Question about Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Electric Dryer
On my whirlpool dryer, it says " Control Panel Locked". Is there a reset on this thing. it was working fine and then this message popped up. HELP,
  • 2,509 Answers
You don't give a model number, is this applicable? Select and hold END OF CYCLE SIGNAL for 3 seconds until the CONTROL LOCKED Status light turns off.
Posted on Jan 03, 2011
Whirlpool dryer control locked is on
Turn off the breaker to the unit, for at 15 minutes, then back on, and it might reset itself, if not, I would have to know a couple things....is it an electronic control panel? If it is an electronic control panel, there are error codes, that I can find through the model and serial numbers....and then walk you through it.
Sep 12, 2013 | Dryers
Tip
The front light lit on my Whirlpool dryer is showing control locked
Hi.
If the front light lit is control locked, that means that your Whirlpool electric dryer had been set in control lock mode.
Control lock is a special mode that will prevent user from changing settings or using control until the dryer gets unlocked again.
The machine is set to control lock mode by holding down the CONTROL LOCK/UNLOCK button for several seconds. In the same way you can stop the control lock mode when the machine is already set to Control Lock.
When the dryer is running and Control Locked is on, the dryer can still be stopped by pressing the Pause/Cancel button, but cannot be restarted until the control is unlocked.
If the front light lit is control locked but the dryer door opens and it does not turn off, then you are probably in this situation. In that case, the door will be opening , but the machine still stays locked.
Disconnecting the machine from power, either unplugging power cord or tripping circuit breaker, won't help. The control lock system is designed to stay on in case of power failure.
If the machine is control locked, try unlocking it with the following procedure.
To unlock: Press and hold the CONTROL LOCK/UNLOCK button for 3 to 5 seconds to turn the control lock feature off.
If that does not work, try disconnecting power for five minutes to reset the machine, and eventually do unlock again. As said, cutting power alone will not cause the machine to unlock.
If the machine is still not responding, the lights stay on all the time, the dryer panel does not respond to control unlock procedure, and the door does not lock anymore, then it may be a defective control board.
If you are in this situation, before replacing the control board more parts, including the door lock must be tested. In that case the best option may be contacting the Whirlpool support number listed on the Dryer use and care manual, usually in the last pages.
In this case try resetting control lock as explained above, as told the dryer is more likely control locked and then stopped.
Regards.
Ginko.
on Feb 01, 2010 | Whirlpool GEW9250 Electric Dryer
My dryer says "control locked".
Hello & Welcome to FixYa
This is a common issue with Whirlpool Duet washer however; your whirlpool duet washer needs a reset to resolve the control lock problem. Press and hold the END OF CYCLE/CYCLE SIGNAL button for 15 seconds to reset the control. Please get back to me if you have any other questions.
Kevin
Aug 24, 2011 | Whirlpool Duet GHW9150P Front Load Washer
The "Control Locked" is lit up and the control
Try holding down the CONTROL LOCK button down for about 3 seconds.
See if that works.
Comment back here if it doesn't and I will provide additional instructions if required.
Good luck.
Joe.
Feb 27, 2011 | Whirlpool Duet 7.0 Cu. Ft. 7-Cycle Super...
My Whirlpool Duet dryer has the "Control Locked"
Hi
To unlock it press the END OF CYCLE SIGNAL button for 15 seconds and the unit will reset.
Dec 31, 2010 | Whirlpool GEW9250 Electric Dryer
I have a Whirlpool Duet Dryer that indicates the "Control [is] Locked. The problem somehow began while I was away over the weekend and it no longer allows me to start the dryer. (I have a total of...
Hello
Your whirlpool duet dryer needs a reset to resolve the control lock problem. Press and hold the END OF CYCLE button for 15 seconds to reset the control. Please get back to me if you have any other questions.
Kevin
Nov 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Help! I have a whirlpool frt load dryer it is locked (controls)
You need to press and hold the "End of Cycle Signal" button on this model to lock or unlock the control panel. The instructions should be printed directly below the button.
Jun 30, 2009 | Whirlpool GEW9250 Electric Dryer
Whirlpool Duet Dryer has a mind of it's own, cannot change contro
First of all check to see that the control panel is not locked. There is a lock button assigned on the control panel. It should say it next to one of the buttons. Not door locked. You have to hold that button in for 5 - 10 seconds to unlock the panel. If not, you may need a new panel, happens often, its part # 8558753 depending on the color. Thanks Dave www.washermd.com
Dec 12, 2008 | Whirlpool GEW9250 Electric Dryer
Control panel locked light is on
ck for a button with hold to lock under it hold button 3-5 sec
Jul 02, 2008 | Whirlpool GEW9250 Electric Dryer
Dryer not working
Open dryer's rear panel and look for a broken belt and does the motor spins. Let me know with your results and we will see how could we assist you.
Aug 21, 2007 | Whirlpool LAB2700ML Pedestal Drawer for...
Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Electric Dryer Logo
71 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
