Question about Refrigerators
I have a Samsung rsh1dbbp fridge/freezer, the change filter light has come up, but the instructions are not clear I do not know where to install the new filter, could someone help me?
The filter is located behind the fridge. This is a self contained filter cartridge that is replaced as a unit. Online they sell for about £4. Pull the fridge out completely and you will probably see the filter cartridge clipped to the wall. The filter is about 10 inches long and about 2 inch diameter. Note the flow direction marked on the new cartridge, and remember to turn off the water supply before disconnecting to inlet and outlet pipes from the filter . Hope this helps
Posted on Jan 09, 2011
How to change water filter on beko fridge /freezer
are some instructions for the installment of your
replacement filter for a Beko AP930X refrigerator. These instructions also include the location of the filter:
http://www.freshwatersystems.com/specifications/MTG_Installation-Instructions-7.pdfHere
Jun 08, 2013 | Refrigerators
Samsung model rsh1dbbp: fridge running at 19 degees. have cleared ice build up in lower left hand side. freeer and water ok. no ice build up in freezer
The accumulation of ice on one side indicates a refrigerant problem. Basically there is a refrigerant leak and some of the refrigerant has been lost.
A technician can repair the leak and re gas the refrigerant for you.
Apr 01, 2011 | Refrigerators
Where is the water filter located and how do i replace it.
The water filter is located in the fresh food or fridge side of the appliance, at the rear - in the upper right hand corner.
To change the filter, open the fridge door, clear the top shelf and grasp the filter. All that is needed is to turn the filter to the left about a 1/4 turn for it to drop down. A few drops of water may spill onto the shelf. To install a replacement, remove the protective cover (shown as a red cap above), and position under opening for filter. Gently push upward while turning the filter to the right. The filter will pop in, and as you turn about 1/4 of the way around, it will be drawn up a small amount until seated. At this point it will no longer turn any further.
More info about the filter is below (taken from the manual).
Please rate this reply - thanks!
The water "Filter Indicator" light
• "Filter Indicator" light lets you know when it is time to change your water filter cartridge. The light
will change from green to orange. This tells you that it is almost time to change the current cartridge.
It is recommended that you replace the cartridge when the light changes to red. (see "Install the water filter" section for more information)
• If you install water filter, throw away the first six glassfulls of water filter, or until water flows clearly to flush impurities in the water supply system.
Using the dispenser without the water filter
• You can not use the water and ice dispenser without a water filter cartridge because the water line
blocks at water supply.
Ordering replacement filters
• To order more water filter cartridges, call 1-800-SAMSUNG and ask for accessory Part # DA29-
00003A or contact your authorized Samsung dealer.
Jan 04, 2011 | Samsung RS265LABP Side by Side...
My samsung rsh1dbbp will not cool down, when it is on the freezer won't go below -20 and the fridge +14, and it is constantly beeping even when switched off? Can you help?
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for the air deflector As you know, the deflector directs the freezer air toward the front of the frig and the rear of the cold control.
I think this help in solving the problem.....
Nov 02, 2010 | Samsung Refrigerators
Water tastes funny
if there filter was not properly installed you would not have any water at the door.
you do not need to turn the water supply off to change the filter.
you should be able to push the filter light for three seconds,they do not turn off they just change color
May 28, 2010 | Samsung RF265AA Bottom Freezer French Door...
I have a rs21dcns fridge freezer. i'm having trouble getting water from the water dispenser and also having trouble setting the temperature control for my fridge.
The water stops flowing from the dispenser when the external water filter needs changing, stick a new filter and it should start working again, it sometimes takes a few minutes to clear the air after the filter change.
Sep 07, 2008 | Samsung Refrigerators
Water dipenser
The instruction book suggests this could be because the freezer temperature is set too low. Mine is set at -20C. It says the water line can freeze stopping water flow. Try reducing the temperature.
Sep 03, 2008 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
292 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
