Question about GPS
I am restoring a 1984 BMW 323i with a Bosch ignition system. The wiring loom requires replacing. I have purchased a wiring loom from a car with a Siemans ignition system and have traced the wires that join the engine wiring loom to the main wiring loom and have established that the wires could be interchanged with the wires from the new wiring loom although the plugs are different, the wires could be soldered on to their respective positions. I would like to know if this is suitable. The Siemans system has an Ignition Coil Resistor which the Bosch system does not have.
    Brigadier General:
  • 7,191 Answers
You have posted the problem under "GPS Devices" category.
Kindly submit the question under BMW Cars section on the website by clicking this link so that the best car experts can view and post a solution to the problem.
On the page which opens, type the question in the "Ask an Expert" box on the right hand side of the page and click on "Post a problem" button.
Thanks for using FixYa.
Posted on Jan 03, 2011
I am restoring a 1984 BMW 323i model E30. I am replacing the Bosch main wiring loom with a Siemans wiring loom. I plan to use the original bosch engine wiring loom and connect it to the multi-plug of the...
your asking me something now ,havent seen one in years but the cables can be connected over with time and patience and a bit of solder is good as it doesnt corrode ,now the ballast resistor fitted with the siemans was a different type of circuit and as it was a bosch then wire it as the bosch was wired ,because the ballast resistor was used in conjuction with a 9v coil and when you cranked the engine it allowed full 12v voltage to the coil to give an increased spark under crank load ,never did work that well to be honest and the resistors often packed up so use it as the bosch system .On the siemans you had a wire from starter connection on ignition switch to coil and the ignition feed went through the resistor to the coil ,Simple enough but them resistors were a right pain in all honesty
Jan 03, 2011 | BMW 3 Series Cars & Trucks
Would a 1985 bmw r 45 have electronic ignition or points
Electrical System
Ignition System
Battery ignition. From 1981model: Contact free electronic ignition
Alternator
Bosch 280 W
Starter
Bosch 0.7 Kw
Spark Plugs
Hope this helps.
Bosch W 5 D / Beru 14-5D / Champion N 6 Y or Bosch W 7 D / Beru 14-7D / Champion N 10 Y
Nov 20, 2010 | 1985 BMW R 45
I require the wiring diagram for a Bosch 0227100111 electronic ignition module used in my car
This is all I can help with, pins:
1 = coil
2 = b-
3 = b-
4 = b+
5 = +input
6 = -input
7 = tach
Jan 06, 2010 | 1984 Alfa Romeo GTV6
Mercedes w124 E280 1994 model. The engine stalls at time at junction; cuts out on take off or stalls before it takes off at junction. Have replaced just MAF(Bosch) and replaced wire loom too, otherwise car...
check condition of spark plugs and wires.. they can cause cut out at take off.
I have problems with Bosch spark plugs. But I love the Bosch ultra premium ignition wires
Also check for vauume leaks, intake hoses tight.etc.
Oct 28, 2009 | 1994 Mercedes-Benz E-Class
1999 bmw 323i dashboard reads S and car wont turn over
If this is an automatic then the gearbox sounds as though it has a fault, check fuses in glovebox i think theres two in there for the gearbox. if they are ok you need to have a diagnostic check im afraiid
Mar 23, 2009 | 1999 BMW 323 Series
Intermitent ignition failure BMW r80
Guys ...this problem is caused by a faulty Bosch ignition coil (gray type). Replace both the Ignition control unit which is linked to this type of ignition coil (buy Transpo BM 300 - cheapest pattern type) & the ignition coil itself with a newer type 1990's model (red outlet points to spark leads.) & the problem will disappear. This is a known problem caused by hairline cracks in the gray casing. These cracks cause intermittent electrical disconnects when hot/wet - MICHAEL - DUBLIN - IRELAND
Nov 20, 2008 | 1995 BMW R 80
Trunk ajar sensor stuck in on mode
the connection is the problem you will find broken or frayed wire inside wiring loom at the left trunk hindge a quick fix
Nov 14, 2008 | 1999 BMW 323 Series
BMW Wiring Diagram
Google it;enter you're make/model system operations schematics-it'll take you to wireing diagram.
Oct 23, 2008 | 1984 BMW 3 Series
GPS Logo
23 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
