Question about Exercise & Fitness
I have an older sr225 spirit treadmill. i have put 2 new motors in thru the years.it is now blowing the main house circuit breaker.the last time i put a new motor in witch was about 4 yrs ago the service man i talked to said that the next time it does that it would be the circuit boards? plus the motor & wouldnt be worth repairing? but i reley like this treadmill what do you think.
  • 96 Answers
SOURCE: Replaced Motor Control, motor and Main Control board, but still won't work
The only other thing that could cause the ON light to turn off as soon as the motor is about to start would be a bad or loose connection that causes a break in the circuit. Even if the components are O.K. the connection could still be causing the problem.
Posted on Mar 02, 2008
  • 409 Answers
SOURCE: SMEG A 2.5 Range Oven
sound like the TOD to me. have a technician replace it.
Posted on Sep 13, 2008
tjt3
  • 44 Answers
SOURCE: gfci breaker for spa
gfci's are designed to trip if they receive voltage on there ground/neutral side, therefore my vote is for Smithbrother I would say there is probably a partial short somewhere in you system.
Posted on Mar 24, 2009
  • 16 Answers
SOURCE: Proform 515s treadmill motor won't start
If the colse buttons make a chirping noise when you push them the console should be Ok. If there is no chirping noise with the push it is a bad console. If everything but the speed works it will probably be your motor controller that is bad.
Posted on Apr 14, 2009
  • 14 Answers
SOURCE: Tech support for New Balance 1400 treadmill thinks
In general, I haven't ever seen the MCB fuse ever blow. But the fuse should be visable if you remove the lower cover and look at the circuit board, most of these are of the old style automotive type and can be found at an auto store. more than likely a transister is blown and the board itself needs to be replaced, this usually happens due to the deck not being lubricated
Posted on Aug 22, 2009
Spirit treadmill model SR225 is this a 1.5 in speed? I need the slow model for mom.
If you wish to get some details; check the site http://electro-medical.blogspot.com/. Pull up older posts. Surf the site with patience. check for treadmill articles.
Mar 14, 2016 | Spirit Exercise & Fitness
Life Fitness 4000 repeatedly blows outlet circuit breaker
If there was a fuse in the treadmill it certainly wouldn't cause your main circuit breaker to blow. It sounds like the motor burnt out and shorted- which is causing your house circuit breaker to blow. There is a chance that the ball caused some other damage that is creating the short but my bet is on a burnt out motor. You would need to disassemble the unit and test for short circuits to verify.
Mar 04, 2014 | Life Fitness Lifefitness 4000 Treadmill...
I have a Ntl 1094 Track C 1900 and the problem i have is ; the drive motor for the belt trips a breaker in the house breaker box. The belt will start and run for approx 5 seconds and the the breaker...
first check and see what the circuit is rated at. it you have too many thing on that circuit(light,tv,etc) this will trip your breaker because of the amp draw of the treadmill. nordictrack recommends a dedicated circuit of 20amp. you may nned to have a circuit put in with 12/2 wire
Oct 17, 2013 | NordicTrack Exercise & Fitness
I have a rodgerblack gold treadmill ag-10302 when i switch it on at wall it trips the circut in my fuse box help please
1) please use a table lamp in connect in wall circuit. if the c.breaker trip again, the problem is your outlet wall. Call electrician or test the wires for touch each other or ground improperly, and fix it.
If the circuit is NOT trip, test the power cord for defective 2) test the main switch for shot circuit 3) test the c. breaker for defective 4) test the motor see the if the motor if short circuit see my personal TIPS for help motor , see the diagram attached. 5) test the output board, the board can be short circuit and replaced. Happy NEW YEAR God bless you
Dec 31, 2012 | Reebok Exercise & Fitness
Horizon 4000 treadmill is tripping mains circuit breaker and blowing plug fuse
see my personal TIPS and test the motor.
2) the main board can be faulty, replace
3) lube the machine for a DECK belt , the resistance can be another cause.
4) lube the roller bearing too.
5) test the power supply for faulty
see the block.
God bless you
Sep 19, 2012 | Exercise & Fitness
Bowflex Series 7 Treadmill motor problem
1) test the power cord for open, break
2) see if there some animal, bid the some wires internal, and get touch with the chassins provoking the short in the machine.
3) replace the blown fuse inside, see the block
4) test the main switch for open or defective.
5) unplugg the machine and see if there c.breaker or fuse are tripp? if does the problem is the c.breaker from your home
6) do NOT use extension cord, and buy some detector spikes, glitch,transient.
God bless you
Jun 26, 2012 | Bowflex Series 7 Treadmill Msrp 199999
Nordic track treadmill trips breaker
1) I am assuming that the breaker is the treadmill and Not from your house.
2)you must test the Main Motor. measure the voltage without load
3)now you must test the main motor controller board.
4) transformer.test .see the block diagram and see how the main motor board has aprox 90% of functions of any treadmill.
12_14_2011_4_11_07_pm.gifGood luck. Sincerely. G-d bless you
ERNESTO CUADRAMANAGUA, NICARAGUA C.A
Dec 14, 2011 | NordicTrack Treadmill
Treadmill electical issue: My Spirit SR275 Programmable treadmill blows the panel electrical fuse for our workout room when I start the belt. I can operate other treadmill control functions without blowing...
A treadmill has a high current draw -- it should be on a dedicated 15 amp-circuit -- if sharing a cricuit, it's not unusual, from time to time, for it to trip a breaker or blow a fuse in the main panel.
Charlie
Jan 12, 2011 | Kitchen Ranges
I have a Spirit SR-918 treadmill. running at 3.2 m, Stops and trips circuit breaker any where from 5 to 25 minutes.Had same problem in 2007, walking belt, deck and motor bushings replace. Put $500 into it...
We also have a Spirit SR 918. It may be the lower or upper boards powering the motor that malfunctioned.
We need a particular part replaced on it, other than those boards, so if you still have not trashed the unit, have replaced it, or are thinking about disposing of the unit, we will pick it up. We are in Chicago, as well.
It will cost us between $125 to $499 to replace our treadmill, but it is so heavy duty, that it comes down to finding the parts, since additional labor will come out even.
Aug 28, 2010 | Spirit Exercise & Fitness
E1 error on display
E1 code means an elevation problem but I am not familiar with the new Spirit models. Been trying to set up with Spirit now that I am getting calls on them again. Its been 5 years since my last call, best thing to do is get in contact with Spirit and they will direct you on what to do or give you phone # to call a service provider. The older units had a calibration sequence for such a problem.
Customer Service and Parts Departments
800-258-4555
May 27, 2010 | Spirit Esprit ET10 Folding Treadmill
Exercise & Fitness Logo
345 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
