Question about Frigidaire FEF336BC Electric Kitchen Range
What is the problem when the over won't shut off and I saw on the display a code of F1 ???
  • Frigidaire Master
  • 1,902 Answers
Hello & Welcome to FixYa
Error code F1 is displayed due to electronic oven control failure and the only way to solve this problem is by replacing the control board which is bad. Please get back to me if you have any other questions.
Kevin
Posted on Jan 03, 2011
Oven is on and won't turn off. Fuction code "F1" is displayed. Have to shut power at circuit breaker???
If oven is electronic /gas keep circuit breaker off.... check and see if it is still under warranty and/or if it is a call center you can call 4 repair....also... if gas you might want to turn off gas valve in the back of oven until oven is repaired.......F1 is a error code!
May 15, 2016 | Kenmore Kitchen Ranges
Frigidaire oven displaying the f1 error code
You are experiencing a runaway temperature, or too hot of a temperature for the control board and sensors within the unit. When the unit gets this error code it shuts down for safety reasons. You would need a professional to diagnose the connections and control wiring to the control board, and the elements for safety.
Dec 30, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
F1 Error Code : Kenmore Self-Clean Electric Range. Oven wont shut off. I can silence the F1 alert but it keeps coming right back on every 30 to 60 seconds or so. Range top burners work fine, but oven
An F1 error code usually means that the temperature probe isn't sending the correct signal back to the control board. Try disconnecting power to the range for at least a minute. If F1 displays after you cycle power you may need to replace the EOC (Electronic Oven Control).
Dec 05, 2012 | Ovens
Mer6772bas ovens won't work, bottom oven won't open
F1-4 is a lower oven runaway clean error F9-3 is a lower oven door latch failure. Must be a bad door latch causing the errors.
GEMINI FAULT CODES
Aug 30, 2012 | Maytag MER6772BAS Gemini Electric Kitchen...
I have a frigidaire range/stove. I was roasting dinner at 300 then turn the oven up to 400 near the end. Shortly after there was a pop that sounded like it came from inside the oven. I thought a potato...
F1
  • The F1 code indicates a control failure. Try pressing a key to see if it displays on the screen. If not, the keypad may have shorted and requires replacement. If the keypad is fine, there is perhaps a problem with the internal checksum; disconnect the power for 30 seconds and reconnect it. If the code remains, you must replace the electronic oven control (EOC). If the F1 code appears when the oven is running, it means that the oven senses an overheating condition. Use an external thermometer to check the temperature inside the oven. If it is accurate, it means that either the temperature sensor probe or the control relay has malfunctioned. Disconnect the power, and inspect the sensor probe, replacing it if necessary. If the oven is actually overheating, replace the EOC. If the oven is allowed to overheat, the resulting damage is possibly so extensive that the entire oven may require replacement.
Read more: Frigidaire Oven Error Codes ' eHow.com http://www.ehow.com/list_7105089_frigidaire-oven-error-codes.html#ixzz1OVfekgRx
Jun 06, 2011 | Frigidaire Ovens
My washer keeps shutting off and F1 shows up on the display.
The "F1" error code on the Whirlpool cabrio is quite common, and generally has to do with the control board. Replacing the control panel may resolve this issue. However, I believe Whirlpool is aware of the F1 issue with the Cabrio, and is fixing some machines for free. Please call 1-800-253-1301 for more details and see if you are eligible for a free repair.
Thank you !!
Aug 12, 2010 | Kenmore Oasis 27042 Top Load Washer
I have a GE Range. Purchased in 1993. The user guide says it is for JSP26GP, JSP28GP, JSP31GP. The thing won't quit beeping and the function code displayed if F1. What should I do? Thanks!
The F1 error code means your oven temperature has exceeded 590 degrees and the beeping is to warn you to shut it off.
Itis likely that the oven thermostat has failed, so you will need to get it replaced.
Jan 04, 2010 | GE Ovens
When you turn on the oven, display reads CLN or F1.
that means the oven either needs cleaned or that the oven is stuck in cleaning mode i suggest unplugging it for a few hours or clean the oven
Sep 30, 2009 | Amana Kitchen Ranges
My fisher paykel nautlis dishwaher display error code F1
What is the Model #? If both drawers, if a double, display F1 and won't shut-up then the flood switch is tripped and you have to unplug it to keep it from beeping and the drain motor running. The causes for the F1 fault can be numerous but not excluding bad lid lifts, broken link support, cracked drain line and wrong soap. Call F/P
Jul 19, 2009 | Fisher DS603W / DS603B / DS603I Dishwasher
F1 Code on display
The model # is incorrect...please post correct m #....
Aug 27, 2007 | Kenmore 94223 Electric Kitchen Range
Frigidaire FEF336BC Electric Kitchen Range Logo
65 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
