Question about Gaggia Baby Espresso Machine
The frother has stopped working also takes a lot longer for water to come through.
    President:
  • 1,618 Answers
Descale machine and also check the holes at the end of the steam wand they might be blocked.
Posted on Jan 05, 2011
XN4050 not working
If you have HARD water(lots of iron) then it probably needed cleaned sooner than you did it .
Jan 18, 2015 | Krups XP 4050 Espresso Machine
My Keurig Milk Frother stopped working. The green light comes on but turns off immediately. Is there something I can fix?
How long have you been using that? Why not try the frother from Kitchen Ace. I can assure you that the quality of there products are really awesome!
Amazon com Kitchen Ace Can Opener Stainless Steel with Smooth Edge...
Sep 12, 2014 | Coffee Makers & Espresso Machines
The frother doesn't work on my 2nd hand Krups XP2070
The frother usually has a rubber tip. The rubber tip normally has an additional pipe right next to the frother. The pipe's black plastic tip has a very small hole in it. This can get clogged and the frother will not work. Take a pin/needle and unclog this very small hole. The pipe itself can be plugged with milk residue and will need cleaning.
If you take the strainer cup and hold it up to a light, you can see if all the holes are open. If not, this will slow down the brewing process and create a LOT of back pressure which can force the water to flow out through the sides above the strainer cup. Take a needle and open each hole of the strainer cup.
When grinding your own beans, try not to process the coffee too fine or it starts to fit into the holes of the strainer cup. This can also slow down the brewing process. If you grind a batch too fine, you can sometimes get a way with mixing it with a batch of coarse or under-ground beans.
Mar 20, 2014 | Krups XP2070 10 cup Coffee Maker/15 bar...
What does a blue light mean on my aerochino? thanks.
Means you are not heating your milk, the frothing milk will be cold (for iced drinks) because you have held the button down longer than normal. Usually it takes 5 Seconds for the blue light to go on. try turning it on or pushing the button faster, It should turn on red, for heated and frothed milk.
Nov 10, 2010 | Nespresso Aeroccino Automatic Milk Frother
The milk in the frother won't foam. I tried different kinds of milk but still doesn't work
the frother should have come wit two attachments a coiled one and a paddle the coil one is for frothing fill frother to bottom mark or slightly lower.hope this helps let me know how you went
Sep 14, 2010 | Nespresso Citizmilk C120
The frother on my cafe roma has stopped working. I removed the wand but where the steam comes out is stopped up. how do i fix this
The "frother" is probably blocked. Remove it and see if you can blow through it. If not, you can try cleaning it with a paper clip. If that won't work, place the metal frother tube in a pot of water with a bit of ammonia or vinegar in it. Heat the water to boiling, then let it simmer awhile. After it cools, try using the paper clip again. You should clean the steamer attachment after each use:
2. Remove the froth enhancer and rinse under warm tap water. 3. Wipe the steam wand with a damp cloth. 4. Briefly set the Selector Control to the ‘STEAM’ position to clear any remaining milk from the steam wand.
Oct 30, 2009 | Breville ESP8XL Espresso Machine
No water or steam is coming out of the frother. Tried rinsing machine and going back and forth from brew to froth with no results.
Just fixed this same problem by taking apart the water solenoid valve and cleaning out its connection tube of deposits that was blocking water/steam flow. I removed the magnetic coil but that's not required. The connector was very tight because it had loctite sealer on the threads. I used plumbers teflon tape on the threads when reassembling.
May 11, 2009 | Jura Capresso C1300 Coffee Maker, Espresso...
No steam comes to milk frother
Try this: 1. Pour in vinegar instead of water. 2. Bring vinegar to a boil but do not run it through the machine. 3. Turn off machine for about an hour. 4. Remove sheath from the frother and clean the metal tip. 5. Place tip of frother into large mug of cold water. 6. Turn espresso machine on and allow vinegar to run through frother. 7. You'll know the frother is clear when the water in the mug begins to churn rapidly (and perhaps loudly).
It may take the vinegar a little while to dissolve and loosen the blockage. If the process does not work the first time time, try again later and allow the warm vinegar to sit in the machine longer.
Optional: Before starting the process, unbend a paperclip or thin metal hook (the kind used for hanging holiday ornaments) and use it to clear the steamer orifice.
To keep frother clear: Follow recommended descaling schedule in user manual
Jun 05, 2008 | Krups Allegro FND111 Espresso & Coffee...
The frothing stick doesn't seem to work
descaling time not with vinegar with descaler vinegar remove calcium in little piece descaler melt it use 1 part descaler 1 part water put in the water container start it up open valve after a few second turn it off leave it for15 minute repeat untill empty after do 2or3 rince descaler is corosif thank you for using fixya pierre
Feb 10, 2008 | Dualit Espresso 889 Espresso & Coffee...
Kitchenaid Espresso maker no longer dispenses hot water from frother
by frother you mean it puts out steam ? if yes then I need to know how long you hold down the button and have you checked the hose in back to see if it has cracks or is kinked?
Dec 31, 2007 | KitchenAid PRO LINE KPES100PM Espresso...
Gaggia Baby Espresso Machine Logo
114 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Michael Vincent Cruz
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
