Hello mate, hotpoint aqxxl129pm lights on front of machine keep flashing & wont spine out water,taken pump off and cleaned out pipes still doing the same, any ideas could the pump be broke?
  • Washing Mach... Master
  • 1,527 Answers
Hello, you would need to test the pump with a multimeter , any spin problems could be down to the module board
regards
shaun
Posted on Jan 03, 2011
  • phil bag Feb 19, 2011
    Mine is doing the same. do you know if wayne-dud fixed the problem or have you any more ideas.
Washing machine blocked how do I unblock?
clean filter at the front or back of the machine will have a turn to the left insert. where the water pipe/s fit take off take top of undo the inlet valve clean out filter. tip up washer find pump you can undo this and clean housing inlets one waste one sump pipe clean and put back clean these hoses thoroughly waste pipe blow through to make sure not blocked that's it.
please rate my answer thankyou
Aug 04, 2015 | Hotpoint Aqualtis AQXXL129PM Washer Front...
I have a hotpoint ulitma washing machine that is
Error code E15 means pump time out, that it is to say the water is not pumping out enough in the time alloted by the control module.
There must be some kind of blockage or restriction in the pump or the outlet hose, so you need to check these.
Please rate my solution.
Thanks.
Jan 19, 2010 | Washing Machines
Aquarius hotpoint wf541 wont pump the water out at the end of the cycle
You need to clean the filter.
Remove lower rear cover of washer.
Locate and remove large black hose fastened to bottom of drum.
Remove and clean the filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well
Hope this helps with your problem
Dec 28, 2009 | Hotpoint Aquarius WF000 Front Load Washer
My washer dryer wont spin or rinse,
hello mam
you should call the engineer because he will check the timer switch and the motor if he finds the problem in any one of these he will rectify it.
Oct 04, 2009 | Hotpoint Ultima WF860 Front Load Washer
Display lights flash
I have just posted the same problem about the lights flashing rapidly, I have just gone to investigate my machine and switched it off and on again at the mains and so far it has resolved the problem. Hope this works for you.
Mar 09, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint aquarius wf740
Sounds like water pressure could be low or inlet pipe is kinked.
F04: possible filling or water level problem. Check water inlet pipe (or shut-off valve), or the outlet pipe, or the pump or pump filter if accessible (check for blockages or foreign objects). Also could be the water valve solenoid weak, causing filling to be too slow.
F05: possible draining (pumping off) problem, check the pump filter, or pump, outlet pipe, or U-BEND.
Don't forget to rate!
Feb 27, 2008 | Hotpoint Aquarius WD63 Front Load...
Prewash flashing and machine Overfilling
Their is a small bowl connected by a see trough plastic pipe leading up to the preshour switch, that you will have to clean out the bowl and disconect the pipe from the presure switch and blow trough this to clean out any droplets of water. Replace then try the machine again, it may fill up again, dont dispair, empty the machine and re-blow trough the hose again with it disconected from the preshure switch. To empty the machine of water place the outlet hose into a bucket 3 or 4 times.
slimjim1
Oct 15, 2007 | Hotpoint Aquarius WF000 Front Load Washer
Washing Machines Logo
199 people viewed this question
Top Washing Machines Experts
