStar M7310 Corded Phone
Lands Phones Logo
1,797 people viewed this question
Top NorStar Lands Phones Experts
Oloyede Monsuru
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
