Question about Plumbing
How to remove plaster of paris (hardened) from a PVC pipe ? The empty electrical condute (3/4" Pipe) embeded in the floor & 18" elevated on wall. Before the cabels to be pulled out some mischieff poured the plaster of paris in those pipes & those been blocked. The floor & wall is been finished with tiles. Now i have to remove the plaster of paris from the pipe then only i can run the cables thru the pipe.
  • 731 Answers
You can disolve plaster of paris with an acid.
I would try something weak to begin with like vinegar.
Pour some in the pipe and let it sit.
I'd then use a drill driven pipe snake to try to break it up
Good luck
Posted on Jan 03, 2011
MY GE PRESSURE RELIEF VALVE HAS JUST STARTED LEAKING. WHAT SHOULD I DO ? GE SMART WATER HEATER GELN0705CO3984
You can buy a replacement relief valve at any hardware or home improvement store. It's real name is a T&P valve or temperature and pressure relief valve. It always has a 3/4" inlet and outlet. It is a very easy procedure to replace. You will need a bucket, teflon pipe thread tape, and a 3/4" x 6" black iron or galvanized pipe nipple. To start the valve replacement, turn off the shuttoff valve on the cold water line. Then open the handle on the relief valve and drain water into the bucket, that is, unless you have a pvc pipe coming off of it into a drain floor, then just drain it without the bucket. Be careful, the water is hot! When the water level gets below the relief valve, it will stop draining. Then remove the pvc pipe, if applicable, and thread in the 6" pipe nipple to use as a leverage tool to remove the valve from the water tank. Turn it counter clockwise to remove. Then put teflon tape on the new valve, going from left to right with the valve threads facing downward. Wrap about 3-4 layers all around the threads. Then twist the new valve into the water tank clockwise and using the pipe nipple tighten by hand until very snug and outlet is facing downward, as before. Remove the pipe nipple and install pvc pipe, if applicable. Leave valve handle open and turn on the cold water until the valve starts spitting, then close the relief valve and let it fill up the tank. If you did it correctly, you are now finished! Good luck!
Douglas
Jun 14, 2010 | Water Heaters
Any way to take apart cemented pvc drain pipe
if the drain is slow or stopped up, i use a high powered drain opener from ace hardware called "liquid fire" it is different from drano and all that other ****.
Apr 12, 2009 | SAIT Portable Saw Cut-Off Wheel TM 12 x...
Kenmore Washing Machine won't drain properly, overflows at PVC pipe. I can run a gardenhose all day long and it won't overflow. But as soon as the Wash Machine Pump starts to empty the basin I can her the...
Check your waste pipe roof vent.
If it is not free (of dead animals leaves etc) - it creates a suction - rather than a drain in your pipe.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 30, 2009 | Kenmore Washing Machines
Plumbing Logo
937 people viewed this question
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
