Question about Brother EM-630 Typewriter
No Characters Typing
Brand new out of box brother em-630... i can see the daisy wheel moving and striking but nothing appears on the paper. i tried word processing mode, and nothing prints using the print function. just opened it this morning - i can see where it worked when factory tested. no letters or numbers will show up now - have removed ribbon, daisy wheel, and correction tape, and replaced all correctly and still won't type onto paper. not even getting a light hit.
  • fossphur Aug 01, 2008
    This sounds similar to my problem only when I press delete, the typewriter strikes the ribbon and instead PRINTS the letter.
  • fossphur Nov 06, 2008
    The ribbon does lift, it lifts out of the way of the striker. It is almost like if I had a whiteout ribbon installed, it would be typing in white, and whiting out in black. But the two ribbons are nothing alike and you can't possibly install them wrong.
  • 478 Answers
Could be the ribbon is not lifting, do you see an image on the ribbon, also may be twisted inside the cartridge the shiny side has to be facing the keyboard.
Posted on Nov 06, 2008
Brother ce60
Try a milti part form if the carbon prints then you have a ribbon problem. Very old or not lifting/\.
Jul 03, 2013 | Office Equipment & Supplies
Keyboard want work
If your machine is not printing properly:
1.Examine the ribbon cartridge to make sure it has not run out of Ribbon. If your ribbon appears silver or gray, install a new cartridge.
2. Ensure the black lever in the center of the carriage is pressed to the rear, towards the paper. If not press it to the rear to lock the Daisy Wheel into place.
3. With the typewriter turned off, press and hold down the "CODE" Key, the "SHIFT" Key, and the "TAB" Key.
4.Restore power with all three Keys depressed.
5.When the machine sounds a beep tone, release all three keys.
6.The carrier will move to the left indicating that the memory has been cleared and the machine has been reset.
7.Try typing.
If the problem continues, your unit will need servicing. You can locate a Brother Authorized Service Center in your area:
May 08, 2013 | Brother EM-530 Typewriter
Daisy wheel will go to the letter pressed, but the hammer will not strike. It moves along like it's typing, but the daisy wheel is the only thing responding.
May 05, 2011 | Brother SX-4000 Typewriter
My AX -430 typewriter was functioning well as i was using it. However as i was typing a new word, the letters are no longer visible on the paper. The part that hits or is it the hammer or arm, can no...
It sound like you have a broken part. If the hammer is not hitting hard enough, the armature theat make the hammer strike the keys is broken. This is a common problem with the ax's
Mar 03, 2011 | Brother EM-430 Typewriter
Check for KBII and PS (ketboard II , Proportional space) or any bthing interfearing with the printwheel.
Apr 06, 2010 | Brother SX-4000 Typewriter
Brother CE-70 typewriter. Was typing perfectly well. Over about 15 characters the impact on the print head reduced to nil. Although printhead appears to strike the daisy wheel the character does not strike...
Make sure that the ribbon is moving. If characters are piling up in the same spot on the ribbon you will get this problem. Easiest fix is to replace the ribbon. Many brand new ribbons can have a problem. If this dosent solve the problem it may be a mechanical problem with the mechanism that drives the ribbon, requiring a technician to repair.
Oct 22, 2008 | IBM Wheelwriter 30 Typewriter
Typewriter suddenly will not print!
It's been awhile since I've worked on these.
What is the typing mechanism in here? I believe Brother was using a wheel.
Jun 19, 2008 | Brother EM-530 Typewriter
Cannot get daisy wheel to type correct letters
Turn oFF the typewriter, take the ribbon out.....use the lever on top to release and remove the print wheel cartridge. Lightly rotate it to see if it will move and reinsert the cartridge. snap it back into place.
Turn on the machine, the typewriter should move the carrier to the left and reset the printwheel....if it is snapped back properly.
Jan 14, 2008 | Brother GX-6750 Typewriter
Brother EM-630 Typewriter Logo
247 people viewed this question
James Cagle
James Cagle
Jim Keysor
