Question about Sony BRAVIA KDL-40S2010 40 in. LCD Television
Sony bravia v series 32"
    New Friend:
  • 95 Answers
IT normally happens after factory reset is done. You need to reprogram the channels. Try the auto program (AUTO TUNING) Process.
  1. On your remote commander " Press HOME or MENU button"
  2. Scroll down to " SETTINGS or SET-UP"
  3. Then to "CHANNEL SET-UP"
  4. Select " AUTO PROGRAM " To Auto program your LCD TV and it's done..
Posted on Jan 05, 2011
    New Friend:
Plz tell me all settings of suny bravia such as brigthness,,color, backligth, and sharpness,,,plz tell me tha standerds of these one..because my kid has change all of these ,,thankss
Posted on Apr 22, 2014
    New Friend:
Can u help me? i have a kdl 32v5500 television. what's the reset code for it?
1000tx
Posted on Sep 25, 2013
    New Friend:
I need to restore CTV channel 7 on my Sony Bravia TV
Posted on May 31, 2013
SOURCE:
My Sony Bravia KDL-19M4000 no longer displays the TV guide? Also when I change channels it displays, "No Program Title Available". How can I reset to correct these problems?
do a reset to this set, and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done...
Aug 22, 2016 | Sony Bravia M-Series KDL-19M4000/G 19-Inch...
Tip
ERROR CODE AND POWER SUPPLY CIRCUIT
Viewing the Self Check Diagnostic List
1. TV must be in standby mode. (Power off).
2. Press the following buttons on the Remote Commander within a second of each other:DISPLAY > Channel 5 > Volume - > TV POWER .
Results for all of the following diagnostic items are displayed on screen. No error has occurred if the screen displays a "0".
NOTE: If the Service Menu display text is not completely visible, press the Menu HOME button on the Remote Commander to refresh the display.
3. To exit Self Check display, turn the power off. Press [Menu] Exit.
Clearing the Self Check Diagnostic List
1. In Service Mode, press the Channel 8 Channel 0 .
RESETTING TO FACTORY DEFAULTSUse the following instructions to restore the User Controls and
Channel Memory settings to the preset factory conditions.1. While holding down the UP ARROW on the Remote Commander, press the POWER button on the right side of the set.The set restarts and displays the initial setup screen. This may take several minutes.
White Balance adjustment
1. Allow approximately 30 minutes for the set to warm up before proceeding with the white balance adjustment.
2. Connect the signal source to the 3 terminals of the Component In input (Y/Pb/Pr).
3. Set the Picture Mode to "VIVID" in the user menu.
4. Select the Component In input.
5. Open the Factory Service Menu (see section 3-1.) and select "Service Alignments Menu".
6. Set "White Point Red", "White Point Green", "White Point Blue" and "Black Level Offset Red", "Black Level Offset
Green", "Black Level Offset Blue" to average values .
"Cool " White Balance Adjustment
1. Select "COOL" from Color Tone in Service Alignments Menu.
2. Input 70IRE full white pattern signal into Component In.
3. Adjust "White Point Red", "White Point Green", "White Point Blue" in Service Alignments Menu if needed.
4. Input 25IRE full white pattern signal into Component In.
5. Adjust "Black Level Offset Red", "Black Level Offset Green", "Black Level Offset Blue" in Service Alignments Menu if needed.
6. Repeat steps 2 to 5 to achieve desired White Balance.
FOR MORE DETAILS CHECK THE FOLLOWING LINK
www.electro-medical.blogspot.com
google.com/+AjinGopakumar
USE SEARCH TAB TO FIND MODELS OR USE THE DROP DOWN MENU
on Jun 30, 2015 | Sony Bravia L-series Kdl-32l5000 32-inch...
Tip
SERVICE MODE AND ERROR CODES CHECK
on Jun 30, 2015 | Sony Bravia KDL-26L5000 26 in. LCD HDTV
Sony Bravia has lost all channels besides ABC and 7 Network, this happened while the TV was on, what is wrong?
unless you are on a antenna look in the menu to make sure set is on catv and not air or antenna.
Sep 03, 2012 | Sony Bravia KDL-32XBR9 32 in. LCD HDTV
Sony KDL-32S2010-Chicago area..channel 50.1 (WPWR) is now showing up on 51.3.(found it by accident). 50.1 showing spanish shows. Reinitiated auto tune erased all channels without antenna, then auto tune...
Do a factory reset to this set, and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Mar 27, 2017 | Sony BRAVIA KDL-32S2010 32 in. LCD...
After BBC 1/2 switchover unable to retune these channels.Have Sony bravia KDL32S2510. Help!!!
do a default settings / factory reset if poss rather than a standard retune. After that watch out for too much signal..ie a booster and bypass it if you can.
Nov 06, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Sony Bravia does not see my digital channels
Hi buck lite,
Your cable company is telling the truth, you have digital cable. When auto scanned for digital channels the tv is lookig for OTR(over the air) signals. These are broadcast signals you will need an antenna to receive. Depending where you are and the type of antenna you use you probably could pick up some digital channels. Let me know if this helps and please rate this solution. Lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Jan 20, 2009 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
No picture, blue screen
Use the TV input selector to select the right channel, that should fix it.
Jan 04, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Sony BRAVIA KDL-40S2010 40 in. LCD Television Logo
1,196 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
