Question about Dell Inspiron 2200 Notebook
Does my dell inspiron 2200 have tv o/p facility to the vga connector?
    Sergeant:
  • 223 Answers
Yes you have monitor out VGA connector just check left side of your laptop you can see 15 pic monitor output , that's VGA connector, you can use them to connect your lcd tv.
Good luck ! if you think your problem solved don't forget to rate
Posted on Jan 03, 2011
Connect Dell Inspiron 6400 to VIZIO E601i-A3 60-inch 1080p LED HDTV using VGA Connector
When you connect the vizio try changing the resolution settings on your laptop to see if that makes a difference. Could be that your video card output is not really compatible with the higher requirements of the Vizio.
Sep 20, 2017 | Vizio 60" E601I-A3 Full HD LED-LCD TV
Dell inspiron 1520 how do i connect to my tv
The Dell has a VGA port 15 pin DSub connector and if your TV has a 15 pin viseo connector the you need a 15 pin video cable. Check the connectors on the Dell and TV so you get the correct connectors. You will need to select the computer input on your TV so it can display the Dell computer video images.
Apr 17, 2012 | Dell XPS One All-in-One TV Desktop with...
Repairing power connector inspiron 2200
The connector is special to Dell, and not generally available. You may need to purchase a new power supply. The connector has 3 concentric terminals, and one is used to 'ID' the power supply as genuine DELL. A plain DC connector can be used, but the batterys will not charge.
Mar 10, 2010 | Dell (8N816) Motherboard
I have Dell Inspiron 2200 laptop. My laptop's
The lines indicate a slow failure of the LCD and it is progressive. The system can be connected to a VGA monitor and you can select the External display using Fn + F8 key combination.
LCDs are about $100 on EBay
http://shop.ebay.com/?_from=R40&_trksid=p3907.m38.l1313&_nkw=Inspiron+2200+LCD&_sacat=See-All-Categories
Dec 25, 2009 | Dell Inspiron 2200 Notebook
Does VGA card support TV out directly through VGA port function.
For TV's you have separate port that is S-Video.
Thanks, PREM
Mar 30, 2009 | Dell Inspiron 2200 Notebook
Vga to tv
The answer to your question is Yes. You can use a VGA to RCA converter and view the output on your TV. I am assuming that you are using a Inspiron 1200 laptop. Couple of things you may need to check.
1. Toggle display using Fn + F2 (Hold down the Fn key and press the F2 function key), this will toggle the display between Laptop, TV, & Laptop + TV .
2. Right-click on desktop, goto display properties, make sure the second display is set to 800x600 or 1024x768, these are the only display resolution supported by analog TV’s
Hope this helps. Please rate your feedback!
Thanks,
VJ
Mar 23, 2009 | Dell Inspiron 1200 Notebook
Dell Inspiron 2200 to Phillips 47 " TV
check this out http://answers.google.com/answers/threadview/id/762913.html *A VGA connector and cable are used to carry analog video signals plus display and graphics data. The VGA is a 15-pin connector commonly found on laptops and other devices. With this port you need a PC-to-TV Convertor to connect laptop to TV. You simply plug the VGA cable from the source into the convertor, and use an S-Video or RCA cable out to the TV. The converter is USB powered, so there’s no external power adapter to carry around, making this laptop to TV connection entirely portable. you will need a seperate audio cable unless you are going to use your laptop's speakers
Feb 04, 2009 | Toshiba Tecra M1 Notebook
Laptop to TV
I dont believe that you can hook that model up to a TV you have to have a certin video output and it also would depend on your tv as well. But i am about 100% sure that series does not have the output you need you usally can connect via S-cable
Dec 04, 2008 | Dell Inspiron 2200 PC Notebook
Dell Inspiron 2200 microphone scenario
Any standard desktop microphone or headset with microphone will perfectly work. It requires simple crystal microphone which starts from few dollars. You can get from any IT store
Good Luck
Jan 18, 2008 | Dell Inspiron 2200 Notebook
Dell Inspiron 2200 Notebook Logo
89 people viewed this question
Alun Cox
