Question about GE Refrigerators
Ge profile psc25psw the front board not working but every thing work okey ,the board is touch screen and say home, help, lock,water,crushes,cubed the board not show any power.
GE refrigerator cooling but not properly..... I had the mother board changed one or two years ago for a similar problem..... not sure if that the problem again. Wondering if that a common problem with this refrigerator. model number psc25psw
Posted on Jun 27, 2012
fridgetech
  • 473 Answers
SOURCE: side-by-side GE TFX25JRYWW
There is a metal rod on the ice bucket that fits into a solenoid at the back.  Pull out the bucket and make sure the solenoid is pulled down.  Put the bucket back in and see if cubes work.  If not then replace the solenoid.  You can get it at http://www3.sears.com/.  Part # WR62X58 and cost is $29.27.  You should hear a loud click if the solenoid is working.  If your able to check to see if you have voltage to that solenoid when activating the ice dispenser.
Posted on Oct 25, 2007
SOURCE: Icemaker problem crushed only not cubes
I looked at the plastic piece the solenoid was moving (from Guest's comment 03/07/08). Pushed the plastic piece up (had to push pretty hard) and it reset the solenoid to its' start/beginning position(-?) Plastic piece came back to lower position - was free to move up and down. The solenoid is working now (hear the loud clicking and see it pulling the plastic piece up) to get cubed ice, instead of putting it thru the crusher.
Posted on Mar 15, 2008
  • 184 Answers
SOURCE: Ice dispenser only dispenses crushed ice
THE WAY A DISPENSER CHANGES FROM CUBES TO CRUSHED ICE IS BY RAISING AN ARM THAT RUNS ALONG THE BOTTOM OF THE ICE BIN. IF IT SETS FOR A LONG TIME, IT CAN GET A BUILUP OF FROST OR ICE THAT KEEPS IT FROM MOVING. PULL THE ICE BIN OUT AND TRY TWISTING THE END OF THE ARM MANUALLY. IT SHOULD OPEN A DOOR AT THE FRONT OF THE BIN THAT WOULD ALLOW THE ICE TO BYPASS THE CUTTER ASSEMBLY.
ALSO,WITH THE ICE BIN REMOVED, PUSH THE DOOR SWITCH BUTTON CLOSED BUT KEEP THE FREEZER DOOR OPEN. WHERE THAT ARM GOES IN THROUGH THE BACK WALL, CHECK FOR MOVEMENT OF A ROD UPWARD WHEN YOU CALL FOR CUBED ICE. IF YOU HEAR A LOUD HUM BUT THE ROD DOESN'T MOVE, YOU MAY NEED TO REPLACE THE SOLENOID ASSEMBLY IN THAT MODULE.
Posted on Apr 10, 2008
MNTECH
  • 1543 Answers
SOURCE: Ice cubes will not dispense, but crushed ice will. GE Profile TPX24PRYA
If the auger motor turns in either setting we know that the auger motor is OK, and if it does not turn in both crushed and cubes that leaves a problem with the WR55X129 time delay, which is the part that you switch to go from cubes to crushed to water.
Posted on Dec 08, 2008
SOURCE: ice dispenser will not switch back to cubed from crushed
Had the same problem, dispenser stuck on crushed ice, even when cubed ice is selected.  There is a magnetic switch behind the panel where the motor for the ice dispenser is.  It gets water in it and freezes so it is not free to go up and down.  It is always down for crushed, but for cubed ice, the magnet pulls it up.  when it's frozen with ice, all you'll get is crushed.  You'll have to defrost it.  You can defrost the whole freezer, but better to just remove the ice dispenser and defrost that. Three 1/4'' bolts hold secure it.  You'll have to unplug the wires from the back of the freezer to remove the unit. The just let it defrost and dry. You can remove the switch from the panel and dry it out too.   I've had to to this several times and am looking for a solution to keeping water out of the thing so it won't freeze again. Has anybody solved that?
Posted on Mar 28, 2009
Ice maker only delivers crushed...cube option not working
The control board is probably bad. Replacing it might fix the problem.
Dec 31, 2010 | GE Profile 23.1 Cu. Ft. Side-by-Side...
Cubed Ice selected, crushed ice comes out
ice maker works. water thru the door works. lock works. light works, alarm works.
when i try to get crushed, ice cubes or quick ice.
nothing happens
Aug 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Cubed and crushed ice will not dispense
it sounds like your heater on the ice maker this needs to work in order to get ice. usually you have to replace the ice maker
Aug 12, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ice dispenser does not work and water dispenser works rarely.
the solenoid fell off, where does it go, it must regulate crush ice vs cubed ice. everything works except this
Jul 23, 2009 | GE Profile PSW26P Stainless Steel Side by...
My icemaker, a ge profile is only making crushed ice, no cubes,
There is a selector for crushed or cube and is usually at the dispensor.or above it. good luck
May 26, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ice maker only dispenses crushed ice, won't dispense cubed ice anymore.
I have a GE TFX25ppbaaa refrigerator. The ice maker corkscrew motor would run and provide crushed ice only. The corkscrew motor would not run when the switch was moved to the cubed ice ( half moon) setting.
I replaced the large Light/ water/ crushed ice/cubed ice switch , ( product service number GEH WR55X129 ) ( part number GE 162D6372 PO17 )and it fixed the problem. Cost was about $43.00.
Apr 17, 2009 | Refrigerators
Ice crusher has stopped crushing
Replace the switch behind the front panel on the freezer.
Mar 01, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
PSS26SGRD GE side by side
could be just the board on the dispenser only. not the main board or mother board.
just a little bit hard to replace because of the problem on how to open the front dispenser.
tnx 4 using fixya,
drcool
Oct 21, 2008 | GE Profile¿ 26.5 Cu. Ft. Stainless...
GE Profile Refrigerator
Unplug it for around 30 mins. then plug it back in and see what happens. Try this before anything.
Dec 26, 2007 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
159 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
