Question about KitchenAid KERC507 Electric Kitchen Range
Our stove makes a constant buzzing sound. Anyone else have this problem?
Constant buzzing noise, must be transformer but stove works perfect. is this normal
Look to see if coiled gas line is vibrating against back of stove. (Or try pulling stove forward a bit).
Otherwise, you are probably correct about a transformer. It can be ''defective'' and still work.
May 18, 2015 | GE Profile JGP636 Gas Cooktop
My EFa 700H makes a buzzing sound when i turn it on at the wall
Perhaps this is a warning buzzer to tell you you have to set the clock?
It also could be a fan.
Jun 17, 2014 | Bosch Stove / Oven / Range Name Plate...
Stove is shaking
I would suggest going to this website http://www.drolet.ca/en/installer-locator and you can find someone from Drolet who is authorized to diagnose your issue. If you can't find someone close by on the Drolet website then look for chimney sweeps through Angie's List preferably and they can help diagnose and determine the problem. First stop always default to an AUTHORIZED SERVICING DROLET service techinichian. Especially with pellet stoves, depending on the technology, these can be extremely technical with the exhaust and combustion blowers being off balance and causing the stove to shake. Without someone there to look at it and diagnose it hands on it is equivalent to when your car has a check engine light and you don't take it to a mechanic. Pellet stoves can be extremely tricky to work on. Good luck and try the manufacturer first.
Find an installer near you Drolet
Jan 11, 2014 | Drolet ECO-45 High Efficiency EPA Pellet...
Buzzing noise ft
Warning buzzer. Unplug and try resetting system
Oct 05, 2013 | Magic Chef Chest Freezer MCCF5WBX
Constant buzzing in my 15 W amplifier
Make sure you have a ground prong on your power cord. Most input jacks nowadays are closed circuit. They have a switch built in that won't allow any sound without the cord plugged in. You may have a damaged jack that will give you a loud hiss, a loud hum or crackling depending on what volume your controls are set at.
Aug 27, 2009 | Line 6 Spider Iii 15 Modeling Guitar...
Buzzing Noise coming from GE Stovetop.
It could be a loose transformer that needs to be remounted. Pull the stove out, remove all of the screws at the top and visually inspect the transformers and wiring. This should be an easy fix, but if you leave it too long then your stove will malfunction. I hope this helps at least get you to the next step.
Jun 21, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Kenmore gas stove makes a buzzing sound
Is the door locked?? Is it an electronic buzzer sound??
hold the CLEAR button for 3 seconds - the door will unlock.
open the door - and press CLEAR for 3 seconds.
Error code may come up.... close and re-open the door.
Are there any indications on the display?
Or is this a mechanical buzzing from underneath? in this case your gas regulator's diaphragm has failed.
If the above reset doesnt wokr (and the sound is electric) your circuit board will need replacement.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Jun 09, 2009 | Kenmore Kitchen Ranges
Re: Sony 771 ... constant buzzing sound in background
Sounds like feedback. Check your speaker connections at the speaker and the main unit.
Jun 26, 2017 | Sony MHC-771 Shelf System
Pellet stove
The buzzing is possibly your exhaust/combustion blower. This blower is the fan sound you hear as the stove starts up. If you ARE hearing a NORMAL fan sound, then the buzzing could be the auger motor. Do you have a Foxfire with an igniter? This tells me the series of model you have and what control system it uses.
Feb 24, 2008 | Heating & Cooling
Buzzing sound
You haven't specified where the buzzing sound is coming from, if it is coming from speakers, changing capacitors in the audio section will fix the problem, especially the filters. Now if it sounds like a hissing sound from back of the tv, the CRT base socket is the culprit. It is an easy thing to fix, and the base is cheap, but make sure you purchase the exact same type of base or it will harm the CRT. Good luck.
Jan 22, 2008 | Samsung TXN2775HF 27" TV
KitchenAid KERC507 Electric Kitchen Range Logo
101 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
