Question about Philips DVD757VR DVD Player/VCR
Are there any known problems with the DVD757VR power supply as I have a unit that is showing no signs of life (no lights etc). All fuses appear in tact.
SOURCE: Unit appears dead.
G'day, I don't have a solution, but my Panasonic NV-GS250 is doing exactly the same thing - nothing! Good luck Aaron
Posted on Jun 08, 2007
  • 33 Answers
SOURCE: No power to unit
Maybe it has an area on it where its supposed to be chargee to the powerpoint because most things like this may need to be charged like
Nintendo ds and portable dvd players.if this does not work take it back for a refund
Posted on Jul 25, 2009
  • 188 Answers
SOURCE: No Power to Television
LG gives 2 years warranty.
Posted on Dec 09, 2009
  • 21 Answers
SOURCE: HEad Unit gets power, but will not appear as it is on
if it is a new head unit return it for a different one
Posted on Jan 16, 2010
  • 311 Answers
SOURCE: will not turn on, no sign of life,
where is this 60V being mesured from?
Posted on May 12, 2010
No power
Look if you can safely get it apart for the fuse inside the unit and if possible test the power cord and where it connects, this is the place to begin---total dead units are usually easy to fix, follow the AC voltage from the wall or voltage source inside to the fuse etc.
Dec 20, 2012 | Acer S242HL bid LCD Monitor
Canon copier pc 310 will not turn on.
Hi there please check the fuser and power supply and let me know.
Jan 15, 2011 | Canon MF8180C Color Laser MFC Printer
TV set appears to be 'dead'
Check the power supply capacitors to see if they are bulged.
If they are replace them, this should fix the problem, if not replace the main board.
otherwise replace the power pcb
May 23, 2010 | LG 26LH200C 26 in TV
A power surge seems to have burned out my Toshiba TV/VCR combo.
The power supply does have fuses. They require removing the back cover of the unit. Note: High voltage is present so I recommend having a pro do this.
In units like this many times a part will fail and the fuses will be ok. At this point you will need a pro again.
I would replace the unit. The repair cost could be in the 60 dollar range depending on the severity of the problem and shop rates in your area.
May 08, 2010 | Toshiba MD13P3 13 in. TV/DVD Combo
Dead appearing ups/inverter
keep on your main switch. off all the lights fan and other electrical items, let that inverter get charge first
Jun 18, 2009 | APC Back-UPS CS 500VA UPS System
MOTHERBOARD shows no signs of life./MB# KTBC51GLF
Have you tested the power supply? Try switching out the power supply and see if that gets you up and running.
Mar 14, 2009 | Gateway GT4022 PC Desktop
Blown dell motherboard
Have you checked to make sure it wasn't the power supply? If this motherboard is still inside the pc and the cd/dvd lights up, or the network card shows life, fans, case lights, etc: than I would rule bad mobo. If nothing shows signs of life, try power supply or even better maybe a lose connection.Check all cabling and wire plugs. Clean out any dust.
Dec 29, 2008 | Dell Computer Refurbished OPTIPLEX SX270...
It would help to know a few things; Is the power supply coming on at all? - Fan should be running, front panel light(s) coming on at all, etc.
You also didn't mention if it is a fairly standard clone or a brand-name system, model number, etc.
If there is no sign of life when turning on, it is most likely the power supply - the low-end units are incredibly cheaply made and prone to failure at random.
If it is a standard unit and you have no life signs, replace it. They are available from $10-100 dollars.
If you do have signs of life, watch the monitor screen for any signs of video.
If there is any kind of display, the BIOS is at least reacting and if the system is over 5 years old, replace the coin cell battery located on the board. These are widely available- even Walmart.
Obviously, the unit shuld be powered off, unplugged and you should touch some bare metal part of the chassis to discharge any static you might be carrying around.
If you have any worthwhile information, you might want to post it - it kinda, sorta helps.
Feb 28, 2008 | EPoX EP-4PLAI Motherboard
Unit appears dead.
Dec 13, 2006 | Canon MV700 Mini DV Digital Camcorder
Philips DVD757VR DVD Player/VCR Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
