Question about Garmin Nuvi 265W GPS Receiver
My garmin keeps saying no data available everytime you hit anything on the Where To screen. How do i fix that?
  • 321 Answers
You will have to connect your device to the computer, then you back up the software, maps and applications of your device onto your computer. Then you format your device and restore your everything back onto your device. Then you turn it on, that way it will work for you.
Before you do that, i will advice you reset your device by holding down the power off/on button for about 15 seconds, then the device will restart the unit, that way, it should work properly, but if it does not work properly, then you carry out the back up and restore solution.
That should do the job for you. Hope this information helped.
Posted on Jan 03, 2011
Garmin nuvi no data available
garmin nuvi has been recalled due to internal battery over heating causing the unit to not work properly giving you the no data available
Jan 16, 2012 | Garmin Nuvi 760 Handheld GPS Receiver
There's 3 possibilities;
1. The map is unselected (which is the most likely)
2. The map is locked or
3. The software is out of date and needs to be upgraded.
You'll find the solutions to 1 and 2 at http://www.fixya.com/support/r6197735-no_detailed_maps_found_support_routing. There's more information there than you'll need so to select the map if it's unselected go to paragraph 5.
If the map is locked start at paragraph 2.
If the software needs updating download and install WEBUPDATER from http://www8.garmin.com/support/collection.jsp?product=999-99999-27. to your computer.
Connect your satnav to your computer with the mini USB lead and run WEBUPDATER. It will check for updates and install them to your satnav.
I hope this solves your problem.
Apr 29, 2011 | Garmin Nuvi 265W GPS Receiver
No data available and no maps downloaded
it may just be that the maps are deselected. to correct this go into the tools/settings/map and then at the bottom of the screen in the middle you will see map info tap that and then at the next screen it will show you the maps which are installed if there are any without ticks just tap the box. tap ok and try again if. if there are no map choices then you will need to reinstall the maps on your unit
Apr 26, 2010 | Garmin nuvi 780 GPS
Well my Garmin nuvi 1300 was working fine yestarday but now it's saying "No Map Data Available"... What does that mean?
it sound like someone has "unticked" maps go to settings then maps and map info and look for the screen that says city navigator, and tick box that should work unless someone has attached to pc and wiped maps
Oct 24, 2009 | Garmin nuvi 1300 Car GPS Receiver
Touch screen is a little sluggish
Try cleaning house on it.
Also Try the Garmin web-updater Here to keep it running well.
You could wipe all data and start again,
Backup anything you want first.to the Pc....
Hold bottom right of screen, keep pressing until it says,
Do you want to erase all data, erase it, select yes,
Re-register with Garmin, re-update,
Your good now,
Regards
Apr 16, 2009 | Garmin zumo 550 GPS Receiver
Keeps saying no map data available
try going to garmin site and download a files for it
Jan 29, 2009 | Garmin StreetPilot C330 GPS Receiver
My StreetPilot c330 unit says ?Can?t Unlock Maps? when I power it on. What is the problem?
My Streetpilot c330 and it says? can't unlock maps? How can i fix this problem.
Oct 30, 2008 | Garmin StreetPilot C330 GPS Receiver
Powers up but then stops with a message
Turn on the Garmin and look for the little wrench. Press the wrench and now find Map. Press Map and look for Mapinfo. Press Mapinfo and verify that there is a check mark next to the Mapsource Map.
If you press Mapinfo and there is nothing, then your Mapsource upgrade did not go through.
Jan 08, 2008 | Garmin StreetPilot c510 Deluxe GPS...
Garmin Nuvi 265W GPS Receiver Logo
1,369 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
