Question about HP Compaq ProLiant ML530 Server
If the fan light is on, what does this mean? Thanks
Why does the fan stay on my Toyota Yaris 2004.
WHICH FAN?
my guess radiator fan.
the CEL lamp is on, "? running,that means there are huge errors stored, why not scan it, a tool is like $10 (ask) or free scans at all ASE shops.
no man on earth an surely blind here can answer that question,wow.
is it drivable after all we dont know what is wrong yet,cart before horse its called.
im sick ,can i ski dive:/ heck i dont know.?
the fans on most cars do stick on, parked, hot, this is a FEATURE
even the fan shroud shows that, (fan may start at any time)key off.and on.
the fan on 24/7 means engine is overheated
or has failed.
we connect scan took ,ahh not overheat,
and find the ect COLD, AND FAN ON AND FAN CONTROLS BAD.
IN 1MIN FLAT.
Dec 27, 2014 | 2007 Toyota Yaris
How do i rewire my ceiling fan/ light so the fan will run when the light is off?
Go to home depot or lowes and get a different switch,tell the salesman what kind you want and he will show it to you.
Dec 22, 2012 | Dryers
The temp light on our projector is flashing red along with the power button going green then turning red along with it. What does this mean?
It means that the unit sensed fan malfunction inside the set. It will produce an excessive heat which will damaged other parts. To avoid this thing to happen, protection circuit is enable and shown an error code through the led light. Check for faulty fan and replaced it with new one.
Have a nice day!
Thanks for using Fixya.
Aug 19, 2011 | Epson PowerLite 3LCD Projector
I have a Samsung 56 in DLP that took a power bump and now will shut off after being on for only about two minutes. What can I try? It is protected by a surge protector so I don't think the surge went to...
Did you hear friction sound from behind unit?, if you hear it, change the color wheel.
Did lamp light before switched off?
and which indicator led in front side are blingking (Lamp ,Temp or fan).
If Lamp, chech the lamp.
If Temp, its mean hight temperature detected . check fan on engine, is it rotate smoothly or not, change that fan if necessary.
If Fan, its mean fan not working.
Thanks
Mar 15, 2011 | Samsung DLP HL-P5663W 56" TV
When I turn on the TV the green start up light blinks green and the TV comes on with picture and sound for about 2 seconds, then turns itself off and the code light blinks 4 times, pauses then blinks 4...
4 times blinking means Fan stopped, power is not supplied on Fan 1, Fan 2 Fan 3 and at Fan 4. Or Fan connector is not attached securely. Cleaning these fans by using a vacuum cleaner can also solve your problem. Sometimes these fans are clogged by dust.
Oct 24, 2010 | Sony KDS-R60XBR1 60" Projection HDTV
My check engine light came on after i put freon in the car for the air condition. my friend has a computer that we hooked up to the car to find out what the problem was and this code came up P1490, what...
When you get that code it means that the computer isn't detecting the relay kicking in and starting the cooling fan.
In most cases replacing the relay for the fan will cure that problem and you can erase the code with scanner once the problem is repaired
P1490 Low Speed Fan CTRL Relay Circuit - you need to check and make sure the cooling fan is coming on when it suppose to.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 05, 2010 | 2003 Chrysler Sebring
We were given a Gateway EL500S computer to use for our kids. We set everything up. We did try to install an ethernet card. When we turned it on, nothing happened. The light comes on the ''on'' button but...
when you say no fan you mean the cpu fan or the case fan. the cpu fan is on top the cpu. make sure that at least this starts. if it does not start then shut down your pc immediately as it can burn the cpu.
it could be lots of reasons, but make sure that you have connected the power supply cables correctly to the motherboard. probably the motherboard may have a small led. check if that lights up. it means that power gets to the motherboard.
i would advice to find someone that has more knowledge.
Jan 24, 2010 | Computers & Internet
Just wanting to find which wires go where on switch of fan with light. i have old wire to loop into with new old wire brown / black new black red & green Thanks
I think u mean old cable has 2 wires, those were brown & black, new cable has 3 wires those were black=Neutral, red=Phase go to switch, green=Ground.
Thats it.
Aug 21, 2009 | Monte Carlo 5BY52MW Bayshore Ceiling Fan
Flashing standy light
This means Fan failure - A replacement will cure.
Jun 21, 2008 | Sony PFM-42B1 42 in. HD-Ready Plasma...
HP Compaq ProLiant ML530 Server Logo
44 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
