Question about Hamilton Beach BrewStation 47214 Coffee Maker
No Power I've checked the plug, outlet and connections. One day it just stopped working. No power. Troubleshooting sheet says it might need a cleaning. I go to the cleaning page and it says to clean it I have to turn it on!!! Help! ron
  • 1 more comment
  • Anonymous May 17, 2009
    One day - i went to make a pot of coffee and 'no power'. checked the wall plugs - but the unit is just not powering up.
  • hozro May 17, 2009
    The outlet? Dude, youre no wiz. The unit wont power up - the wall plugs are hot and fine.
  • Anonymous May 22, 2009
    I have the same problem. Just one day it stopped working. Would like some help since it is only a year old.
  • 30 Answers
Just remove the outlet and see whether the connection is proper.
Sometimes there might be a loose conduct which causes such problem. After doing this if the problem still continues just take another new wire, join it with the old one and connect it.
Posted on Jul 09, 2008
OW TO GET MY ACET ASPRE ONE IT STOP BLACK SCHREEN NO POWER
Step by step troubleshooting.
Verify power outlet is good
Verify power adapter is good
verify connection to computer is good
fully charge battery
test
=======do this
Check power source, plug known good light into AC receptical.
If AC cord has connector to power block verify it is properly seated.
plug adapter into AC outlet
Verify Power is present at power connector with another similar computer or voltmeter. (12V to 20V)
When plugged into computer, charge (not power) indicator MUST light either red, amber, or green. If not, connector on computer may be broken.
leave overnight or until charge light is green
turn on normally.
most likely causes:
- loose connector
- broken wire from power adapter
- broken power plug on computer.
- anything else is probably beyond ur capabilities to fix.
Aug 10, 2014 | Acer Aspire One PC Notebook
C 352 does not turn on
Is your power source a direct plug-in to a wall outlet? Make sure both the upper and lower parts of the duplex receptacle are working properly; use a volt meter or in the absence of one, use a desk lamp or some other electrical appliance to test that the outlet is working.
If you are using a power strip or a combination power strip-surge protector, make sure the switch is turned "on" and that the internal breaker did not "trip"; press the reset button if there is one present.
The same way you checked the wall outlet for power, check the power strip the same way. Yes it is possible for any one of the outlets to be defective while the others work.
Check the power cords, make sure there is no loose connection or have been disconnected entirely.
Make sure the wall outlet is not controlled by a wall switch- on rare occasions I have responded to service calls where this has been the case.
Beyond that, you will need the service manual for that particular model printer to take you through the troubleshooting steps; which will require taking apart the printer's casement and exposing moving parts.
It could be a defective "on-off" switch; power supply; main board, etc. I don't know your skill level and if you are tech savvy.
You can contact the manufacturers' tech dept personnel; they may walk you through basic troubleshooting steps like I just did before authorizing a warranty repair or return repair order.
If it's no longer under warranty and its going to cost you more than half- or two thirds of what it cost you to buy the printer in the first place; go buy a new one and dismantle the old one for the precious metals and collect some money back on it. Copper, gold, stainless steel, and aluminum are at a premium these days.
Nov 25, 2013 | Konica Minolta bizhub Office Equipment &...
Kenmore H2 front loader washer wont run
see this steps and fix it. God bless you
Check Power
Check the outlet by plugging an appliance into the same outlet the washer was plugged into an running the appliance a hair dryer works good for this it will draw some amperage. If it works fine move on.
Control
To check the control remove the top panel and then remove the console to access the wiring to the control. Find the wire feeding the control from the main power cord. If you cannot visually see this refer to the tech sheet or service manual. Connect voltmeter to the 2 wires feeding the control if it is recieving power and it does not respond replace the control
Jul 09, 2013 | Kenmore Washing Machines
How do i reset my wf100
follow the steps and fix it. God bless you
Check Power
Control
May 28, 2013 | Washing Machines
Why won't my ml44t transformer turn the connected lights on or off?
1) Copy following link for installing and troubleshooting power pack
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
2) Test outlet for power.
Temporarily run extension cord from another outlet.
Connect wires to terminals a and b ... make sure no insulation is under screw plate.
44 watt power pack will operate 44 watts of low-voltage lights (12Volt).
If 300 watts of lights are installed on line, then lights probably will not light up.
Mar 01, 2013 | Hardware & Accessories
I have (7) 20W bulbs on a newly wired line running on a brand new 200W Malibu transformer, worked fine for 2 days and now it's tripping the reset button - Any suggestions ??
1) Copy following link for malibu power pack tips for longer transformer life:
2) Two plug choices on each outlet, Plug power pack into other outlet on receptacle.
Inspect for damage on outdoor outlet.
Replace outdoor outlet, and do not use quick connects. Connect wire directly to screws on side of device.
Replace GFCI outlet.
Feb 01, 2013 | Malibu Intermatic Inc. ML121RT Low...
My Remington Keratin Therapy Flat Iron Doesn't Turn On.
see thi steps and fix it.God bless you
If the iron doesn't heat, make sure 1) power is on to the outlet, 2) check the electrical cord and 3) check the thermostat and replace if necessary. Use the VOM.
Oct 15, 2012 | Remington Style Therapy: Keratin Therapy...
The digital display keeps flashing and wont work
see this causes and fix it. God bless you
Control
To check the control remove the top panel and then remove the console to access the wiring to the control. Find the wire feeding the control from the main power cord. If you cannot visually see this refer to the tech sheet or service manual. Connect voltmeter to the 2 wires feeding the control if it is recieving power and it does not respond replace the control.
see the diagram attached and troubleshooting too.
Sep 30, 2012 | Washing Machines
Put on 1min - starts and stops after a second. Moved micro about month ago and put it back - works okay. Fautly again to day - moved it - connected and it works. Ready to move back to place and tested and...
Yes.... your outlet is no good...when the Micro starts to use more power the plug to outlet connection heats up a bit and the contact is momentarily broken...then it goes back on as soon as the power usage is stopped...
Replace the outlet that you are plugging the microwave into and your problem will be solved...
heatman101
May 26, 2011 | Kitchen Ranges
Printer doesn't turn's on
Per Canon:
Solution: Disconnect and Reconnect AC power adapter or power cord to the device and electrical source
Secure all Power Connections
  • Disconnect the AC Power Adapter or power cord from both the device and the electrical source.
  • Then reconnect it.
  • If you are still unable to obtain power to the device, try another power outlet.
  • If possible, try connecting power directly to a wall outlet (as opposed to using a surge protector or power strip...just as a troubleshooting measure).
If this does not work, have you tried a different outlet to ensure that the outlet isn't the issue? Also, when you press the POWER button, does the printer respond at all, or is it basically dead?
Please post back if you need further help, otherwise, thank you for using and rating FixYa!
May 24, 2008 | Canon PIXMA iP1600 Printer
Hamilton Beach BrewStation 47214 Coffee Maker Logo
158 people viewed this question
Top Hamilton Beach Coffee Makers & Espresso Machines Experts
jason
Greg Cann
Greg Cann
Are you a Hamilton Beach Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
