Question about Brother MFC255CW All-in-One InkJet Printer
How do I do a reset of the Brother MFC255CW? I have a paper jam error message. There is no paper jam.
IrishDruid
  • 2712 Answers
SOURCE: Lexmark X6570 printer - Cleared
Ok, the paper jam could be due to one of the following:
  • Check for paper in the paper tray
  • Check the size of the paper in the paper tray to see if it is the same as what the printer is set for.
  • Defective D-roller
  • Debris in the paper path
  • Gears not turning or broken gear
  • Defective paper tray
  • Broken input sensor flag
  • Defective input sensor board
  • Defective system cable 2
  • Defective system board
  • Exit Sensor flag (Fuser)
  • Exit Sensor board (Fuser)
  • System cable 1
First try a hard reset - unplug printer from power source, wait a minute and replug. If it still does not work, uninstall the driver, reboot PC and reinstall (or download latest version from lexmark.com.
If there is no bit of paper or debris stuck in the rollers, it would indicate something more serious, and in need of servicing. If your machine is under warranty, I suggest you take it back to the shop and get it replaced.
If your warranty has run out, then you'll either have to get it serviced or buy a new printer (whichever works out cheaper for you)
Hope that helps!
Posted on Nov 11, 2008
TIPS72
  • 369 Answers
SOURCE: Canon MP610 - Paper jam error message
PLEASE REMOVE THE POWER CABLE AND REINSERT IT IT SHOUL BE OK AND IF STILL PERSIST JUST RESTART THE PC IF STILL RESIST PLEASE LET SOME TECHNICIAN TO CHECK FOR THE SENSOR FOR THE PAPER JAM ...
GOOD LUCK
Posted on Jan 04, 2009
  • 133 Answers
SOURCE: message on brother MFC7420 "back door open" when it's not
Actually, you need to double check the back cover and front cover, open them all to check all paper jam.
Besure to check the back cover, normally all paper jam is from the back.
be sure to close the front cover at the last cover to close.
Posted on May 29, 2009
SOURCE: how do you reset brother dcp-117c printer to
press # 6 button and disconnect the power cable..press them both and reconnect that..reset is done
Posted on Mar 24, 2010
SOURCE: my brother mfc-6490cw printer keeps
my brother MFC-6490CW keeps coming up with an error message 'cannot print 70' how do i solve this?
Posted on Jan 09, 2011
Paper jam on screen will not reset
To clear the error message Paper Jam after you removed the jammed paper, open and close the scanner cover.
If you still receive the error message, a small piece of paper may be stuck inside your Brother machine.
Refer the below link for the steps to remove any ripped paper remaining inside your Brother machine:
still receive the error message Paper Jam after removed the jammed paper...
Apr 22, 2014 | Brother International Brother MFC-J4510DW
Brother DCP-9010cn is showing Unable to print code 73
The error code 73 means that you have a paper jam or a paper sensor problem.
here are a list of all the codes for brother printers:
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000100/000068/faq000168_005.html?reg=us&c=us&lang=en&prod=mfc5490cn_all
To troubleshoot paper jams go here:
http://www.manualslib.com/manual/355700/Brother-Mfc-9010cn.html?page=78#manual
If its not a paper jam you will need to call brother customer service as it may need a sensor part.
1-877-BROTHER (877-276-8437)
Mar 14, 2014 | Office Equipment & Supplies
Printer screen says NO PAPER FEED...when there is paper in the tray.
'No paper feed' is different from 'No Paper' : it basically means that the printer cannot 'grab' a sheet of paper to feed it!
Just remove and loosen the stack of paper from the tray and reinsert the stack making sure that the sides are not jammed hard against the guides.
ps. For good measure, also check for any remains of previously jammed/torned print outs.
Hope it helps!
Jan 07, 2011 | Brother MFC255CW All-in-One InkJet Printer
I have a Brother HL-4070CDW printer and the display shows "Jam Tray 1 - Remove the jammed paper from Tray 1". We have followed ALL of the troubleshooting instructions from the Brother manual and...
hello, sorry to say that your machine will need the entire front door assembly, whats happening, is that the guide for paper feed, well it now has problem, so far the only way to fix it, is to replace this part, i have tried alot of temp. fixes, but only last a few days, and then it comes back, sometimes worse.
Oct 27, 2010 | Brother HL-4070CDW Printer
Brother MFC-8840D printer w/false paper jam indication.
With my Brother 8840D I have had paper jams that when cleared would not delete from the display nor would the machine operate until I unplugged the machine for around eight hours. I guess it is a sort of reset or reboot.
Jun 06, 2010 | Brother MFC 8840D All-In-One Laser Printer
Get paper jam error on Brother MFC 5840CN
are you using brother oem ink? generic ink gives lots of problems
Dec 09, 2008 | Brother MFC-5840CN All-In-One InkJet...
Brother MFC 3240C Paper Jam Error Message
If it is not resetting then either there is still something on a sensor or you did something to a sensor by accident.
here is the manual
http://www.retrevo.com/s/brother+2820+fax++manual
Nov 21, 2007 | Brother IntelliFax-2820 Laser Fax
Brother MFC255CW All-in-One InkJet Printer Logo
107 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
