Question about Garden
8 hp craftsman snow blower starts then stalls out shortly and then cannot restart unit. Also what is sparkplug gap plse
    Brigadier General:
  • 4,088 Answers
Remove the fuel line at the carburetor to see if fuel will run out--it should run in a thin stream, but if it just drips or nothing comes out, then check the fuel filter, fuel line, and any shut-off valve for plugging. If fuel does flow out, the remove the carburetor and clean the interior with spray carburetor cleaner. Remove the float and float needle--check the passage behind for any plugging. Make sure any screw-in jets are not plugged. Make sure the air cleaner and muffler are not plugged. The spark plug should be about 0.025". Hope this helps!
Posted on Jan 04, 2011
  • Anonymous Jan 04, 2011
    Thank you for your response. It is greatly appreciated I will try the fuel line and see what happens. Thanks again.
Is the spark plug on my new snow blower already set to the .30 gap at delivery?
It,s already set to specs when u buy it u need to call The service center or store where was bought...being new u should not do anything to some thing new and still under warranty
Nov 10, 2014 | Craftsman 21" 179cc* Single Stage...
Snow thrower backfires and stalls
sounds like carb needs cleaning or plug changed
id do both
Jan 30, 2014 | Craftsman Arnold Mtd Snow Thrower Blower...
Snow thrower
you need to thin out your mixture on the carb. should solve this.
Igition coil gap for craftsman model 536886621
ALL ignition coils are gapped at about .010 or ten thousand. Rule of thumb, normal business card inbetween flywheel and coil
Dec 21, 2013 | Craftsman 536.886520 Snow Blower
What is sparkplug gap on 8 horse tecumseh snow blower
Clif - I have two items in my garage with Tecumseh engines on them in that HP range and they both specify .030 spark plug gap in the instruction manual.
Dec 03, 2013 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Starts and runs, stalls out. rebuilt carb same problem??
at what point does it stall out? when you try to go to full throttle or while it is just idling?
Feb 13, 2013 | Craftsman Snow Blower / Snowblower Bottom...
2002 craftsman 23 hp kohler pro series stalls and wont restart
try playing with the throttle adjustment or it could be a saftey feature malfunction, like the seat shutoff for example.
Feb 25, 2009 | Craftsman Garden
I have craftsman snow blower 5 hp 24inch model #
does the impeller spin and not the augers.if so check sheer bolts.if neither impeller or auger spins check auger belt.
Feb 22, 2009 | Craftsman 16" High Garden Tractor Snow and...
Snow thrower won't stay running
Replace the spark plug being sure to use the plug recommended in your owner manual, and the gap recommended. Then clean or replace the air filter. Finally use high test, new gasoline. Not gas that has been sitting around for months. good luck
Jan 11, 2009 | Mowtownusa Snow Thrower Starter Switch for...
Garden Logo
157 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
