Question about Electrolux Oxygen Z5540 Pet Lover Vacuum
Probleme sur aspirateur electrolux Z5540 voyant rouge clignotant ainsi que jaune l'aspirateur est à l'arret pas moyen de remettre en service que faire svp?
I have a new Electrolux 4300A (Ultraactive Deep Clean Canister) and the powerhead brushruoll has stopped working. Where is the reset button?
I have repaired many of these and to be honest your best course to to call Electrolux Home Care and find your nearest warranty station. The reason for this is it should cost you nothing and without the on ohm meter and a prior knowledge of how these are put together, you would not be in for a fun afternoon. Call them and explain the problem, most likely you have a broken or pinched wire in the neck assembly and will need a replacement. The wires to the neck attach directly to the main circuit board near the height adjustment, but to retain your warranty call Electrolux now... put down your mouse and call them so you can go back to enjoying your recent purchase with confidence.
(800) 896-9756 Monday-Friday, 9AM-8:30PM (EST)
Saturday-Sunday, 11AM-7:30PM (EST)
Nov 13, 2013 | Electrolux 75922-4 Beam 045056 Power Head
Need manual model aspirateur
What model and make are you talking about?
Sep 14, 2013 | Electrolux Central Vacuum
Change fuse for power head
salut leo as tu un probleme avec ton aspirateur ,,moi je vien de reparer le mien ,,si tu as des question ecrit moi et si je peut aider ca me fera plaisir...
Mar 25, 2013 | Hoover S3670 WindTunnel Bagged Canister...
How do I open a Miele s5310 vacuum to get access to the motor
Connaissez-vous la m?thode pour ouvrir un aspirateur Miele S5310 car le contacteur Marche/arr?t ne fonctionne plus.
merci de votre aide R?my
Jun 13, 2012 | Miele Vacuums
Jai un probleme dans la tv daewoo lecran est toujours atteint mais le sens est bien et avec alimentation jai entendu un sens dans la blaque electronic je sais quoi exactemet et merci
Bonjour, Je ne suis pas sûr que le problème est parce que je ne parle pas de français, mais ai une fonction traduit sur mon navigateur. Voici un site Internet que je pense pourrait répondre votre question : s'il n'aide pas, vous pourriez demander à ce site: forum.hardware.fr/.../plasma-daewoo-42nesi-sujet_70005_1.htm
+ HaPlease placent un vote pour moi. Remerciements.
Apr 20, 2011 | Vacuums
The filter gives red light.Does this mean the filter must be washed or changed. How should it be washed, what does ´´washable´´ mean here?
Red light normally denoted filter is blocked. If it is a washable filter then wash it. If it liiks like a paper type filter, replace it. Washing it will make it clog up even more.
May 28, 2010 | Electrolux Oxygen Z5540 Pet Lover Vacuum
I have an Electolux Oxygen canister vacuum and the power head suddenly stopped working. It is only a few months old. Any suggestions.
1. You have to verify if it's simply the belt that has broken and the spinning brush isn't spinning because of it. Place your ear next to the top of the power head to listen for the power head motor. If electricity is getting to the head you'll hear the motor and know to inspect the belt.
2. If the motor doesn't run, look at the electrical pin connectioins in the pipe from the hose to the head. Are they burnt? If yes a new wand is needed. Also check the electrical connections in the hose handle and make sure they are not burnt.
Let me know if this helps
Oct 09, 2009 | Electrolux Oxygen Z5540 Pet Lover Vacuum
Je nai pas de pression au bout de la brosse
Je suis désolé mais Fixya a seulement une version anglaise en ce moment. Cependant ce site vous permettra de copier et coller n'importe quelles réponses vous pouvez devoir votre problème pour que vous pouvez les lire en français. Vous pouvez taper aussi votre question sur ce site et cette copie et ce passé la traduction l'anglais sur Fixya pour une réponse plus rapide des experts.
Le site de traduction mentionné est un site de traduction libre. Juste être sûr de choisir les langues correctes pour la traduction à et de.. (L'anglais à français ou français à l'anglais) et utilise le bouton de Traduction LIBRE.
http://ets.freetranslation.com/
Merci pour utiliser de fixya. ..and j'espère que ceci aide ! ! !
Dec 22, 2008 | Polti Eco Pro 3000 Canister Steam Vacuum
Vacuums Logo
110 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
