Question about Manfrotto 3005D Tripod
How do I take my ball & head from the normal position to the center position inside the tripod legs? I want to use it for close up macro shots.
  • 747 Answers
I was unable to find a picture of this tripod and head arrangement so on experience only I'll suggest how to do this. All of my Manfrotto tripods whether round tube or octagonal center post design work the same way. At the the bottom of the center post is a cap, it might be a rubber plug, twist lock type with a hook, or a rectangular stopper. Which ever this plug/cap can come out will a little effort. It's there to prevent the user from inadvertently pulling the center post out while extending to maximum height. You need to loosed the tension scree/lock off loose but not necessary to remove the screw. Then remove the center post by pulling it right out of the tripod housing. Now invert the post and reinstall it from the bottom side up, the tricky part is to realign the friction/tension lock and sometimes I use a pen/pencil to hold it over to the side while I insert the center post. once in place tighten the friction lock. The draw back I had at first was using the camera upside down. I've since solved that problem with a C type bracket. Hope this helps
Posted on Jan 03, 2011
Head won't secure to tripod
Two potential issues. 1. Perhaps you have just not screwed it on tight enough. Just tighten the black knob as much as you can then screw the head on your legs as tight as you can. 2. If you can't even do that I will assume that the hole on the bottom of the head is too large for the screw on the tripod legs, in which case you just need a a bushing adapter. Like this one:
http://www.bhphotovideo.com/c/product/882988-REG/Sunwayfoto_tn_15_Bushing_3_8_1_4_Stainless_Steel.html
Apr 10, 2014 | Gitzo Gh2750qr Series 2 Magnesium Off...
Legs Locks Loose
Ross
-It is possible that you are overloading the tripod, thus causing this problem (check specs on tripod model)
HOWEVER IF YOU AREN'T....Giotto uses (2) different leg lock designs..., quick release (normally adjusted by a socket wrench) or rotary (screw locks)!
- If tripod uses screw locks, sometimes foreign material gets into the mechanism and either damages it or prohibits from tightening!!!!!
Note: rotary locks are easy to maintain & if you need parts..., they are user replaceable and usually inexpensive! (contact Giottos distributor in the country you live in)!!!
BUT FIRST!!!! (often problem is caused by dirty lock mechanism)
-carefully unscrew the leg lock (that is slipping) until it separates from the leg higher leg section & carefully pull out the lower tube (at the top of the lower tube will be 'shims' that are part of the lock mechanism).
-Look closely at existing 'shims' do they show signs of cracking, of a build up of dirt, etc. (if damaged they will need to be replaced)
-if shims are undamaged..., use rubbing alcohol & a clean cloth to clean shims and both the tube they sit on and the inside of the tube they slide into.
-once both sides of the tubes and both male & female threads of the locking mechanism are cleaned..., place a light coating of a light oil into the threads (sewing machine oil, bike chain oil, etc)...., do not get oil on the shims!!!!!
-replace locking shims back into position and carefully slide leg tube back into place..., then screw locking collar on (this should not take any force..., if while threading lock collar back on..., it seems tight..., back off collar and check positioning of shims). Repeat procedure!!!
TEST RESULTS!!!
Note: in most cases with rotary locks, problem is purely a maintenance issue, cleaning usually fixes the issue!!!
Peter
Nov 08, 2013 | Giottos (BL1150) Tripod
Customer service for giottos
To order service parts contact the importer:
Canada-JCL Sales (Richmond B.C.)
USA-HP Marketing (Pine Brook NJ)
-Inform them of the tripod model and possibly provide them with photos of where the spreader arms attach to both the legs & the center column...., you may require additional parts.
Mar 31, 2013 | Giottos Vt-809 3-section Compact Tripod...
Hi, I have just bought the 190CXPRO3 carbon fibre
Little confused here. Is the head the part you want to detach from an older set of legs? Do you want to remove center post from new legs or old legs. The base plate remains on the center post/ Aftre removing 3 set screws, and you want to remove the head from the baseplate and it will not turn, grap slip joint pliers or a pipe wrench, wrap the jaws with cloth ( to prevent marring of head or legs) and while holding head with wrench, have someone else turn legs
Apr 26, 2011 | Manfrotto (190XB,128RC) Tripod
Slight dent in one leg near base plate,how does the top section come away from base plate for possible repair,leg will not close all the way.
Check out : www.bogentripodparts.com. While I am not that familiar with that model, there are parts available)not sure which ones_ and ther is a video on tripod repair, albeit a different model.
Apr 24, 2011 | Manfrotto (Distributed by Bogen) 055XDB...
I want to take some photos of jewelry for insurance files, How do I take close up shots that do not blur
Use a tripod for best results. Use "macro" mode for great close-ups. Try to avoid using flash because it will be too strong for close-ups. Bring over some lamps and position them for good lighting.
Jan 24, 2011 | Samsung Digimax D73 Digital Camera
HI, I have a Bogen/Manfrotto 468/3435 Pro Ball head on a 3011bn tripod. How do I get this off of the tripod?
Hi, extend the extension and look under the mounting head. You will see three set screws requiring a slotted type screw driver. Loosen these off so the head is just protruding from the flange. Have the ball head locked in position and unscrew it from the center mounting stud Left to loosen Right to tighten.
Dec 12, 2010 | Cameras
I can't get the ball head off my tripod. I've loosened the set screws at the base, but the head won't budge.
You can try this:
spray lubricant between ball head and base, wrap the ball head with a heavy rag( to help prevent scratches, use a pip wrench on ball head while someone else holds legs ( or also wrap legs in cloth and hold in vise). DO THIS AT OWN RISK
Dec 04, 2010 | Manfrotto (Distributed by Bogen) 055XB...
The rubbers that go round the locking part of a gitzo tripod leg, 3 on each leg
Try the us distributor for that part
Bogen Imaging Company
ATTN: Service Dept.
565 East Crescent Ave,
Ramsey, NJ 07446
201-818-9500
Jul 23, 2009 | Gitzo Magnesium Center Ball Head for...
Manfrotto 3005D Tripod Logo
Top Manfrotto Photography Experts
Mitch Davis
Mitch Davis
ray gallant
Are you a Manfrotto Photography Expert? Answer questions, earn points and help others
