Question about Sony Playstation 3 (PS3) Console
I have turned my PS3 on via the controller, it boots into life but nothing appears on my tv. My HDMI cable in plugged in and was working about 8 hours ago. I have unplugged cables given them a clean but still nothing happens. I have tried switching it off and back on via the main switch at the back off the console.
  • 839 Answers
There is no need to have technical knowledge to do fix this problem.....Just get repair guide from internet and follow the steps in it and fix your problem by your own.......
Click here to download repair guide
Posted on Jan 03, 2011
I have a panasonic Th-42pv500a. I'm trying to connect my ps3 Via HDMI but it won't work. The ps3 works in my other tv with the same HDMI cable. And the foxtel box works in the panasonic with the same HDMI...
the playstation detects that you are changing display settings. hopefully you still have the old red yellow and white cord that we all used to use to plug in stuff to your tv . use this cord to connect your playstation to the tv, it should pop up that you want to change display settings. then after you go through that unplug and recconect the hdmi and it should run you through it again, Another option - when you plug in your ps3 to the tv , turn everything on the tv and playstation. if nothing pops up turn off your tv and playstation , literaly unplug them from the outlet for a good minute then plug everything back in and you should fix it that way. hope one of these work
May 04, 2011 | Televison & Video
Got a PS3 hooked upto a Samsung 40" LCD TV via
I would suggest trying a different TV, and maybe see if you still have any Component or Standard Definition Composite cables to connect the PS3 to the TV and see if it works that way. I would assume you did this when you said you reset the resolution on your PS3, but turn it off, then hold in the power button until it beeps twice in a row. (Just in case) Make sure everything is plugged in twice and your TV is on the right input. If none of that works, there may be something wrong with the graphics adapters on your PS3 in which case you will need to contact Sony about fixing it.
Mar 04, 2011 | Sony Playstation 3 (PS3) Console
My Toshiba 62HM95 DLP TV does not work with my PS3 via HDMI or Component cables. Is the TV not compatible or is something wrong?
hello, unplug all the cables from you ps3, turn the power off on the ps3 then turn it on press and hold the standby button on the front of the ps3 you will hear 1 bleep then 2 short bleeps after the short bleep relase the button, also turn your tv off then on again, when your ps3 comes back on plug the hdmi cable into your ps3 and then into your tv hdmi 1 on the tv go into the menu find hdmi click on this you should get a picture and sound hope it works
regards
shaun
Nov 22, 2010 | Toshiba 62HM95 62" HDTV
HDMI Video not working on kv-30hs420 but audio works
AmigaDude posts how to reset the video to factory settings here: http://www.avsforum.com/avs-vb/showthread.php?t=766771
The instructions are as follows: 1 - Turn on TV and set input to port being used.
2 - Make sure PS3 is connected via correct cable.
3 - Power on PS3 via power button and HOLD IT for 5 seconds (release after the second beep). It should automatically configure your PS3 to the TV's native resolution for all settings.
Once reset, you'll connect your RCA cables (Red/White/Yellow) and set up the PS3 display settings. To get there from the XMB bar, go to Settings > Display Settings. You might have to disconnect the HDMI cable from the PS3 before the RCA cables work. I don't remember entirely.
Select Video Output Settings > HDMI > Automatic. If you can see the prompt about a max resoultion of 1080i (with your HDMI cable plugged in) you should be good. Select Yes and press X to continue. You can set up the audio but it's not necessary. Select Finish and you should be good.
Jul 12, 2009 | Sony FD Trinitron WEGA KV-30HS420 30" TV
How would i know if my HDMI ports are working or not?? Tried to connect a PS3 to it but nothing. Thought it may have been the cable so checked someones that i know is working and still nothing. Checked...
As you already checked PS3 and HDMI cable,
select HDMI input in TV and connect PS3 via HDMI cable. TV should show PS3 picture.
And if still no joy then HDMI input port in TV is bad and need to replace input board/ main board.
Jul 08, 2009 | LG M227WD-PZ LCD TV
Powers on - no output to TV
Ok, this is general hardware failure. This will need to be repaired by a Sony tech asap. the central board is malfunctioning at this time. Contact Sony asap.
Jun 20, 2009 | Sony Playstation 3 (PS3) Console
Playstation 3 Does not display on TV using HDMI or regular video cable. senerio: My son hook it up using HDMI Cable to my bedroom sony flat screen tv to watch a blue ray movie and play some games. which...
I posted to your problem with a similar one. I was able to get my PS3 to work by:
1.) Powering down both the PS3 and ViewSonic LCD
2.) Unplugging the power cables to both PS3 and LCD
3.) Waiting at least 10 or more seconds
4.) Plugging in the power cables to both PS3 and LCD
5.) Turning on the ViewSonic LCD
6.) Turning on the PS3 and holding down the power button until the beep
After this sequence I heard the bootup audio and the menu appeared on the screen- which detected the HDMI connection to my LCD.
Very odd.. I've had my PS3 in the same place for months and just today this happened.
I wanted to post my success. Best of luck!
Seth
Dec 26, 2008 | Sony Playstation 3 (PS3) Console
Please help with getting 5.1 sound from my TV!
You must run a Digital Optical cable from your PS3 to your reciever. Then press your function button on your recievers remote until you see SAT/CABLE on your recievers display. Next go to your PS3 settings and go to Sound settings, then Audio Output settings, and select Digital out (OPTICAL) then your done. This is the only way to get true digital sound from your PS3 to your reciever.
Oct 01, 2007 | Sony DAV-HDX500 System
My ps3 display
to all those who cannot see any display..hold down the on/off button until it beeps once, then wait a few seconds until it beeps again, the ps3 will have reset itself and will adjust the visual settings to fit your tv
Mar 08, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
21 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
