I have a flamerite serena fire it has just stopped working think it could be the internal fuse but cant find it any ideas
2 Suggested Answers
SOURCE: Our flamerite odyssey fire has
I may of had the same problem, when i turned on the fire with the remote it would turn off straight away or not turn on at all. However i have just got it working again. Open the the door so you can turn the switch on and off. If you look in the opening where the two bulbs are, there is a small gap on the left. Make sure the mains is turned off, if you have small enough hands put your arm through the gap and push in the connector that is on the back of the on/off switch. My fire has not been working for ages, now that i have done this, it is working fine again. Good luck.
Posted on Nov 21, 2010
I have a flamerite milan fire suite lights not coming on checked bulbs they are OK heating working also
No power to the fire: Check the wall socket, plug and fuse. No illumination: Make sure the fire is turned on. Check heater is working, if so change lamps. Illumination but no heat: The safety cut has operated see note on operating the Fire. Noise when illuminated: Due to moving parts, the electric fire will make a noise. Noise from the heater when in use: The sound of rushing air is normal. Logo
Jan 21, 2017 | Heating & Cooling
I have a flame rite fire model number 172/180 will not work do you still have these fires
Maybe your circuit board is fried too? Circuit boards come up as issues more than a few.
Kind Regards,
Scott
Need circuit board flamerite 172 180 elect fire
How to fix flamerite fire
Feb 10, 2015 | Home
Flamerite fire spare parts
This is an issue to be resolved with Flamerite.
Oct 22, 2013 | Grilling
Our flamerite odyssey fire has stopped blowing out heat and we have changed the thermostat which seemed to be the obvious solution, but it just now blows the fuse.
Nov 20, 2010 | Heating & Cooling
I have a Flamerite Odyssey Suite Electric Fire approx 5 yrs old. The thermostat no longer works and I cannot find anyone that sells a replacement. The thermostat only has the number 143211 256-C...
I have just tried to obtain a stat for this same fire Flamerite was no use at all.I have put a link in where the sta was to override, it's on full now, but theres heat now. Terry Risley Electrical Services 0788 4061406
Oct 24, 2010 | Universal Remote Control Heating & Cooling
Breakdown with Flamerite Corello FO1
my Flamerite Corello fire does not work we had to have the circuit bard fixed within the first 12months of getting it and it went again over a year ago how can i fix it
Aug 15, 2010 | Heating & Cooling
I have a Flamerite fire, model is called Isis. The fire come with a remote control which you use to turn on the lights and the heat. The fire is not working, when you press the remote the bulbs on the fire...
Hi I have the same fire with almost the same problem, I even bought some new batteries for the remote thinking that may be the problem.
I bought my fire suite second hand ,(Vega suite with Isis inset) in almost new condition and absulutely love it, so am gutted it has stopped working , Someone said , ''It could be the hidden bulbs at the backof the isis inset that need changing, But on trying to find access to the bulbs I just cannot find a way to get to them, There is 4 screws on the near inside which previous owner has cross threaded and wondered if that is the only way to get to them, If you have any ideas I would really appreciate your help and will contact you also if I can find a solution, Take care have fun
Maureena
Dec 14, 2009 | Dryers
My flamerite atlanta fire will not switch on. When i do turn the heat on the fire cuts out
Similar thing happened to mine at weekend after fitting a new hearth and fire surround (sods law) think its the heater unit £57.50 from flamerite
Sep 04, 2008 | Heating & Cooling
Heating & Cooling Logo
156 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
