Question about Hotpoint Dryers
Hi, got a hotpoint aquarius ctd 40 dryer. When I close the door and start it up it trips the power. dont know if it is the door at fault. Andrew
  • 1,531 Answers
You will need to check the main terminal block make sure there are no wies burnt or touching each other.
If that is ok then you will need to check the heating element and make sure,it is not grounding out on the cabinet,and make sure to check all the wiring to the unit.you will also need to check the motor and drive belt and make sure they move freely.
The last thng ot check is you circuit breaker.
Posted on Jan 04, 2011
Not heating up
first thing to check is the heating coils,,if ok go to the censor just over the top of the door,,,this is most likely the dud part
Jul 10, 2010 | Hotpoint Dryers
HOTPOINT WD420 TRIPS ALL THE SOCKETS IN MY HOUSE
You have a fault on the machine which is a dead short or an earth leakage.
Neither can be sorted out without a set of testers and some knowledge
Unless you can get hold of a resistance checker and know how to use it call a in a repair person
Jun 14, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
My hotpoint ctd 40 wont heat up
Things that could stop a electric dryer from heating:
- house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug.
A ohm meter test for these parts is here.
Jan 27, 2009 | Hotpoint Dryers
Runs slow then speefds up
If it is slow in starting, could be faulty start capacitor, slack or worn belt,overloading of course.
the capacitor is mounted near the motor, and is a round cylindrical tube about 4" long.
If u require any more info , then let me know.
Plz rate my solution.
Thanks.
Jan 03, 2009 | Hotpoint TDC32 Electric Dryer
Turn washer dryer on ok, then close door then curcuit trips
check the wiring and make sure nothing metal is on the motor because your dryer has a short in it somewhere
Dec 23, 2008 | Hotpoint Ariston Aquarius WD420 Front Load...
Hotpoint CTD 40
Thermostats do not have a reset
IF the dryer has failed by overheating, the device is called a thermal fuse, it is a one-shot protector, and needs to be replaced.
If the thermal fuse has blown the dryer is likely {expletive deleted} with lint and needs to be cleaned.
STILL require make and model details for replacement instructions
Oct 08, 2008 | Dryers
Help
stats come as a kit and often go faulty. if you are in uk, try currys masterpart
Aug 07, 2008 | Dryers
Hotpoint Aquarius WD64 - Tripping the electric?!
something is going down to earth, start by unplugging the motor and retesting, if it doesn't trip them check the motor carbons etc, if it trips then check the heater element for contact down to earth, replace if needed etc, then check the outlet pump the same way if i have helped rate me please ps when working on machine remove from power supply
Oct 03, 2007 | Hotpoint Aquarius WD63 Front Load...
Earth Fault
IM GUESSING THAT YOU GOT A LEAKY GASKET THATS SPRAYING WATER ONTO YOUR DOOR INTERLOCK SWITCH CHECK TO SSE IF YOU AHVE ANY RIPS OR TEAR IN THE GASKET. DOOR INTERLOCK WOULD BE WORTH CHANGING AS THEY DONT COST MUCH.
Jul 24, 2006 | Hotpoint Aquarius WD640 Front Load...
Dryers Logo
35 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
