Question about Coffee Makers & Espresso Machines
Heater element not warming water at all light on front of machine just keeps flashing model number on box hd7850/60
    Novelist:
  • 107 Answers
Hi, Please go through some of the information in the user manual which you would be able to access by clicking on the below web link:- http://download.p4c.philips.com/files/h/hd7850_60/hd7850_60_dfu_eng.pdf Usually the light on the front of the machine keeps blinking because There is not enough water in the water reservoir or the reservoir is not properly been placed.So take out the water reservoir of the machine. Check if there is enough water in the water reservoir (i.e above the 1 cup MIN level if you want to brew 1 cup and above the 2 cups minimum level if you want to brew 2 cups) and replace the water reservoir. Thank you for your time and best wishes for your effort.
Posted on Jan 03, 2011
Have a Miele G1220SC dishwasher. It recently developed a strange problem: when switching it on ALL program lights come on and the machine starts taking water. after a while it stops taking water and starts...
follow this steps and fix it. God bless you
Heating Element
If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Heating Element Assembly
If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Check Fault Codes
If the display lights are flashing and there is an error code in the display window, check the wiring diagram and tech sheet in the dishwasher that will provide information on the fault.
Drain Pump
If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective You'll need to replace it. Drain pumps are not repairable.
Touchpad and Control Panel
If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Jul 30, 2013 | Miele Dishwashers
2 green flashes. hot water is blazing hot set at 120 degrees.have the energy smart unit model#ee2h50rd045v . what is wrong?
2 green flashes is 'High Water Temp.'
http://waterheatertimer.org/Whirlpool-Energy-Smart-electric.html
Typical energy smart manual:
http://waterheatertimer.org/pdf/Whirlpool-energy-smart-electric-manual.pdf
3 flashes is Temperature Sensor failure.
4 flashes is Upper element
5 flashes is Lower element
Troubleshoot section says:
1) Make sure access doors and insulation are installed.
2) Check elements for resistance of 5-25 ohms (if element has a short in center of element, it might not trip breaker)
http://waterheatertimer.org/How-to-test-water-heater-element.html
3) replace element and reset control system.
Buy ordinary 4500 Watt element from hardware store.
http://waterheatertimer.org/How-to-replace-water-heater-element.html
4) I also suspect the self-diagnostic control box.
Manual says: Repair parts may be ordered through your plumber,
local distributor, home improvement center, or by calling
1-877-817-6750.
You need serial number, product number and model number from label on side of tank.
Jan 11, 2011 | Whirlpool Water Heaters
I am only receiving half of the normal amount of hot water.
You have electric water heater.
Electric water heaters are fully repairable by homeowner, excluding hybrid type.
Rheem electric water heaters:
http://www.rheem.com/products/tank_water_heaters/electric_water_heaters/
Rheem fury series manuals and models
http://www.rheem.com/product.aspx?id=09DF2BDD-5E11-4D32-B574-84ACFB8A4619
Age of Rheem water heater is shown first 4 digits of serial number located on side of tank: for example 0705 means July 2005.
Serial number also shows model number & wattage of elements in case you need to buy new generic 4-bolt type 4500 Watt element from hardware store.
A) If your water heater receives very cold incoming water, it may not heat fast enough to keep tank warm.
Add a tempering tank.
http://waterheatertimer.org/Tempering-tank.html
Add insulation over entire water heater except TP valve. Insulate pipes completely.
Read more information:
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
B) 40 or 50 gallon water heater is 240Volts and tank will have 2 access panels on front.
Rheem ships all water heaters with 4500 Watt elements.
Narrow down the suspects:
C) Water heater has some hot water.
This tells us upper element is working.
And that water heater electricity is working.
And that reset button is not tripped.
And that heater is not experiencing run-away overheating event.
That gives us 3 solid suspects.
1) lower element is burned out. Test lower element using inexpensive multi-meter from Home Depot.
Replace element with same wattage shown on label, and clean out sediment:
This will restore water heater to full 99% efficiency.
http://waterheatertimer.org/How-to-clean-sediment-out-of-electric-water-heater.html
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
2) Upper or lower thermostat is bad. Replace both thermostats for about $25.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
If you want to test thermostats and all parts before replacing anything:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
3) Burned or shorted wire. Turn off power. Open covers on side of tank. Remove insulation. Inspect parts for signs of high heat and burning. Especially lower element. Tighten any loose wires. Replace part that shows signs of burning.
Put insulation and cover back over thermostats so cooler outside temperature doesn't cause thermostat to misread tank temperature.
geno_3245_185.jpgRheem 4500 watt element
Dec 14, 2010 | Rheem Water Heaters
The water want stay hot very long
Age of Rheem
water heater is first 4 digits of serial number located on side of tank: for example 0705 means July 2005.
Serial number also shows model number & wattage of elements.
B) If cold outside temperatures are not to blame, your water heater may have a bad thermostat or bad lower element.
C) 40 or 50 gallon water heater is 240Volts and tank will have 2 access panels on front.
D) Water heater has some hot water.
geno_3245_183.jpgRheem element
Dec 14, 2010 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Gaggia Syncrony won't heat up.
I switch the machine on and the green light (number 24) flashes to indicate it is warming up but it never gets there it just keeps flashing for at least half an hour.
Dec 31, 2009 | Gaggia Syncrony Logic 74884 Espresso...
Water heater- not always hot
common problems i have seen are:
1) wife or kids hitting the OFF switch thinking its the light switch in the closet where my heater is located.
2) heating element has died. you should have 2 elements in this heater. when one dies, the heater cannot keep up with the demand of heating 50 gals of water.
if there is a warranty, then now is the time to exercise it.
if no warranty, then it is possible to troubleshoot each element to see which one is dead if you are handy with a voltmeter and electrical wires. if comfy, i can provide steps to narrow it down. list the kenmore model number if you reply.
Feb 02, 2009 | Intermatic WH40 - Water Heater Time Switch...
Miele Washer problem Novotronic Premier
Main wash light flashing is a heating fault. You either have a faulty temp sensor (NTC) or the pressure chamber has blocked and the heater element has popped.
Oct 22, 2006 | Miele Novotronic Premier 500 Front Load...
Coffee Makers & Espresso Machines Logo
144 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
