Question about Garden
Diagram for a 3-way switch - Garden
  • Jeffrey Cameo
    Jeffrey Cameo Jan 03, 2011
    What type of 3-way switch(for AC wiring or for DC). What is the model number/make etc....the post is listed under chain saws..need model info/symptom
  • Cameron
    Cameron Mar 06, 2014
    mon426
Diagram for 3-way and 4-way switching can be seen on following link.
3-way diagram applies to switches only (and not to 3-way timers or dimmers, which may add specific variations to wiring).
http://waterheatertimer.org/ST01C-program.html#3-way
Notice that the dark screw is key to wiring 3-way circuit.
Each 3-way switch has 1 dark screw (the common screw) and 2 brass screws (travelers) ... and a green ground screw.
Also see more electrical information:
http://waterheatertimer.org/See-inside-main-breaker-box.html
http://waterheatertimer.org/B220C.html
http://waterheatertimer.org/Install-owb.html
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on circuit.
Posted on Jan 04, 2011
Need wiring diagram
Wiring diagram for a 3-way switch, one of the many wiring diagrams showing different methods of wiring a three way switch circuit. This electrical wiring diagram shows power into light switch Box #1 – wire to light from switch box #1, and from switch box #1 to three-way light switch box #2.
Jan 06, 2016 | Holmes Products Heating & Cooling
Wiring diagram for 3 way 2 socket lamp
Where is the switch located? If you buy a replacement switch at Home Depot it usually comes with a diagram that shows you how to wire it. If the switch is built into the light socket just replace the socket the switch is included.
Jul 29, 2014 | Leviton Electrical Supplies
Two way light switch diagram
I believe you are looking for a 3-way diagram. 3-ways operate lights from two locations. Here is a diagram:
Jan 13, 2014 | Electrical Supplies
How to wire a two way switch for a staircase
Copy following link for 3-way switch wiring diagram:
http://waterheatertimer.org/How-to-wire-switches.html#3-way
Add a comment and say if you are adding a 3-way switch to existing single-pole switch.
You need 3 wires running to new 3-way switch.
Mar 16, 2013 | Electrical Supplies
Replace the speed control switch in 3/8 Hole shooter No. 0228-1
Try this link. The speed control is done by what Milwaukee calls the remote.
Wiring diagram
Jul 20, 2012 | Drills
Westinghouse fan wiring diagram
Copy following link for general assistance wiring 4-wire ceiling fan switch:
http://waterheatertimer.org/How-to-wire-Cooper-277-pilot-light-switch.html#3-speed
Jul 14, 2012 | Electrical Supplies
Three way electrical switch diagram
Copy following link for 3-way switch wiring diagrams:
Dec 06, 2011 | Electrical Supplies
Load between 3 way switches and line entering switch box. Breaker trips when both switches in down position
Test your wires.
Somehow you've got a neutral wire, or ground wire, or shorted wire connected to one of the switches.
Without a wiring diagram, best place to start is identify hot wire from breaker.
There should be only 1 hot wire connected to the switches.
Disconnect the hot wire. Then test hot wire to each other wire and screw terminal. Tester will light up on neutral or ground fault. That will narrow down the suspects.
Open following link for example 3-way wiring diagram:
http://waterheatertimer.org/How-to-wire-Cooper-277-pilot-light-switch.html#3-way
Aug 22, 2011 | Electrical Supplies
I NEED A WIRING DIAGRAM FOR THE SWITCH ON AMODEL 7191 TYPE 3 , 3/8 B&D DRILL
i don't think you will find a diagram for the switch. find a parts schematic and order a new one. they aren't make to be fixed.
Aug 02, 2010 | Black & Decker 3/8" Variable Speed...
I need the wiring diagram of pump it has 5 pins coming out of pump
hello, i holding a wiring diagram central locking system,model 201,it have a 6 pin,
  • pin no.1 brown goes to ground
  • pin .no 2 black ignition on
  • pin no. 3 red permanent 12 volt
  • pin no. 1 yellow trunk lid switch
  • pin no. 2 blue driver door switch
  • pin no.3 green passenger door switch
hoping it"s help to solve your problem,ty
Apr 28, 2009 | Mercedes-Benz 190-Class Cars & Trucks
Garden Logo
604 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
