Question about Acer Aspire 6920 Notebook PC
It tries to boot from network. In the boot menu IDEO is set at 1st priority but if I press F12 at start up the only option is the network boot. What is wrong
    Brigadier General:
  • 8,909 Answers
They do. Disconnect any periferals before booting.
Download an updated BIOS and updated drivers from Acer.com
Posted on Jan 03, 2011
How do I unlock the Bios on an Acer ES-1 111M Laptop
To boot from a CD, DVD or USB device, make sure that the device has boot sequence priority over the hard drive.
BIOS Boot
BIOS (Basic Input Output Subsystem) is a programmable chip that controls how information is passed to various devices in the computer system. A typical method to access the BIOS settings screen is to press ESC, F1, F2, F8 or F10 during the boot sequence.
BIOS settings allow you to run a boot sequence from a floppy drive, a hard drive, a CD-ROM drive or an external device. You may configure the order that your computer searches these physical devices for the boot sequence.
The first device in the order list has the first boot priority. For example, to boot from a CD-ROM drive instead of a hard drive, place the CD-ROM drive ahead of the hard drive in priority.
Before you set boot priority for a USB device, plug the device into a USB port.
To specify the boot sequence:
  1. Start the computer and press ESC, F1, F2, F8 or F10 during the initial startup screen. Depending on the BIOS manufacturer, a menu may appear.
  2. Choose to enter BIOS setup. The BIOS setup utility page appears.
  3. Use the arrow keys to select the BOOT tab. System devices appear in order of priority.
  4. To give a CD or DVD drive boot sequence priority over the hard drive, move it to the first position in the list.
  5. To give a USB device boot sequence priority over the hard drive, do the following:
    • Move the hard drive device to the top of the boot sequence list.
    • Expand the hard drive device to display all hard drives.
    • Move the USB device to the top of the list of hard drives.
  6. Save and exit the BIOS setup utility.
  7. The computer will restart with the changed settings.
Boot Priority Options
Some computer manufacturers allow you to select the device that contains the boot sequence from a special device selection menu. The example below uses a Dell system board.
To set boot priority using a device selection menu:
  1. When the computer starts to boot up, after the manufacturer's ID screen, press F12 several times. The device selection menu appears.
  2. Use the up and down arrows to select CD-ROM or
May 04, 2015 | Acer Aspire Computers & Internet
How do i access the boot menu on a Vizio All in one PC Model CA24-A0. Im trying to do a clean install of windows 7.
press f7 key ,select usb storage from start up menu and press enter ,follow steps,hope this helps :)
Oct 15, 2014 | Vizio All-In-One CA24-A0 - Core i3 3110M...
Toshiba boot screen won't appear when turned on
It will help if you mention the Toshiba model so we can ascertain which BIOS is running. But in general, take the USB out of the slot, and then when the machine starts up, press F2 when you see the prompt.
Alternatively if you do not see the prompt screen, press the ESC key for 3 seconds immediatley as you start the machine and then F1- that should present you with the Setup screen
Feb 13, 2014 | Toshiba Satellite L855D-S5220 Laptop
My computer will not boot windows xp os
Do you mean it won't pick the disc? If so, try F10 it should also give you a boot menu if you don't see press any key to boot from cd... The other option is boot into BIOS and change your boot order. CD-ROM/DVD should be the 1st option.8_28_2012_7_14_07_am.jpg
Aug 28, 2012 | IBM ThinkPad X41 Notebook
COMPAQ PRESARIO WON'T BOOT FROM CD
Hello, you are experiencing this because of the Boot priority setting in your bios. Your computer has been set to boot from your hard disk first and so it will never try to boot from a CD when it starts. There are 2 ways to fix this:
1. Go into your bios (usually by pressing F2, F10 or Delete key as your computer starts) and set the boot priority to check CD or optical drives first. Consult your PC manual if necessary.
2. Press F12 when your computer starts, this will bring up a menu to select boot options. Choose your CD drive.
Thanks for using FixYa
Jul 22, 2011 | HP Compaq Presario Sr5550f Desktop Pc
Having problem with operating system disc....can get to advanced bios menu but do not know what to change the priority of.... first 2 items on the menu won't let me change priority value and the 3rd...
there should be a boot menu command at start up just like you entered the system bios, i believe the e machine boot command is F12 that will give you the opportunity to boot from what ever you want on that boot only. so in your case of course you would scroll down to cd and hit enter. press any key to boot hit any key and boot.
May 30, 2011 | E-Machines eMachines Desktop PC
DELL latitude 100l, someone disabled all boot devices then set config / administrator password. Please help
Boot Priority on Dell Latitude 100L
  1. Turn On Your PC
    Have you ever noticed the messages that pop up on the screen as soon as you turn on your PC? These messages tell you a key combination you can press to enter "Setup" or the "BIOS." Watch your screen and see if you can read what keys to press.
  2. Press the Keys to Enter Setup Mode
    If you did not see a message telling you what keys to press, try tapping the following possibilities as you turn on the machine:
    • Esc
    • F2
    • F12
    • F10
    • F1
    After pressing Esc or other key, you will most likely see instructions telling you how to enter "Setup Mode". Follow those instructions.
    tip.gif On some computers, you must hold down the key before you press the power button to turn on the computer. For example, if you are converting a Toshiba laptop to a Linux Workstation, you must hold down the Esc key and then press the power button. The computer then asks you to press F1, and you can then set the "Boot Priority."
  3. Using the Arrow Keys, Choose the "Boot," "Boot Order," or "Boot Priority" Option
    The menu of choices you see will be different for different kinds of computers. Remember that the choice you want is the "Boot" order or "Boot Priority." On some computers, this is called the "Start Up Options" or "Start Up Sequences." You are going to change where the PC will look for boot information when it starts up. (CD-ROM, HARD DRIVE/HDD, LAN, FLOPPY, USB). If you wish to boot from your Hard drive, then select it as your First Priority.
  4. Using the instructions on the screen, save your settings and start up your PC. The PC must boot from the HDD. Regrds
Jul 01, 2010 | Dell Latitude 100L Notebook
How to enter to boot menu
Try to press F12 during startup. You need to press F12 before windows starts to load.
Another option is press F2 during startup and change the boot device in the boot device priority section.
Done that Save and Exit setup
Mar 13, 2010 | ASUS F3Jm Notebook
When my Maxtor basic External Hard Drive is conected my PC won't boot up.
Verify in the BIOS setup (usually accessible by pressing F2, F12, or Del at boot), "Boot Device" submenu, that the system isn't programmed to also boot from an external device. If it is, it will try to boot off the Maxtor, but won't be able to since there's no OS there.
The system should be configured to start off the internal hard disk, and optionally the CD-ROM. Other options (ROM BIOS, PXE, USB, etc.) are usually best left deactivated or at lowest priority.
Nov 17, 2009 | Maxtor BASICS Personal Storage 3200...
How to set boot priority in bios is thinkcentre lenovo it has no option in bios
when i am enter in the lenovo bios in bios option have four option for first boot device. which i am select.
Oct 21, 2009 | Lenovo ThinkCentre® M55-8810 PC Desktop
Acer Aspire 6920 Notebook PC Logo
90 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
