Question about Indesit W 123 Front Load Washer
I have a Indesit wixl 105 washing machine that doesn`t work. It wont start. When I plug it all the leds are flikering, inclusive those above the buttons. I`ve cleaned the self-cleaning pump but in vain.... When it was working there wasn`t any weird noise or smell. Thank you for your time
SOURCE: Indesit Standard WIL 123 (UK) Washing Machine
Had a similar problem ,flashing red led means door not locked, I removed door from machine removed front from door and found hinge pin for lock had come adrift, religned pin and chapped back into position .THen replaced door and door to machine .dor shut and lock worked perfectly, hope this helps
Posted on Jan 11, 2008
dazmaraz
  • 67 Answers
SOURCE: indesit W123 washing machine
it maybe your brushes are worn out, on alot of machines these days if the brushes wear the machine wont fill , or your motor itself could be faulty or your board. Unplug the machine , take the back off , get yourself a test meter disconnect the motor and put the probes from the meter and put it across the tags, if the motor is wrong you wont get continuity between 2 tags normally 1 and 5 looking from the top of the block going down
Posted on Mar 31, 2008
jason0110
  • 66 Answers
SOURCE: indesit washing machine w1235
could be the bearings or heater/heater may of lifted or spider sometimes a coin can get trapped
Posted on Jun 15, 2008
  • 6 Answers
SOURCE: my indesit washing machine wia111
Try unplugging it for a longer period of time. The computer in it may set itself back to default settings.
Posted on Jul 29, 2008
SOURCE: Indesit WIDL 106 wont start -ON/OFF-Door Led Flashes rapidly
It is a defectiv controller pcb. I think the eeprom on the controller pcb lost its program (happens often on Indesit machines).
The only solution I know is to change the controller pcb, - not a cheap solution.
I have the same problem with WIDL 106.
Posted on Oct 15, 2009
Indesit WIXL 143 washing machine noise
there maybe a coin or something stuck between the two drums, when the machine spins fast it lifts the item up, unplug the appliance and remove the botton drum hose to see if you can get it out.
Apr 05, 2010 | Washing Machines
I have got Indesit WIXL 123 washing machine. Until yesterday, it was working fine. But today, when I started it, just after taking water and 5 initial spins, its Door Lock LED and 4th Function Button...
i had the same problem its the motor you need a new one luckly my father inlaw is a scrap collector and i come across a spare washer and salvaged all the parts and i tried plugging a new circuit board but still the same so i tried changing the door lock mechanisim but still the same, so itried just for the hell of it the motor and weyhey we have life i thought the motor was the most unlikely thing to cause the problem but im happy but for how long? next year will replace it with new washer.
Oct 26, 2009 | Indesit W 123 Front Load Washer
The drum wont go round
either motor faulty or carbon brushes worn down take motor out and inspect
Jul 08, 2009 | Washing Machines
Dec 01, 2008 | Indesit W 123 Front Load Washer
Indesit W 123 Front Load Washer Logo
164 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
