Question about Korg Pa800 Synthesizer
The tempo not synchronize with protools and nuendo ?
  • Korg Master
  • 5,603 Answers
Search index of the manuals for MIDI sync clock or similar name. Usually you can turn this sync clock on or off.
Posted on Jan 03, 2011
How connect nuendo to PV mixer?
well you will have to look in your computer, then the program, and then find audio properties and look for the peavey ASIO driver and connect.
May 29, 2014 | Peavey 32fx USB 32 Channel Mixer
I need an activation code for pro tools 8?
When ProTools is installed on a computer it needs to be authorized to work. This has to be done via a dongle, a socalled iLok . The authorization is done by www.ilok.com. You need a dongle with the authorized registration of ProTools on your computer to make ProTools work.
regards
Mar 09, 2014 | Digidesign MBox2 Mini with Pro Tools 8 LE
I can't hear the sound from my PC when I'm using the mixer. Its hooked up to both the computer and the speakers, but when I'm recording in pro-tools 11 I can't hear any of my playback. I have to bounc
hello. Im not too familiar with Protools (mainly because its a headache right out of the box), but MY understanding is that Protools won't recognize a lot of external audio devices. (such as behringer)
however..if you are able to record and 'see' the audio there, just not hear it, there might still be a solution, & seeing as how i never used protools, it still might just work.
First of all:
if you're using the UCA-200 external usb box connected with rca cables, then my solution SHOULD work, as it is what i did to get mine to finally do the same thing.
#1) you will need to pick up (x2) RCA-1/4 jack adapters . (radioshack, about $2 each)
#2) insert a red and white rca cable in the RIGHT side of the Mixer's CD/Tape out .....the other end of the rca cables will go into the UCA-200 INPUT.
#3) with 2 more cables in the OUTPUTs of the UCA-200, put the rca-1/4 jack adapters on both cables, insert them back into the Mixer inputs 9/10 (in the analog 1/4 instrument inputs)
#4) adjust volumes accordingly, make sure channel 9/10 isn't muted, headphone volume is up, etc..
.......if that didn't do the trick, then you will need to go into the Audio Settings menu on your computer..(or protools) and change the default playback device to your mixer (probably named Generic USB or something similar)
I really hope this helps somewhat, because i remember going through the same thing & it took a looong time to find the correct awnser.
best of luck!
*also*
check for any updated drivers for your mixer! (I personally recommend you do a Google search for Asio4all drivers, they're pretty good)
if your awnser is A), i would suggest going into your computer's Audio Settings menu, and select the mixer as your default playback device.
Nov 23, 2013 | Behringer XENYX 2442FX Mixer
SEtting tempo on metronome Zoom R24
The metronome speed is controlled by the Tempo setting. The metronome controls only adjust the volume of the metronome and if the metronome is heard on the input or output recording. The R24 manual is available here: http://www.zoom.co.jp/downloads/r24/manual/ . See page 20 for setting the Tempo. The Tempo button is below the Tempo label to the left of the LCD display on the right side of the Zoom R24.
I hope this helps.
Jun 01, 2012 | Samson Technology Zoom R24 Multitrack SD...
The Simmons SD5K keeps spontaneously playing songs, even when all I want to do is play my own stuff with the metronome! I turn on the metronome, set the speed, hit the pads a few times, and the music...
Press the "click" button and then set the tempo you want, press the "click" button again this will stop the metronimoe but is also sets the tempo in memory. The next time you press the "click" button it will be ready to go.
Anytime you press the tempo + or - it thinks you are trying to use the "Tap Tempo Function".
Jun 07, 2011 | Simmons SD5K 7Piece Electronic Drum Kit
The recording level to my Mbox is very low for some reason. I am running Pro Tools LE and I have a shure 87a microphone. Every time I attempt to record a track, the input volume is incredibly low...
Make sure you turn the Phantom power on the Mbox2 on as the Shure 87A requires it being a condenser mic.Make sure you use XLR mic cables. These are just things to check on.
Jan 29, 2011 | Digidesign *mbox2...
I am trying to upload protools le 8. starts to upload & sticks
Are you installing from a disk or a download? Sometimes the program gets corrupted during the download and you have to do it again. You may require specific drivers for your machine. Its always good to contact the company for support:http://www.digidesign.com/index.cfm?navid=3&langid=100& Hope this helps.
Jan 21, 2010 | Music
I have a behringer xynyx 1204,and a protools personal studio,with mbox2 mini,and im just wondering if its possible to plug the mic into the mixer,instead of the mbox,and still be able to record vocals into...
It is possible, you can simply put a Y-cable for Mic or a splitter for the mbox and the Mic. You can plug the mic directly to the mixer then the other jack on the splitter connected to the mbox.
Jul 25, 2009 | Behringer Music
Question on the start /stop feature and saving tempo information
As I read the manual, the tempo is saved with the SONG.
Starting and stopping rhythm SHOULD always start at the begining of the song. This is on page 20 of your manual. The manual is available online if you don't have one.
Jun 12, 2009 | Alesis Sr 16 Stereo Drum Machine
The tempo indicated on the alesis sr16 is inaccurate
how can i change the tempo on song compose, for example step 01 tempo 60 and step 02 tempo 120??
Thanks.
Jan 16, 2009 | Alesis Sr 16 Stereo Drum Machine
Korg Pa800 Synthesizer Logo
104 people viewed this question
Top Korg Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Korg Music Expert? Answer questions, earn points and help others
