Question about Phonic - XP 5000 - 5000 Watt Power Amplifier Amplifier
XP5000 amber LED's are not switching off after powering up.
  • 4,234 Answers
This is an indication that the startup checks have failed. This usually occurs when the outputs are bad. Without seeing the unit and taking internal measurements, I can't really give you more specifics. I'd bring this to a service shop for a repair estimate. Report the results here and we should be able to walk you through the actual repair.
Dan
Posted on Jan 03, 2011
Amber light on then a while turns green but wont boot
1) Switch the system on. Can you tell me if the power button is flashing amber or a solid amber? Please also tell me if you notice any diagnostics LEDs staying lit - these are labelled 1,2,3 and 4 and are near the front headphone sockets
2) Please remove all peripherals at the back of the system and switch the system on. Does this affect the power button LED or diagnostic LEDs
3) Have you added any components to the system e.g. video cards, sound cards etc...
4) Please open the system and remove the following components:
a) Power and data cables from hard drives and optical drivesb) Any PCI/PCI-Express expansion cardsc) All memory from the systemd) The system fan
5) With the above removed, please reconnect the power cord to the back of the system and switch the system on. Please make a note of what happens with the power button LED and the diagnostic LEDs
6) If there are no changes to the power button LED or diagnostic LEDs, please remove the power cord from the back of the system and remove the following components:
a) I/O panel cableb) CMOS battery
7) With the I/O panel cable and CMOS battery removed, please connect the power cord to the back of the system. The system should automatically try to switch on. Do you hear any beeps from the system? If so, can you tell us exactly what you hear?
If you need any assistance with removing these components, please see the User Manual here: http://support.euro.dell.com/support/edocs/systems/op380/en/index.htm
Please keep us updated on how you get on!
May 21, 2014 | Dell OptiPlex 380 MT Desktop Computer...
Cooper 9534SG-K master dimmer amber LED goes out when lightsbturned off
Any switch with a light in it needs power to the switch along with neutral
May 07, 2014 | Cooper Wiring Devices Aspire Smart Dimmer...
I have a motorola AP-300 which keeps on blinking amber light when i turn it on. how can i reset it or what's wrong with the AP?
From the installation guide for this AP, I find the following:
LED Indicators
The unit has LED activity indicators on the front of the case provide a status display indicating error conditions, transmission, and network activity for the 802.11a (amber) radio or the 802.11b/g (green) radio.
802.11a Activity LED Amber
The amber LED flashes three times per second until firmware is loaded. During boot, 802.11a mobiles cannot associate. After adoption, the amber LED is steady or flashes with 802.11a radio traffic.
The amber LED flashes once per second if an error prevents the 802.11a radio from operating normally.
802.11b/g Activity LED Green
The green LED flashes three times per second until firmware is loaded. During boot, 802.11b/g mobiles cannot associate. After adoption, the green LED is steady or flashes with 802.11b/g radio traffic.
The green LED flashes once per second if an error prevents the 802.11b/g radio from operating normally.
From this, it appears that the 802.11A radio is malfunctioning.
Here is the Motorola support web page for this device.
Dec 30, 2010 | Motorola AP300:802.11A/G, Internal Antenna...
Computer will not turn on
  • Blinking Amber/yellow: Initial state of LED at power up.
    Indicates system has power, but the POWER_GOOD signal is not yet active.
    If the hard drive LED is off, it is probable that the power supply needs to be replaced.
    If the hard drive LED is on, it is probable that an onboard regulator or VRM has failed.
Apr 28, 2009 | Dell Dimension 4600 PC Desktop
Phonic XP5000 problems clip ligth coming on and killing input
Don't buy a Phonic XP5000 similar to the Crown XLS5000. Probably share the same problems. I tried three XP5000 that all had the same problem.CheersRob UeberfeldtKaikohe New Zealand
Mar 18, 2009 | Phonic - XP 5100 - 5000 Watt Power...
Powers On if I plug it in, and power supply fan runs...
Think of blinking amber as the initial state of the LED. As long as the system is receiving power from a power source and can pass that power through the system board to the LED on the Control Panel it should, at least, blink amber. As a result, a blinking amber Power Button LED is a reliable indicator that the system is receiving power from a power source. This, in turn, tells us that the source and power cord are likely to be functional. The Blinking Amber LED also tells us that the power supply to system board connection is good as well as the connections between the system board, I/O Panel and Control Panel. Depending on the components installed and the condition of those components, the LED may progress past blinking amber and move to solid amber. If the LED does not progress past blinking amber it indicates that the system is not able to properly distribute power to the system components. This is discussed in the next section of the interaction.
It does not indicate that the power supply is bad. It simply indicates that, for whatever reason, one of the power supply 'rails' is not operating within its specified range or, simply, that there is a short somewhere in the system.
The LED state could be the result of a misconfigured or incorrectly installed system component. A bad drive, for example, may be shorting out one of the rails. Incorrectly installed memory can cause a blinking amber front panel power button LED.
Feb 05, 2009 | Dell PowerEdge 1800 Server
Workstation POST
Answer is C, D, E
Nov 13, 2008 | Computers & Internet
Can't find video signal
If screen says "Signal cable not connected " all the time till power led switches to Amber chances are monitor is ok and problem is with graphic card or cpu.Connect to Known working CPU and confirm that monitor is the problem.
If same problem persists on another working cpu after changing signal cable,the interface board in the monitor could be defective.
Samir
PLease rate solution and provide feedback.
Jun 09, 2008 | BenQ FP731 17" LCD Monitor
Phonic - XP 5000 - 5000 Watt Power Amplifier Amplifier Logo
94 people viewed this question
Top Phonic Audio Players & Recorders Experts
Greg Cann
Greg Cann
rhodesworks
Are you a Phonic Audio Player and Recorder Expert? Answer questions, earn points and help others
