Question about Acer Aspire 5520-5156 Laptop
Loosing back up cd's - Acer Aspire 5520-5156 Laptop
  • Chris
    Chris Jan 03, 2011
    Please elaborate, did you lose your backup cd's?
    Do you want to order a new set?
    have you tried reinstalling from the built in backup?
    Do you need to reinstall? if so, have you already backed up any files you need like photos?
    Thanks,
    Chris
  • 114 Answers
Type in msconfig in the run box or in a CMD box (open as admin) then retick the entry Acer Backup Manager in the start up tab. Reboot and you shoud be prompted to make a new set of back up disks.
Posted on Jan 03, 2011
Sony CDP - Cx455 CD player will not play or power off. I can only turn it off by unplugging it. ??
the belts might be off. Take the cover off, and look in the back to see if the belts are loose. If the cd mech can't get back to the home position, then the unit will not turn off
Dec 15, 2016 | Sony Audio Players & Recorders
I have a 1015 Wurlitzer 1015 Jukebox 100 CD player. The problem just started in that the carriage picks up the cd, swings it over to the turntable, won't release the cd, returns it back to the carriage and...
Switch K7. It clicks and stops the motor when the gripper puts the CD back. Either the bracket which clicks it has come loose or the switch doesn't work anymore. (and it's a PIG to change!) K7 is labelled and is the far side of the gripper gears.
Sep 18, 2013 | Wurlitzer Jukebox 1015 One More Time...
Restore back to fact.
are you trying to restore your system to factory settings?
it means you can loose all your data in your computer. If you dont have data use your system restore cd come along with your desktop to restore.
Put your restore cd in your cd rom and restart your system. Boot with the cd and follow instructions on screen
Jun 25, 2010 | Acer Aspire™ T180 PC Desktop
1988 accord the dashlights were working and i pushed the cd player back and they won't work now. how do i fix it?
you must have either pulled a wire loose or you created a short check your fuse box first and then check for loose connections behind your cd player
Mar 03, 2010 | 1988 Honda Accord 4 Door
My cd was open it came oiut and the connections
Yes you can reconnect the cable ribbon its should work but it is broken it needs to be replaced. Good Luck.
Aug 27, 2009 | Acer (91.48R37.002) CD-RW/DVD-ROM (Combo)...
Player has been working fine for about a year. Now, it turns off and comes back on periodically. At times it will turn off and loose all previously programmed settings.
if its loosing all memory settings then the constant voltage supply is faulty (yellow wire on rear of player) try tracing it back to the fuse box checking for bad connections
john
Jul 25, 2009 | Sony CDX-GT310 CD Player
My Toshiba Satelite laptop with Vista constantly looses the CD/DVD drive.. If I reboot it comes back, but as soon as I put a cd in the drive, it disapears again ..It will not load anything from the drive...
Hi there.
This is a common problem with vista loosing the CD/DVD drives.
Do this >>>>>> right click on "computer" and select "manage" from the sub menu, then select "device manager" from the left hand side, it will generate a list of devices, look down the list for CD/DVD and click on the + icon next to it, from the drop down list right click and uninstall, restart the PC and let vista re-install the drivers for you, then try to use the CD/DVD.
If this does not work please post back.
Good luck and thanks for using FixYa!!
Mar 15, 2009 | Computers & Internet
Numark CD mix 2
Hi aondj
I would remove the back panel, and get access to the soldering of the connectors that are giving you trouble. resolder them, and see how you go. Get back to me here if this does not cure it and we shall get into it further
regards
Graeme
Apr 12, 2008 | Nu Mark Numark Cd-Mix-2 Dual CD...
The radio works but the CD does not
Hi Could be a bad selector switch, try jiggling it back and forth to see in it works in an in between position. Possible loose power connector to the cd player or cd is faulty. Jay
Jan 21, 2008 | GPX TVB544 5 in. Portable Television
Cd player not working it reads error02
this sounds like a wire has cum loose or ur cd player sensor has been damaged
Sep 27, 2007 | Dual XDM6830 CD Player
Acer Aspire 5520-5156 Laptop Logo
21 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
