Brand new heater won't start. Transformer buzzes. Power is good. led doesn't light. 3A fuse at bottom of circuit board keeps blowing as soon as the power to the unit is turned on. Problem?
    Novelist:
    Champion:
  • 224 Answers
There is a definite problem here with a dead short, honestly I would return the heater to where ever you purchased it from. To be brand new it should be out of the box and plug it in maybe a little programming and instant heat. Hopefully you are not to far away from the purchase place.
Posted on Jan 03, 2011
Green LED light on circuit board is off. Fuse snaps as soon as you give power. Solution?
The green light being off simply means there's no power, if the fuse is blowing this isn't surprising. If your circuit board looks OK - no burn marks etc I think the most likely culprits are the components that get the mains voltage which are the two fans and the transformer. You tube has videos about checking these components with a multimeter.
Nov 25, 2015 | Mr. Heater MHU45NG
What runs on the .3amp fuse?
look on inside cover of control unit it has a schematic
Jul 04, 2014 | Balboa Instruments Pool & Spa
I HAVE A 24VOLT TRANSFORMER WERE DOES THE RED WIRE AND THE YELLOW WIRE GO CONNECTED TO THE HEATER BOARD ST9101A 1014 THE MODEL RGDG-075AMGR
Generally the 24VAC terminals are marked on the furnace board. If it is blowing fuses, check for a short circuit in the thermostat wiring. I have found that the short is usually at the condenser unit where the insulation deteriorated. Many times caused by a dog or cat chewing on the wire. To test, remove the thermostat connections at the control board and power up to see if fuse blows. If it doesn't, you found your problem. Good luck.
May 12, 2014 | Heating & Cooling
I have a speed queen sc35md2yu40001washer that keeps blowing the 2amp fuse as soon as I switch on the breaker it is the fuse where the incoming power goes through before it goes to the transformer
Good job tracing the location of the fuses. Now, logically, the transformer is the next thing to check. When power is turned off at the house breaker, remove one of the wires on the output side of the transformer and see what happens when you turn the power back on. If the fuse blows, the transformer is shot and needs to be replaced. If not, go to the next device on the circuit, etc...
Jan 16, 2013 | Washing Machines
Hi, I stupidly turned on my brand new Francis X7 machine without using a transformer (I bought it from the US, used it in Malaysia), and of course, something blew, and it now doesn't work at all. Any...
The machine is made to work with 120 volts and you have plugged this on a 220 volt mains circuit thereby blowing up the fuse, or the power circuit, possible heater and the main controller unit board.
A step down transformer was needed to work this unit safely . Now unless the unit is opened the damage cannot be confirmed but if you are lucky the fuse would ahve blown and saved the rest. if so test it with a new fuse using a 220 to 120 volt convertor.( transformer with good rating)
Jul 05, 2011 | Microwave Ovens
The 5 amp fuse on the board keeps blowing the transformer smoked i replaced that but it still blows the fuse when i install a new fuse.the contactor buzzes then the fuse blows.
You ahve a short in the low voltage system, thats why the fuse blows and the transformer burned out. Find the short and then replace that fuse and that should solve your problem.
Jun 28, 2011 | Heating & Cooling
Brand new furnace, transformer opens on primary side. also seems that transformer is hotter than normal. I have checked all componets for short to ground and have replaced control board.
The short is on the 24V side...I would put a 3 amp fuse in series with the Hot 24v line before it gets to the circuit board from the transformer you will have to replace again....have a few spare fuses....after having done that./...turn the power on and call for heat...Observe what happens and what stage of the cycle you're in when the fuse blows...Exhaust fan starts...Ignitor starts to warn up....etc...I need more info...shorts are hard enough to find as it is.......does it blow the fuse immediately...usually it will go through a few stages before you get to the problem piece....Make and Model of the furnace could also be helpful to me
Oct 31, 2009 | Heating & Cooling
TI 810 Blowing F2 fuse
Try Changing the bridge rectifier near the transformer.
Dezzi
Dec 30, 2007 | Texas Instruments TI 810 Matrix Printer
Open Questions:
vulcan bonaire comfort control External natural gas electronic ignition 2004. ISSUE: Fan blowing only cool air continuously. Forced to kill power to stop it. model is one of the following. MB514E,20E or 30E. Going by mech drawing parts list. i can confirm what type of sensors i have cleaned with very fine sandpaper. flame sensor PN 5441603SP and IGNITER ELECTRODE PN 5441602SP The fault code i see is described as the following. There are x4 LED's. Sequence Left to Right. LEGEND: 1 Flame Sensor 2 Pressure switch 3 OverTemp 4 Diag. R Red G Green S Solid Colour B Blinking LED Behaviour. In order 2RS & 4GS Until i hear ignition. 2RS & 3RB Duration: split second 2RB,3RS & 4GB Duration: split second 3RS & 4GB Duration: Until it has completed blinking x4 times. 3RS Duration 4 seconds Repeat last two mentioned behaviour. in my own opinion, as a safety feature, the unit thinks that it has overheated or is about to. so kills the gas and force feeding cool air to heating components to save it from frying. Does this mean i have fault 04 if so does this mean i may have a faulty igniter or flame sensor or maybe a faulty as described in the mech drawing SWITCH OVER TEMPERATURE 120 degrees celsius. Am i correct here? Is this the over temperature cut out switch? if no one can really pinpoint which part requires replacement, can you at least, in sequence advise which parts to purchase? so then ill just try my luck. i wonder how to properly test if flame sensor, igniter, over temp etc is faulty with a multimeter. do i just perform a continuity test. I wonder what other parts can i test related to this fault im getting.
Jul 22, 2018 | Vulcan Heating & Cooling
Heating & Cooling Logo
74 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
