Question about Vacuums
I'm using Miele Medivac vacuum and I just sucked in a small plastic eye drop container by accident(I sometimes take off the brush part to **** in 'small enough' articles). And it is jammed in the part where the plastic hose connector bends. I think I can take it out if I can just disconnect the long necked plastic hose connector that connects the metal wand part and the hose part. Is it designed to be disconnected or should I not even try it?
I love the fact that the filter bleeped out s.u.c.k ha ha!
Posted on Aug 25, 2008
Http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=761462
Generic problem for all Vacuums
Posted by greenvanilla on Jul 09, 2008
I'm using Miele Medivac vacuum and I just sucked in a small plastic eye drop container by accident (I sometimes take off the brush part to **** in 'small enough' articles). And it is jammed in the part where the plastic hose connector bends. I think I can take it out if I can just disconnect the long necked plastic hose connector that connects the metal wand part and the hose part. Is it designed to be disconnected or should I not even try it?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The long necked plastic hose connector is made to be replaced because they do brake upon occasion and the part is made to come apart. If you need assistance please contact your local vacuum cleaner dealer or to contact the Miele factory to get a owner’s manual to check the trouble shooting guide and or a schematic of the breakdown of how to un-install the
long necked plastic hose connector or gooseneck of which some people call it. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://miele.com/
Customer Service, Repairs, Parts 1-888-785-2828
Mailing address listed below:
Miele, Inc
9 Independence Way
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jul 10, 2008
My S7580 vacuum cleaner is very noisy
Hey, this is Jeremy with Crucial Vacuum,
To remedy a noisy vacuum cleaner there are typically four main areas to check to restore proper functionality. By following the steps below it should be back to normal in no time!
1. Dirty Filters- If your vacuum has suddenly become very loud, check the filter, as it may be dirty. When the filters on a vacuum become excessively dirty, the vacuum may start running louder because it is working hard to create suction. If your filters are dirty, your vacuum is likely not suctioning appropriately, either. To fix this problem, simply remove the filters in your vacuum, rid them of the dust and debris and rinse them out with warm water.
2. Clog- Clogs are often the reason as to why your vacuum cleaner is being extra noisy. While vacuuming, something may get sucked up such as a button or a small toy, for example. Additionally, the clog may be making the vacuum work harder. Check all tubes and hoses in the vacuum to make sure there are no obstructions.
3. Broken Brush Bearing- When a brush bearing breaks, the vacuum cleaner gets loud and starts to vibrate. To remedy the problem, remove the brush and replace it
4. Broken Fan- The fan in the motor of your vacuum may be broken, causing the vacuum to run louder than normal. When dirt runs through the motor of the vacuum, it can collect on the fan, causing it to break. If the fan in your vacuum motor is broken, it will need to be replaced. This is a slightly more tricky process and may require you to bring in your vacuum to a repair shop to have the part replaced.
You can purchase replacement parts for Miele direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/miele.html?limit=60
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
Jun 09, 2015 | Miele Vacuums
Miele S7210 red light on
You may have more dog hair in the main hose. Pull the hose out of the body, turn the lower hose swivel 90 degrees parallel to the floor and twist the hose off. You will see where to remove it at the swivel. Also check the port door on the back of the vacuum near the bottom of the upper section. It can be looks like a parallelogram with 2 plastic screws, twist the screws half a rotation and gently pry the cover off. After clearing out any debris, replace the cover and fasten the screws. A small LED flashlight will be very handy for checking all of the ports and hoses.
Feb 07, 2013 | Miele S7210 Bagged Upright Vacuum
When the brush is on it won't **** properly
Look for blockage carefully as the unit does not know which you have attached.
Dec 05, 2012 | Miele S7210 Bagged Upright Vacuum
Vacuum sucked up a sock through the hose- now it's clogged how do I fix it upright vacuum
Best thing you can try is getting a "snake" like for unclogging water pipes. Start at where it went in, the hose is behind the brush roll, just off to one side. Gently push the snake in until you feel the scock and twist the snake while pulling it out; if nothing comes out after a few attempts, try a reverse approach by removing the rear parallelogram looking port on the back rear of the vacuum. There are 2 plastic screws which only have to make about a quarter turn. Gently lift the cover off the port and try the snake down the left channel.
Jan 24, 2011 | Miele S7210 Bagged Upright Vacuum
When vacuuming hardwood floor, hair gathers on brush and never sucks into vacuum. I spend most of my time cleaning off brushes. How do I clean hardwood floor with dog hairs.
1. Broom and dust pan, then mop
2. Wet dry vac with wide non-brush attachment
3. Here's a link to a vacuum professing to clean pet hairs well
http://www.evvive.com/shop-by-brand/miele-open-box-canister-vacuums/miele-s516-cat-dog-vacuum_2
4. Try to find a wide attachment for the hose that has no brush, maybe something from a wet dry vac.
5. Take your dog outside and brush every day. It helps, but no matter what you do, you will have pet hair if you have an indoor pet.
6. Go to the source. See if your dog will be vacuumed. Half serious on this one.
Mar 14, 2010 | Sebo Air Belt C2.1 Bagged Canister Vacuum
Sucks up hair and dust but it all collects on the brushes
It has a obstruction somewhere in the plastic pipe. You are going to have to get your hands dirty and tear it apart. Dont be affraid, its easier than it looks, just take it apart slowly and take pictures as you go. When you get the bott exposed you will need to stick a wire in there and dig out the obstruction. Good luck
Jul 26, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
I was vacuuming with the Dyson DC 17 and sucked up a berber carpet string by accident and after cutting and pulling it all out of the bottom brush part, the brush no longer spins but the suction part...
The belt could be snapped. If this model has a brush protected belt then it has to be repaired by a service call. If however you can get to the brush roll belt by removing the bottom sole plate (turning over the vacuum so that you're looking at the base) with the plastic catches undone where you can see the belt then check to see if it has snapped. If it hasn't snapped then it may just need readjusting.
If you can't see the belt and has protective covers that can't be undone then the model has a brush control system that has to be replaced by someone who can do Dyson repairs.
Mar 12, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
LOSING SUCTION
is brushes moving, if so it is clogged , usually takes a star bit to take apart to clean
Feb 07, 2009 | Hoover U5753-900 WindTunnel Bagless...
Hoover doesn't suck well
Did you check the inlet from the bottom? Take the bottom plate off, make sure that the tube(inlet)is free of any clogs. Also if the belt is stretched, then it won't drive the brush roll like it should, replace it part #38528033.
Feb 04, 2008 | Hoover U5444-900 5100 Wind Tunnel 15 Inch...
Vacuums Logo
299 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
