Question about HP Color LaserJet 2600n Printer
Cleaning My printer is not printing clean crisp copies. It looks like the roller or something is dirty and resdue is getting on all the copies. How do I clean?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • HP Master
  • 1,362 Answers
Depeds on where it's coming from. Open the front door, is there toner on the big black belt? if yes get a clean dry cloth and wipe , turn belt at edges only. It may be that the toner is leaking, after markets sometimes do that.
Posted on Jul 21, 2008
Aficio 1018 dirty copies
Remoe the image unit,remove the OPC drum ,clean the opc drum cleaning blade(if necessarry change),remove the transfer unit clean the transfer belt cleaning blade,and clean the polygon glass.
Jan 31, 2013 | Ricoh Aficio 1018 Printer
Paper not clean when printing/copying How do I
first the paper can be dirty in a lot of ways...
i.e.
If you have dark "background"or small black dots, the problem is in developer and it need's to be replaced, or cleaning blade or drum.
If you have streaks on copy, the problem can be in drum and cleaning blade or fixing roller.
If the copy is too light, the problem can be in dirty optics or bad transfer corona.
There can be a lot of things... better call service for preventive maintenace, they will change all that is needed according the number of copies that machine has.
Hope that helps!
Sep 01, 2011 | Toshiba E-Studio167 Copier
I have a sf 2035 and am getting black lines on copies
could be multiple things.
Does it do it when you print a counter page?
No>
mirrors or glass are dirty.
Yes>
Charge roller
drum
drum cleaning blade
or fuser rollers
difficult to tell which one without looking at it.
Good luck
Feb 25, 2010 | Sharp Office Equipment & Supplies
Dell 5100cn printer printing yellow lines across the page.
This can be any of rthe following depending on the position iof the lines on the page. You need to establishe the position of the lines relative to the top of each page and this determines which of the following component will cause the problem
Dirty or damaged developer roller.
Dirty or damaged charging roller.
Dirty or damaged cleaning roller.
Dirty or damaged developer DSD wheels. These wheels are located on the outer ends of the color toner cartridge and appear as a black bushing.
Dirty or damaged transfer roller.
Dirty or damaged transfer drum.
All of them need inspecting and cleaning
Sep 23, 2009 | Dell 5100cn Laser Printer
Black bar printed in the center of copied document
try copying the document to your computer and then from computer take a print out.
Aug 23, 2009 | HP Photosmart 2575 All-In-One InkJet...
Ghost lines horizontally (looks dirty) when making multiple copie
Check the cleaning blade of the OPC drum,the image transfer unit.
Aug 17, 2009 | Canon Office Equipment & Supplies
Copy with dirty paper
This machine sounds like it needs a service. Is the paper dirty before it reaches the fuser unit? You can check this by opening the door while the machine is printing (if you're quick), if the dirt is on the copy before it is fused to the paper then the origin of the dirt is in the process area - clean the area particularly check the cleaning assembly and clean the transport bed (the assembly that pulls out with a green handle been turned to the left). If it is after fusing then your fuser roller and/or cleaning web (roller) is worn and/or dirty. Some techs wind back the cleaning web to buy more time - good luck
Canon Copier Service Manuals
Jun 08, 2009 | Canon NP 6050 Copier
Printing
Your print head may be dirty. Remove the ink carts and examine the print heads.
You should also examine the printer for a printer head parking location or cleaning pad (usually off to one side, where the cart sits when not in use or there is a pad on the side to use in cleaning the print head.)
If the print head is dirty, clean it with a soft cloth.
If the landing pad or cleaning pad is dirty from a leak, you may need to remove it or replace it.
Does printing sound normal? It is also possible that worn rollers may cause the page to advance incorrectly.
May 06, 2009 | Lexmark X7350 All-In-One Printer
Pages are coming out "dirty"
dont know for sure but the older ones had a sorter wiper looking thing that u had to open a lid over a cyclinder after u popped open the thing . the toner is somehow getting to much toner somewhere...run 20 copies though it and see if it dont get better. wipe rollers down with laquer thinner on rubber only..dont get it anything plastic larry
May 15, 2007 | HP DeskJet 3550 InkJet Printer
HP Color LaserJet 2600n Printer Logo
285 people viewed this question
Seeker5211
Seeker5211
