Sir This machine is not so old (2/3 years) and yet we have an occasional oil leak around the outside edge of the drum which sometimes marks white sheets etc. I have repeatedly cleaned the oil from the drum seal, but, it keeps coming back. When I called the supplier technical guys, for a "repair quote" - they suggested that the bearings were worn.....but....that the bearings could not be replaced without the whole drum as well ??? Are they correct, because I would rather have it repaired than buy a new one. Regards, Doug Symmons, Cardiff
  • 10,515 Answers
Unfortunately, he is absolutely correct.The bearing is a part of the tub itself on most of the models, and repair is never suggested as compared to the cost of the machine.The average cost of parts and labor would be around $450 - $500 which makes it much wiser to invest in a new machine. I wish i could have a better news.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jan 03, 2011
LG fuzzy logic top loader leaves black marks on white. Happens when doing a large wash-eg; blanket -it looks awful. I'm thinking the insides might need cleaning? How is this done and with what product
If this is moldy looking you should use 1 cup of bleach in the drum with no clothes on the longest wash cycle with the hottest water. But I believe this is oil from the drive train and the seals on the bottom of the drum are going bad. When you wash something heavy like the blanket, it leaks.
Nov 25, 2013 | Washing Machines
My Frigidaire FTF530FS Front Load Washer appears to be leaking oil and it is getting on my clothes
Hello Loree Grudem - This can be the result of the shaft bearing and seal. They may have become worn and the transmission oil is creeping up to get in your water. Once this happens, it gets on your clothes to cause staining. Or possibly you have a buildup of fabric softener that comes loose and puts a greasy like substance in your water and on your clothing. Once you put your clothes in the dryer and the old fabric softener melts you will see these spots. I suggest contacting a professional to move forward accurately.
Oct 09, 2012 | Frigidaire FTF530FS Front Load Washer
Rust colored mark or short line on tee shirts
most likely coming from your washer....when clothes are wet it harder to see marks....washer needs new seals.
Jul 20, 2010 | Maytag PYE2300AY Electric Dryer
Dryer is leaving brown marks on clothes. it is either a burn mark or they are getting caught between dryer drum and shell, not the door
I had the same problem. Unfortunately, it is caused by a rusting drum edges, if you can believe it. My dryer was only 6 years old when this problem occured. There are felt gaskets on the front and back of the drums where it contacts and rotates on the frame of the dryer. You can take a white cloth and run it around the rim of the front and back of the drum and I suspect you will end up with some discoloration on the cloth. I had these felt gaskets replaced, but that is only a temp solution. When the drum is taken out and the old felt gaskets are removed, you can clean the edges of the drum and get a lot of rust/brown off the drum. New gaskets are only a temp fix. I did it about 1 1/2 yr ago, and I think the problem is starting again. Probably time for a new dryer or time to pull the drum and clean it. New drum probably cost prohibitive if you can get one. What a bunch of **** for a 7 1/2 old dryer. Next dryer will have a stainless steel drum. Hope this explanation helps you with your problem.
Steve
Mar 29, 2010 | Amana ALG331RAW Gas Dryer
My whirlpool washing machine has chipped around the holes in the tub and has rusted. It leave rust marks on my white clothes. Is there any way to repair the tub? The washer is about 5 years old but I am a...
You used to be able to get a brush on product that was used to fix chips in baths and appliances.. I can't remember what it was called, Check around some appliance shops perhaps they might remember?
Feb 02, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Our whites are coming out with grease stains on them
The stains if coming from the washer is going to be most likely the to much use of fabric softner, Most of the time it comes from the dryer where the felt seals are wearing thin and pinching the clothes between the drum and the bulkead making these marks, you sill need to verify which one is causing the problem...
I have seen many times, specially if your machine is more than 5 years old, it might be due to transmission Leak which is highly unlikely.
If that's the case, time to change the washer. As the part itself would be around 150 bucks.
The total would be around 300 bucks.
Let me know, if you need further assistance.
Hope i helped you.
Thanks for using
Sep 28, 2009 | LG Washing Machines
Front load washer leaks
It's not difficult to line up the boot around the door. The difficult part is taking out the tub (basket and plastic shell). Everything needs to be disconnected, and removed from the back, as well the tub is very heavy and best to do as a two person job.
If your washer is only 5 years old, it's kind of a 50/50. The cost (with labour) to fix the leak would come to approx $450 cdn.
Jan 30, 2009 | Kenmore 43142 Front Load Washer
Poor copy quality - lines on paper
Hello sir; The problem is caused by drum cleaning blade, you need to replace drum cartridge or drum blade if you can.
Jan 23, 2009 | Canon NP 6551 Black and White Copier
Kenmore Dryer Drum Felt
i know have to ck myself on those sometimes the stitch closest to the edge of the seal goes toward center of drum..you will also have to stretch the seal around edge of drum 4 hands make it easier
Aug 01, 2008 | Dryers
Dryer is leaving brown streaks on cotton clothes
To all victims of the brownish colored streak marks: I share your frustration!!! I have the same problem with my dryer which started when my dryer was only 3 or 4 years old - - totally unacceptable for an expensive top of the line dryer! A repair guy showed me how the brownish streak marks come from the felt liner which goes around the drum. Look inside your dryer for the beige or tan colored felt which sticks out around the circular drum. If you rub the felt with an old white t-shirt or paper towel, you will see the same brownish colored marks. My repairman recommended getting the felt replaced eventually, but until then, he gave me the following tips which really help avoid getting the streaks: For white or light colored clothes susceptible to the brownish streak marks: I dry these items as part of a very lightweight dryer load - with just a few other lightweight items. By doing a small lightweight load, clothing is less likely to get caught up & rub against the felt edges. For example, I dry 4 light colored men's dress shirts with 2 or 3 other lightweight shirts. OR for white or light colored athletic "dry fit" type athletic apparel, I dry 6 - 8 total lightweight shirts/shorts. If I throw my white Nike top or white pair of summer pants into the dryer with all my "whites", they will be doomed to getting brownish streaks due to the heavy load pushing them against the darned felt liner! Whenever possible, I wash susceptible items on permanent press to avoid wrinkling, then hang dry. Prior to putting these clothes in the dryer, I also "pre-clean" the felt with an old white cotton t-shirt by reaching into the dryer and rubbing along the felt edges until I'm not getting as much brownish color on the t-shirt rag. For a permanent fix, call a repairman or see the following do-it-yourself YouTube video on "Dryer Repair - Replacing the Lower Front Drum Felt Seal": http://www.youtube.com/watch?v=XoYP_YsGP68 . I have a repair person coming today to fix 2 other appliances, so I'm finally getting my dryer fixed, and I will post an update soon.
Dec 30, 2007 | Dryers
Washing Machines Logo
13 people viewed this question
Top Washing Machines Experts
