Question about Zanussi Washing Machines
How to remove filter on zwf1231w do you drain water from little tube first? The filter cap is vert tight an seems blocked from opening by design?
5 Suggested Answers
  • 3741 Answers
SOURCE: washing machine will not drain. water wont drain
If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems:
  • If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
  • If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Posted on Aug 20, 2009
SOURCE: LG WM2010CW filter drain no draining
In all likelihood the rubber drain hose is clogged. I had the same problem with my LG front loader. The hose was clogged with sand and dirt almost the entire length of the hose. The following solution is far simpler than taking the dryer apart to clear the drain hose. Besides I figure this same thing could keep reoccurring with all the sand and dirt we get in our clothes here in East Texas.
I purchased about 4 feet of 3/16 inch OD vinyl tubing and adapted it to fit on the end of a garden hose. The adapter gizmo included a valve so I could control the water flow and not give myself a bath. A picture of the gizmo is included below. Make sure that when you connect the water hose to the faucet that the faucet valve is just slightly opened and that the gizmo valve is closed. Using the gizmo is straight forward. First remove the drain filter and than insert the vinyl tubing in the end of the rubber drain hose and slowly open the valve on the gizmo. Make sure you have a large pan or bucket underneath the drain hose to catch the debris and water. Slowly advance the tubing up inside the hose until it won’t go any further. By this time water will also be running out of the drain filter cavity which will indicate the clog has been removed. Continue back flushing for a few more seconds to assure all the debris has been cleared, than clean up and you’re finished.
Posted on Mar 16, 2010
SOURCE: Samsung B1045AV cannot drain
if i do the washing, and it nears the rinsing cycle, it stops and error 5e appears... can I replace the pump myself...
Posted on Feb 21, 2011
  • 6277 Answers
SOURCE: (Samsung WF330ANW) The front-mounted debris filter
If I understand you correctly that the filter cap does not come off easily try pouring anticalc/limescale fluid into any gap there is around the cap. Empty the machine and you can switch it off providing the door is open! Then pour the contents of at least 2 sachets of proprietary anticalc powder/liquid into the drum direct together with a kettle full of boiling water. Leave overnight at the very least. The following day run just a spin cycle as then there will be no water diluting the mix. This mix will go through the filter and motor and is likely to help release the filter/cap. If you feel like it, do the overnight again. If nothing else it will ensure that the heater element is clean!
I had to spend a couple of hours gently turning the cap back and forth until it finally released its hold- but the filter did not remain attached to the cap by its rubber ring. More patience, anticalc fluid and all was revealed!
I now run an anticalc clean regularly............which reminds me..............!
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Apr 14, 2011
Wat area is the pump filter on my Samsung washer and dryer combo
How do I clean the debris filter in my front loading Samsung washing machine?. Open the filter cover(A) by using a coin or key.Take one end of the emergency draining tube (B) out.Open the emergency drain cap (C) by pulling it. Allow all the water to flow into a bowl. Note: hold the cap at the end of the emergency draining tube (B) and slowly pull it out. Note: you may need to drain several bowlfuls of water. . Prepare a dry cloth. Wash any dirt or other material from the debris filter. Make sure the drain pump propeller behind the debris filter is not blocked.Replace the debris filter cap tightly.Reinsert the emergency drain cap and the drain tube.ake sure to replace the debris filter and emergency drain cap after cleaning it. If they are not reinserted properly your washing machine may leak or otherwise malfunction.Close the filter cove
Sep 30, 2016 | Samsung Washing Machines
Washer didnt drain all the way and now i keep gettin a code. n the light for the door lock wont come on
If water is in tub and the control tries to drain tub but water doesn't drain, then the unit will not operate. Most LG have a drain pump clean out located behind the access door on lower side of washer. Open the door and you will see a black tube with a cap and a round knob. First, get a bucket, pull the black tube slightly out and remove cap. The water in the tub will start to drain and you may have to fill bucket many times to get all water out. Next, unscrew knob and a little screen will pull out. Inspect this screen and inside of pump chamber. Your looking for any thing that could block the pump. If pump hums and still doesn't drain, the drain pump is more than likely bad. Good Luck
May 25, 2016 | LG Washing Machines
Samsung frontload washer fashing nd code
The ND code means not draining
The older versions of this machine did not have a debre filter, but in later versions a drebe filter was added . It is on the bottom right of the front panel. Open the door. Pull the cap off the drain hose and drain water into pan. Remove filter cap. Wash filter off and don't block propeller when replacing filter cap. Insert cap back in drain tube.
Jun 04, 2011 | Samsung WF328AAW Front Load Washer
(Samsung WF330ANW) The front-mounted debris filter seems unclogged but I get a small gush of clear water, about 1/2 to 3/4 cup, whenever I remove the filter cap to check after a wash. I check frequently...
John C
Apr 14, 2011 | Samsung Washing Machines
My LG washer shoes OE and I don't know what to do??
If I'm not mistaken this is a drain issue so check to make sure nothing has your drain hose kinked or clogged. There is also a drain filter that you need to check and clean if needed. There is a small door cover on the bottom fron of the washer. First pull the tube out a little and hold it over a container then remove the cap. This will drain the pump and when no more water comes out you can remove the drain filter by turning the cap thats next to the tube you just drained. Sometimes there is still a little water left so you may have to clean up a little but not much. Clean the filter if needed and you can also look in the pipe to see if any debris was left in the pipe. Place everything back and this should get you back to doing more laundry.
Nov 08, 2010 | LG WM1814CW Front Load Washer
How to drain radiator
hello. on the drivers side of radiator is a drain. here is a picture and the instructions for draining the coolant out.
  • Install a tube on the radiator drain. Place the end of the tube in the drain pan.
  • After the engine cools down, remove the radiator cap.
  • Completely open the radiator drain ****.
  • Allow the coolant to drain from the system until the flow stops.
  • Place a drain pan under the block drain hole plug.
  • Remove the drain hole plug from the engine block.
  • Allow the coolant to drain from the block until the flow stops. There may be more drainage from the radiator at this time.
  • Install the block drain hole plug.
  • Close the radiator drain ****.
    Jul 04, 2010 | 1997 GMC Suburban
    My sun roof leaks and no o0ne seems able to fix it 2004 ion3
    Check your water drain holes. There should be one in each corner. The older Saturns would get blocked and the water would back up. On those you can access the drain tube on either front side at the kick panel. I've not tried to fix an ION so I'm not sure how the drains work. Open the sun roof and pour a little water in each corner. The water should drain out behind the front wheels and somewhere near the rear. If it doesn't you have blockage. Find the drain tube and run a wire through it. Make sure your are careful because you can pierce the rubber tube. Good luck.
    Jun 11, 2010 | 2004 Saturn ION
    "OE" message
    OE is actually DE - Drain Error. Pop open the little door on the bottom left of your washer, and unscrew the cap on the little tube on the left. ***Water will drain out!***
    Once the water is out, unscrew the bigger tube on the right. This holds your drain filter. It is likely clogged, so clean it out and reinstall the filter and cap from the small hose.
    Hopefully this fixes it!
    May 02, 2010 | LG WM-2277HW Front Load Washer
    Water begins to drain into the detergent drawer but does not drain into drum fast enough so the drawer area begins to fill and then begins to spill out of the drawer area all over the floor. If I press...
    remove the drain pump and check out.
    This is inevitably caused by a blockage. The small fabric conditioner compartment in the soap dispenser drawer has a removable plastic cap. This cap fits on the top of a tube which has a hole running through it where the water should siphon through.
    When the time comes for the fabric conditioner to be released, cold water enters the small compartment and just washes the conditioner over the top and down the dispenser to the tub. When the water stops flowing, all that is left is the clear water. This water should siphon up the inside of the cap and down the tube.
    This tube often gets blocked with the conditioner and if you remove the dispenser drawer and take off the cap you can give the whole thing a good clean out. If the cap is missing, the siphoning will not occur.
    To test the function, hold the soap drawer under the tap and allow the water to fill the fabric compartment to overflowing. When you turn off the tap, the remaining water should slowly siphon out of the hole under the cap.
    its the problem in the pump and something is getting blocked in the pump so water is not getting out.
      Front-Loading Whirlpool Washers
    1. Unplug the washer. Remove the three screws along the bottom of the toe panel and pull the panel forward to remove it.
    2. Put your bucket or towels under the drain pump. Open the pump slowly so the water doesn't all spill out at once. If you have a wet/dry vacuum, you can connect it to the drain hose to remove the water from the washer before opening the pump.
    3. Open the door covering the pump wiring and disconnect the wiring.
    4. Remove the two drain lines from the pump.
    5. Remove the screw that attaches the pump to the washer frame and pull out the pump.
    6. if the pump is leaky or cracked it needs replacement.
    7. for prats you can get it from
    8. www.repairclinic.com
    This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
    Dec 05, 2009 | Washing Machines
    My lg intellowasher wd1290 error code OE
    I think your "OE" is really a "DE" or drain error. Open the access door on the lower left of the front panel on the machine, drain the remaining water with the small drain hose there, and unscrew and remove the larger thing, which is a filter. Clean filter. If filter was not blocked, check for loose impeller on drain pump motor, which requires replacement of drain pump motor. (just sticking it back on will result in it coming off again)
    If this helps, a "fixya" rating would be appreciated. Thanks.
    Sep 21, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
    Washing Machines Logo
    29 people viewed this question
    Top Zanussi Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
    shaun taylor
    Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
