Question about Canon PowerShot A550 Digital Camera
Card Locked After downloading pictures to computer, the camera indicates a message: Card Locked. What should I do to fix this problem.
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 480 Answers
Hey thomas8833,
The type of memory card this camera uses is called a SD card which stands for secure digital. On SD cards there is a tab on the side of the card that can be switched between the locked and unlocked position. If you have the tab set to the locked position the camera should not let you write any new images to the card, or erase any images on the card. I would try unlocking the card. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Posted on Jul 09, 2008
    Genius:
  • 1,036 Answers
If it is an SD memory card, there is a switch actually on the edge of the card. Try moving it to the other position and reinstall. Most people don't realise it's even there untill they have problems.
If this works , please rate accordingly so others may follow.
Thanks.
If it doesn't, there will be access to view the locked photo's on the camera. Selecting protect/ lock again should remove this.
I try to take a picture and this comes on the screen write protect.
This is a common problem with SD & SDHC type memory cards - and is easily fixed.
Remove the card from the camera and inspect the edge for a sliding tab and lock indicator.
690144df-2144-46c7-9b90-dd85c207a09b.jpgYou can see the tab & lock indicator on the left side edge in the picture of the front of the card above. Slide the tab UP - away from the lock position - as shown in the picture. The card is now able to be written. When the tab is in the lock position, the card may only be read.
Carefully reinsert the card into the camera - taking effort to see that the tab is not bumped / moved back into the lock position. You should be able to take pictures and have them saved to the card - without the locked message from this point on.
I hope this helps & good luck!
Aug 02, 2013 | Canon Rebel XT / EOS 350D Digital Camera
"Card Locked" message comes up periodically and
Switch of the camera and eject the memory card. carefully take a look @ d side of the memory, u'll find a botton with an indication of Lock and Unlock. Move the botton to the Unlock indication.return the memory card back into the camera carefully and dats all.
Oct 10, 2011 | Polaroid i633 Digital Camera
My camera suddenly had the message "card locked!".
If this camera uses SD cards then what may be happening is that the little lever that drops into the slot on the side of the card to indicate locked or unlocked is jammed in the locked position. If you shine a flashlight in you might be able to see where the pin is.
May 05, 2011 | Canon PowerShot SD880 IS Digital Camera
Memory card is locked, how do I unlock this?
Problems typically are pretty rare with Panasonic Lumix digital cameras. On those occasions where you do have an issue, though, look for an error message on the Panasonic camera for some clues as to how to fix the problem.
he seven tips listed here should help you troubleshoot your Panasonic camera error messages.
  1. Built-in Memory Error error message. If you see this error message with your Panasonic camera, the internal memory area of the camera is either full or corrupted. Try downloading photos from the internal memory. If the error message continues to appear, you may need to format the internal memory area.
  2. Memory Card Locked / Memory Card error message. Both of these error messages are related to the memory card, rather than the Panasonic camera. If you have an SD memory card, check the write protect switch on the side of the card. Slide the switch up to unlock the card. If the error message persists, it's possible the memory card is corrupted and needs to be formatted. It's also possible the memory card was formatted using another device that is not compatible with Panasonic's file structure system. Format the card with your Panasonic camera to fix the problem ... but keep in mind that formatting the card will erase any photos stored on it.
  3. No Additional Selections Can Be Made error message. If your Panasonic camera allows you to "save" photos as your "favorites," you may find this error message because the camera has a limited number of photos that can be labeled as favorites, usually 999 photos. You cannot mark another photo as a favorite until you remove the favorite label from one or more photos. This error message also may occur if you're trying to delete more than 999 photos at one time.
  4. No Valid Picture error message. This error message typically refers to a problem with the memory card. Most of the time, you'll find this error message when you try to play back images from the memory card and the memory card is corrupted, empty, broken, or has been formatted with another camera. To fix the memory card, you must format it, but formatting a memory card causes all photos stored on it to be lost. Try inserting the memory card in another device or in your computer and try downloading any photos stored on it before formatting it with your Panasonic camera.
  5. Please Turn Camera Off And Then On Again error message. At least this error message says "please." This error message most likely occurs when one of the parts of the camera's hardware is malfunctioning, usually a jammed lens housing. To try to fix this problem, start by turning the camera off for a few seconds before turning it back on. If this doesn't fix the problem, try resetting the camera by removing the battery and memory card from the camera for at least 10 minutes. Replace both items and then try turning the camera on again. If the lens housing is jamming as the lens moves through its zoom range, try gently cleaning the housing, removing any debris or grime. If all of these steps don't fix the problem, you'll probably need a repair center for the camera.
  6. This Battery Cannot Be Used error message. With this error message, you've either inserted a battery that's incompatible with your Panasonic camera or you've inserted a battery that has dirty contacts. Gently clean the metal contacts with a dry cloth. In addition, make sure the battery housing is free of debris. You sometimes may see this error message if you're using a battery that's not manufactured by Panasonic. If the third-party battery is working OK to power the camera, you probably can ignore this error message.
  7. This Picture Is Protected error message. You'll see this Panasonic camera error message when the photo you've selected has been protected from deletion. Try working through the camera's menus to figure out how to remove any protection labels for the photo files.
Keep in mind that different models of Lumix cameras may provide a different set of error messages than is shown here. If you are seeing Panasonic camera error messages that aren't listed here, check with the user guide for your model of Panasonic Lumix camera for a list of other error messages, or visit the Support area of the Panasonic Web site.
Jul 11, 2010 | Panasonic Cameras
I was taking pictures outside on a cold day and the camera froze - after warming it up I was able to take more pictures but I thought I lost all the previous ones. I subsequently took about 50 pictures and...
Could be a problem with the "no. reset" in the menu. I would go into the menu and find the regular "reset" and follow the on-screen instructions to get your camera back to factory settings. Then, format your card in the camera.
Feb 07, 2010 | Panasonic DMC-ZS1 Digital Camera
Photo card locked and can not take pictures.
There should be a tiny slide switch on the side of the card. Merely slide this switch to the other "unlocked" position.
May 28, 2009 | Canon PowerShot SD500 / IXUS 700 Digital...
My Canon Powershot A560 memory card is locked and it is the camera doing it not the memory stick.And there is nothing in the manual about how to fix it. When I turn on my camera I get an error...
Remove the memory card from the camera. Note that there is a small slide switch on one of the long edges of the card. Slide the switch to unlock or lock the card.
Apr 26, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Memory card locked
There is a tiny button on the side of the card - so small you can hardly see it. Just slide it up and voila All is solved.
It is frustrating as there is nothing in the manual bout this and the onl line assistance wants to charge for 20 seconds advice Mine is free dorothy
Mar 24, 2009 | Canon PowerShot SD800 IS / IXUS 850 IS...
Not Able to download pictures from Vivitar 5188 using Windows Me.
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa.
Nov 02, 2008 | Vivitar Vivicam 5105s Digital Camera
Canon PowerShot A550 Digital Camera Logo
88 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
