Question about Dmm Antonio Miro by Supergrif Extention for high lavatory 120 mm - 039120110
Trying to locate a supergrif cartridge with the number pb-40 c/d stamped on it
Looking for a serial number for a back pack echo pb-413h blower
if unlucky lost its serial number sticker from petrol spill/heat
if lucky something stamped into the alloy housing of assembly
most mower repair shops can track down sample parts without the serial number
a factory limit of hours on blowers are as little as 100 hours
unless it came with the user book from new purchase
you may never know
Jan 13, 2017 | Echo Garden
Where is the stamped chassis number for ML320 cdi 2001 model?
Try this site, Good Luck.http://www.mercedesmlclub.com/vin_plate.html
Aug 05, 2016 | 2001 Mercedes-Benz ML 320
HOW DO I buy a US postage stamp Printer?
You can print US postage stamps on a standard office printer to print postage by the sheet or using a specialty roll printer like the Brother QL-700.
http://www.pb.com/smb/online-postage-stamps/overview/print-stamp-sheets
This is one example from Staples.com:
http://www.staples.com/Brother-QL-700-Label-Printer/product_356066
Sep 10, 2014 | Office Equipment & Supplies
Where is the engine number located on a 225 motor slant6 crysler
There should be a casting number on the side of the block, and a stamping number stamped into a flat surface behind the alternator. The stamping number is the serial number.
Jun 09, 2013 | Cars & Trucks
I'm trying to locate a cd changer cartridge for my alpine cd changer in my 2000 bmw 528i.. hopefully locally
whats the model number of the alpine changer??? they usually sell for about $40-49 plus shipping. where are you located??
Mar 30, 2011 | Soundgate Abmw35v5 Alpine Cd Changer...
What is wrong with my single handle shower fixture in that it does not give out enough hot water
This is a common problem with Moen shower valves and fairly simple to fix. The pressure balancing cartridge is sticking inside. You need to remove the cartridge and clean it with white vinegar. The problem appears in valves that are not used very often - like in a guest room shower. The impurities in the water leave a varnish-like residue that causes the element to lock up and restrict hot water flow. If you are the original owner Moen will send you a free replacement cartridge but cleaning the one you have will do the trick. Once it's working be sure to run the hot water at least once a week. Here's how to fix it:
1. Turn off water supply to the house or at the PEX panel if you have one.
2. Remove handle by loosening the set screw at the bottom of the handle and pulling off.
3. Remove escutcheon plate by removing 2 screws on the face.
4. Remove escutcheon tube surrounding the valve by pulling with a needle nose pliers.
5. Using an awl or small screwdriver pry the retaining clip up and remove - DON'T DROP IT behind the tile!!
6. Using a pliers, pull out the cartridge. If it won't budge you can try some WD-40 or PB Blaster and if that doesn't work you'll need to buy a "Moen Cartridge Puller" (about $13 @ Home Depot) and it will come right out.
7. Shake the cartridge. If it does NOT rattle you've found the problem. Soak it in white vinegar for 15 minutes and try shaking it again and repeat till you hear the pressure balance element move back and forth. A shot of PB Blaster also helps.
8. Once the element is moving freely you can reassemble everything by working in reverse - don't forget to reinstall the retaining clip or the cartridge will become a missile! TIP: To prevent dropping the clip tie a string through the hole in the top and tape the other end to the wall. If it slips you can just pull it up. Also, spray a little PB Blaster in the valve body before inserting the cartridge to make it easier to seat it.
Hope this helps!
Sep 27, 2010 | Moen & Posi-Temp Single Handle Shower Or...
DVD won't play movies in color
RCA cable connectors (red,white, yellow) are usually for an analog setup. You could still use these for "component" setup, but know the difference with color stamps as follows:
Component color stamps are "blue, green, red" ( blue is marked Pb, green is marked Y, red is marked Pr)
RCA color stamps your using are "red, white, yellow"
Here are the proper hook up method for "Component" using your "RCA" connectors:
On both the TV and DVD component setup:
Plug the red RCA fitting in the component port marked "Pr (red)
Plug the white RCA fitting in the component port marked "Pb (blue)
Plug the yellow RCA fitting in the component port marked "Y (green)
Be sure this setup is the same for the TV's component input ports, and the DVD's component output ports.
i-Note:
For optimum picture quality you may want to purchase component cables as the gage is thicker giving better impedance match resulting in better picture and sound quality.
Jan 25, 2009 | Vizio Televison & Video
Toner Light
Hi.
Its nearly what the last post states,
I have had brother help desk on the phone recently due to this problem. If you get a toner cartridge that has no numbers on it, ( brother orginal parts have huge numbers stamped on the case) then the cartridge needs resetting, this is done by simply pushing the white lever on left handside about 40 degrees forwards, its stiff so give it a proper hard shove. No srews etc to undo.
Hey presto your light will go out.
Cheers
JPW
Jun 09, 2008 | Brother HL-2030 Laser Printer
Pitney bowes 1530 / INCOMING fax date/time stamp
For the UF-595 here's how you turn the fax stamp on:
Function + 7 + copy/set for enter
scroll to option 4 + copy/set
Hit 04 + copy/set and enter number 2 to turn the fax stamp on. 1 turns it off.
Scroll to or enter 28 and choose 2 to turn the fax stamp on for faxes stored in memory for later use.
You hit the "clear" button to wipe out the current number before you enter 2 or 1 for the new entry.
Jan 08, 2008 | Panasonic Panafax UF-595 Plain Paper Laser...
Dmm Antonio Miro by Supergrif Extention for high lavatory 120 mm - 039120110 Logo
288 people viewed this question
Top Dmm Plumbing Experts
Donni Steen
Tom Chichester
Are you a Dmm Plumbing Expert? Answer questions, earn points and help others
