Question about Zanussi FC1200W Front Load Washer
No power to my washing machine (fuse changed still no power)
  • Zanussi Master
  • 1,527 Answers
Hello, have you checked the glass fuse inside the power supply if it has blown make you use the same rated fuse if it blows again the you have dead short in the washer somewhere hope it helps
regards
shaun
Posted on Jan 03, 2011
My washing machine has no power to it
Could have blown a circuit breaker in your electrical panel and if you have fuses could blow a fuse. You may have a short some place. Start with checking the cord and the plug its self. If you have a GFI receptacle you may have to reset that as well
Aug 30, 2016 | Washing Machines
Why is there no power?
Hotpoint red led flashes Washing Machines Questions ...
www.fixya.com > Forum > Tags > red led flashes > Washing Machines
Hotpoint washing machines red led flashes related questions and answers. ... then off When i turn on the washing machine - Hotpoint wf640p - the LED display flashes all the 8s (so ... Question about Aquarius WD640 Front Load Washer/Dryer.
Oct 27, 2015 | Hotpoint Aquarius WD640 Front Load...
Why is my washing machine tripping my main fuse box even when I change the plug socket
by "tripping main fuse" do you mean the high amp (eg 60 amp or 100 amp) fuse that feeds the whole fuse box? if that is the case, there is too much stuff on in your house that's drawing power. The fuse box is too small to power all the stuff you have plugged in and running. Suggest turning off other high draw appliances in the house, like large TVs or microwaves or air conditioners, when running the washing machine.
Nov 18, 2013 | Washing Machines
Thers no power to my washing machine.changed the fuse and theresstill no power.what do i do ? thank you emma
Hi emma... Unplug the machine from it's current outlet and use a heavy duty extension cord to plug it into another outlet that you know works [plug a blow dryer in to check it].
If the washing machine works then you know the problem is in the outlet or the wiring to the outlet. IF the washing machine still doesn't work you know the problem is within the washing machine itself. Possibly the lid switch or a fuse within the machine. J.
Aug 02, 2011 | Indesit Washing Machines
Washing machine won't switch on , changed fuse and checked power.
assuming fuse and power both ok could be off/on switch or door interlock if indicators say power ok
Apr 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Candy GO1482 washing machine blows house fuse
u have an earth fault on mc caused by damp or water across the neutral check for water on electrical components
Nov 18, 2009 | Washing Machines
Washing machine flips the fuse box switch
Either the moter is jambed or timer is broken Disconnect power tip machine up and attempt to move belt manuallr it shouls with some resistance
Oct 12, 2009 | Washing Machines
Had power cut now machine wont work changed the fuse still nothin
check power from the wall socket if its ok the doorlocks and motors are prone to blowing the circut board can be expensive
Jul 30, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Creda 120vw washing machine fuse changed still no life
You start looking from the power plug, down to the power-cord. The power point in the wall, (plug in something else to check power), the pause switch on the machine, any lights on the machine? Did you open the door to get the clothes out?..........
Careful when the power is on & the top off.........
Dec 22, 2007 | Creda W100FW Front Load Washer
Zanussi FC1200W Front Load Washer Logo
235 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
