Question about HP LaserJet M1522nf Multifunction Printer (CC372A)
Hi dear mis/mr we have hp 1212nf mfp,ok when we turn on the printer ,after ready,Continuous restart agine the printer . how to reset factore this printer? how we can update this printer cpu flash memory((F-W))?
  • 193 Answers
Press and hold the power button for 30 seconds after disconnecting the power cable and the USB from the back of the printer.
repeat this process thrice and the memory will be formatted.
you can update the printer drivers from HP.COM
Posted on Jan 13, 2011
How to remove error 49 service error on hp cm1017
disconnect any usb or network cables and restart. If error returns then likely it is a problem with memory on the formatter or the formatter. If you have added memory, remove it and try restarting again. If printer comes to ready, then you have a corrupt print job or the firmware on the printer is old and needs to be updated. Make sure all print jobs are deleted and reconnect the printer and download the current firmware from HP.com and install it.
Dec 13, 2014 | HP LaserJet CM1017 MFP All-In-One Color...
Rooler kit error
1 Turn the printer off.
2 While pressing [- Item] and [- Value] turn the printer on.
RESET MAINTENANCE COUNT appears, followed by INITIALIZING.
After a few seconds READY appears.Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For HP Support
Apr 01, 2014 | HP Color LaserJet CM6040f MFP Q3939A...
Memoy reset for HP LaserJet M1212nf MFP
Turnoff the printer.
Hold Cancel button and start/Copy button at the same time.
Turn on the printer.
Release the buttons when display shows "Permanent Storage Init".
Wait till the display shows "Ready"
Jan 10, 2014 | HP LaserJet Pro M1212nf MFP -...
CM 1015mfp Colors are not aligned. when printing the characters looks like 3D.
If nothing else works, you may have to manually calibrate the dials inside the mirror box. This video link will show you how. http://youtu.be/R1DIko0a1MA
This may be necessary if the printer got bumped really hard.
Aug 17, 2011 | HP Color LaserJet CM1015 Printer
How can I perform an NVRAM initialization with my HP CM1015 MFP
CAUTION NVRAM initialization will erase all network settings. Before performing NVRAM
initialization, print a Network Configuration page, which contains network-setting information.
NVRAM initialization performs the following actions:
? Resets all customer-accessible menu settings via control panel and software back to the factory
default settings
? Resets the language to the value set at the factory
? Resets the default media size to cold reset media size
? Resets the symbol set to PC-8
NOTE The following steps reset the same NVRAM locations that are reset using the
Restore Defaults option in the control panel Service menu. The following process should be
used if the MFP does not come to a Ready state and an NVRAM initialization is desired.
Use the following procedure to perform an NVRAM initialization.
1. Turn off the printer.
2. Press and hold the Right arrow and Cancel buttons simultaneously.
3. Turn on the printer.
4. When you see the message Permanent storage init, release the Right arrow and Cancel buttons.
When the NVRAM init is complete, the printer returns to the Ready state.
Aug 02, 2011 | HP LaserJet CM1015 MFP All-In-One Printer
Hp laserjet 9050n appear disk not initialized .how to solve. thank you.
Turn off printer
Press and hold PAUSE/RESUME(START on MFP)
Turn on printer
Keep holding the PAUSE/RESUME or START until all 3 error lights light
Release the buttons
Press LEFT ARROW(5 button on MFP) until INITIALIZE DISKS appear
Press the CHECK(6 button on MFP)
Wait for printer to READY
May 11, 2011 | HP LaserJet 9050 Printer
Hi Expert. I need to reset my printer ist hp m5035mfp plase I need you Help
Blow are the steps to do a "cold reset" on your HP m5035 MFP Printer. Just be reminded though that you will lose all stored info on the printer and it will restore it to factory settings.
How to perform a Cold Reset:
1. Turn the off the device.
2. Turn the device on and immediately hold down the 6 button on the control-panel keypad as soon as the control-panel display backlight illuminates.
3. Continue to hold down the 6 button until all three control-panel LEDs remain illuminated. Release the 6 button.
4. Use the 3 button or the 9 button to scroll to Cold Reset.
5. Press 6 to select the Cold Reset function.
The unit should then restart.
Hope this helps.
Apr 14, 2011 | HP Office Equipment & Supplies
How do i cold reset a HP CM6040F MFP COLOR LASER PRINTER It doesnt complete the initilization process... keeps hanging on step 6
restart the printer hold down 6 when backlight illuminateshold till all three lights turn on,relese 6 keythen press 3 or 9 to scrool
press 6 to select the optionu want then enter cold reset starts......
Jul 14, 2010 | HP LaserJet 4730 MFP Printer
How to fix error 41.3 on a HP P4515 printer. Have checked all paper settings and tray settings.Changed paper pick up rollers also.
Hi
This error means that the media in tray XX doesn't meet the specified standard of the tray. The specified tray is loaded with media that is longer or shorter in the feed direction than the size configured for the tray. Please check the paper size in current tray or touch OK to change the tray.
To resolve this issue Touch OK to display tray size. Reconfigure the size in the tray so that it uses size of media required for the print job. If the message doesn't clear automatically from the control-panel display, turn the MFP off, and then turn the MFP on.
Restart the printer and repeat the above procedure if issue is not resolved.
Daniel Scott
Jun 14, 2010 | HP Office Equipment & Supplies
HP LaserJet M1522nf Multifunction Printer (CC372A) Logo
609 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
